thinkgeo.mapsuite.portablecore.mapengine
ThinkGeo.MapSuite.Core.MapEngine
This class is for generating maps.
    • ThinkGeo.MapSuite.Core.MapEngine
MapEngine()
  • Create a new instance of the MapEngine.
DrawStaticLayers(Int32,Int32,GeographyUnit)
  • Draw a group of static layers and return a new image with the specified width and height.
  • Type:GeoImage
  • Description:The resulting image after drawing the group of static layers based on the specified width and height.
  • width
    • Description:This parameter specifies the width of the returning image.
  • height
    • Description:This parameter specifies the height of the returning image.
  • mapUnit
    • Description:This parameter specifies the MapUnit used in the current map.
DrawDynamicLayers(Int32,Int32,GeographyUnit)
  • Draw a group of dynamic layers and return a new image with the specified width and height.
  • Type:GeoImage
  • Description:The resulting image after drawing the group of dynamic layers based on the specified width and height.
  • width
  • height
  • mapUnit
DrawAdornmentLayers(Int32,Int32,GeographyUnit)
  • Draw a group of AdornmentLayers and return a new image with the specified width and height.
  • Type:GeoImage
  • Description:The resulting image after drawing the group of AdornmentLayers based on the specified width and height.
  • width
  • height
  • mapUnit
ZoomIn(Int32)
  • This method updates the CurrentExtent that is zoomed in by the percentage provided.
  • None
  • Description:This method updates the CurrentExtent that is zoomed in by the percentage provided.
  • percentage
    • Description:This parameter is the percentage by which you want to zoom in.
ZoomIntoCenter(Int32,PointShape,Single,Single)
  • This method will update the CurrentExtent by using the ZoomIntoCenter operation.
  • The CurrentExtent will be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterwards.
  • Description:None.
  • percentage
  • worldPoint
    • Description:This parameter is the world point you want the extent to be centered on.
  • screenWidth
    • Type:Single
    • Description:This parameter is the width in screen coordinates.
  • screenHeight
    • Type:Single
    • Description:This parameter is the height in screen coordinates.
ZoomIntoCenter(Int32,Feature,Single,Single)
  • This method returns an extent that is centered and zoomed in.
  • The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterwards.
  • Description:This method returns an extent that is centered and zoomed in.
  • percentage
  • centerFeature
    • Type:Feature
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ZoomIntoCenter(Int32,Single,Single,Single,Single)
  • This method updates the CurrentExtent based on a calculated rectangle that is centered and zoomed in.
  • Description:None.
  • percentage
  • screenX
    • Type:Single
    • Description:This parameter is the screen X you want to center on.
  • screenY
    • Type:Single
    • Description:This parameter is the screen Y you want to center on.
  • screenWidth
    • Type:Single
    • Description:This parameter is the width of the screen.
  • screenHeight
    • Type:Single
    • Description:This parameter is the height of the screen.
ZoomOut(Int32)
  • This method will update the CurrentExtent by using the ZoomOut operation.
  • None
  • Description:None.
  • percentage
    • Description:This parameter is the percentage by which you want to zoom.
ZoomOutToCenter(Int32,PointShape,Single,Single)
  • This method updates the CurrentExtent by using the ZoomOutToCenter operation.
  • Description:None.
  • percentage
    • Description:This parameter is the percentage by which you want to zoom out.
  • worldPoint
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ZoomOutToCenter(Int32,Feature,Single,Single)
  • Description:None.
  • percentage
  • centerFeature
    • Type:Feature
    • Description:This parameter is the world point Feature you want the extent to be centered on.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ZoomOutToCenter(Int32,Single,Single,Single,Single)
  • Description:None.
  • percentage
  • screenX
    • Type:Single
  • screenY
    • Type:Single
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
Pan(PanDirection,Int32)
  • Update the CurrentExtent by using a panning operation.
  • None
  • Description:None.
  • panDirection
    • Description:This parameter is the direction you want to pan.
  • percentage
    • Description:This parameter is the percentage by which you want to pan.
Pan(Single,Int32)
  • This method updates the CurrentExtent by using a panning operation.
  • None
  • Description:None.
  • degree
    • Type:Single
    • Description:This parameter is the angle in degrees in which you want to pan.
  • percentage
ToScreenCoordinate(Double,Double,Single,Single)
  • This method returns screen coordinates from the specified world coordinates, based on the CurrentExtent.
  • None
  • Description:This method returns screen coordinates from the specified world coordinates, based on the CurrentExtent.
  • worldX
    • Description:This parameter is the world point X you want converted to a screen point.
  • worldY
    • Description:This parameter is the world point Y you want converted to a screen point.
  • screenWidth
    • Type:Single
    • Description:This parameter is the width of the screen for the CurrentExtent.
  • screenHeight
    • Type:Single
    • Description:This parameter is the height of the screen for the CurrentExtent.
ToScreenCoordinate(PointShape,Single,Single)
  • None
  • worldPoint
    • Description:This parameter is the world point you want converted to a screen point.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ToScreenCoordinate(Feature,Single,Single)
  • This method returns screen coordinates from the specified world coordinate pointFeature, based on the CurrentExtent.
  • None
  • Description:This method returns screen coordinates from the specified world coordinate pointFeature, based on the CurrentExtent.
  • worldPointFeature
    • Type:Feature
    • Description:This parameter is the world coordinate pointFeature you want converted to a screen point.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ToWorldCoordinate(Single,Single,Single,Single)
  • This method returns world coordinates from screen coordinates, based on the CurrentExtent.
