thinkgeo.mapsuite.routing.buildingroutingdatartgroutingsourceeventargs
ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs
<!– Class –> This class represents the parameters passed out through the BuildingRoutingData event.
Public MethodBuildingRoutingDataRtgRoutingSourceEventArgs This is the default constructor.
Public MethodBuildingRoutingDataRtgRoutingSourceEventArgs RouteSegment, LineShape This is the constructor that passed the routeSegment.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean Gets or sets the value that represents whether the building data is cancelled. The default value is false.
Public PropertyLineShape LineShape Gets or sets the value that represents the current lineShape during build.
Public PropertyRouteSegment RouteSegment Gets or sets the value that represents the current routeSegment during route.
BuildingRoutingDataRtgRoutingSourceEventArgs()
Name Type Description
Go Back
BuildingRoutingDataRtgRoutingSourceEventArgs(RouteSegment, LineShape)
routeSegment RouteSegment<!– ThinkGeo.MapSuite.Routing.RouteSegment –> The routeSegment that you want pass out by event.
lineShape LineShape<!– ThinkGeo.MapSuite.Core.LineShape –> The lineShape that you want pass out by event.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
If you set the value to true, it will cancel building routing data.
Return Type
<!– ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs –> Go Back
LineShape
The default value is null if you call the default constructor.
Return Type
RouteSegment
Return Type
thinkgeo.mapsuite.routing.buildingroutingdatartgroutingsourceeventargs.1440040134.txt.gz · Last modified: 2015/09/18 03:06 (external edit)