  • None
  • Description:This method returns world coordinates from screen coordinates, based on the CurrentExtent.
  • screenX
    • Type:Single
    • Description:This parameter is the X of the point you want converted to world coordinates.
  • screenY
    • Type:Single
    • Description:This parameter is the Y of the point you want converted to world coordinates.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ToWorldCoordinate(ScreenPointF,Single,Single)
  • None
  • screenPoint
    • Description:This parameter is the point you want converted to world coordinates.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
SnapToZoomLevel(GeographyUnit,Single,Single,ZoomLevelSet)
  • This method updates the CurrentExtent by snapping to a zoom level in the provided zoom level set.
  • None
  • Description:This method updates the CurrentExtent by snapping to a zoom level in the provided zoom level set.
  • worldExtentUnit
    • Description:This parameter is the geographic unit of the CurrentExtent.
  • screenWidth
    • Type:Single
    • Description:This parameter is the screen width.
  • screenHeight
    • Type:Single
    • Description:This parameter is the screen height.
  • zoomLevelSet
    • Description:This parameter is the set of zoom levels you want to snap to.
ZoomToScale(Double,GeographyUnit,Single,Single)
  • This method updates the CurrentExtent by zooming to a certain scale.
  • None
  • targetScale
    • Description:This parameter is the scale you want to zoom into.
  • worldExtentUnit
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
FindStaticFeatureLayer(String)
  • Finds a feature layer by key (specified in the “name” parameter) within the collection of StaticLayers.
  • Description:The corresponding FeatureLayer with the specified key in the MapControl.
  • name
    • Description:The key to find the final result feature layer.
FindStaticRasterLayer(String)
  • Find the raster layer by key (specified in the “name” parameter) within the collection of StaticLayers.
  • Description:The corresponding RasterLayer with the passing specified in the MapControl.
  • name
    • Description:The key to find the final result raster layer.
FindDynamicFeatureLayer(String)
  • Find the feature layer by key (specified in the “name” parameter) within the collection of DynamicLayers.
  • name
FindDynamicRasterLayer(String)
  • Find the raster layer by key (specified in the “name” parameter) within the collection of DynamicLayers.
  • Description:The corresponding RasterLayer with the specified key in the MapControl.
  • name
GetDrawingExtent(Single,Single)
  • This method returns an adjusted extent based on the ratio of the screen width and height.
  • This function is used because the extent to draw must be the rame ratio as the screen width and height. If they are not, then the image drawn will be stretched or compressed. We always adjust the extent upwards to ensure that no matter how we adjust it, the original extent will fit within the new extent. This ensures that everything you wanted to see in the first extent is visible and maybe a bit more.
  • Description:This method returns an adjusted extent based on the ratio of the screen width and height.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
OpenAllLayers()
  • This API allows you to open all of the layers (either static or dynamic).
CloseAllLayers()
  • This API allows you close all of the layers (either static or dynamic).
CenterAt(PointShape,Single,Single)
  • This is a function that allows you to pass a world point to center on and a height and width in screen units. The function will update the current extent by centering on the point and adjusting its ratio based on the height and width in screen coordinates.
  • This API will update the CurrentExtent.
  • Description:None.
  • worldPoint
    • Description:This parameter is the world point you want to center on.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
CenterAt(Feature,Single,Single)
  • This is a function that allows you to pass in a feature to center on, as well as a height and width in screen units. The function will center the CurrentExtent based on the specified feature and adjust its ratio based on the height and width in screen coordinates.
  • Description:None.
  • centerFeature
    • Type:Feature
    • Description:This parameter is the world point feature you want to center on.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
CenterAt(Single,Single,Single,Single)
  • This is a function that allows you to pass a screen point to center on and a height and width in screen units. The function will update the current extent by centering on the point and adjusting its ratio based on the height and width in screen coordinates.
  • screenX
    • Type:Single
    • Description:This parameter is the X coordinate on the screen to center on.
  • screenY
    • Type:Single
    • Description:This parameter is the Y coordinate on the screen to center on.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
GetScreenDistanceBetweenTwoWorldPoints(PointShape,PointShape,Single,Single)
  • This method returns the number of pixels between two world points using the CurrentExtent as reference.
  • None
  • Type:Single
  • Description:This method returns the number of pixels between two world points.
  • worldPoint1
    • Description:This parameter is the first point – the one you want to measure from.
  • worldPoint2
    • Description:This parameter is the second point – the one you want to measure to.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
GetScreenDistanceBetweenTwoWorldPoints(Feature,Feature,Single,Single)
  • None
  • Type:Single
  • worldPointFeature1
    • Type:Feature
    • Description:This parameter is the first pointFeture – the one you want to measure from.
  • worldPointFeature2
    • Type:Feature
    • Description:This parameter is the second pointFeature – the one you want to measure to.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
GetWorldDistanceBetweenTwoScreenPoints(ScreenPointF,ScreenPointF,Single,Single,GeographyUnit,DistanceUnit)
  • This method returns the distance in world units between two screen points by using the CurrentExtent as a reference.
  • None
  • Description:This method returns the distance in world units between two screen points.
  • screenPoint1
    • Description:This is the screen point you want to measure from.
  • screenPoint2
    • Description:This is the screen point you want to measure to.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
  • mapUnit
  • distanceUnit
    • Description:This is the geographic unit you want the result to show in.
GetCurrentScale(Single,GeographyUnit)
  • Get the current Scale responding to the CurrentExtent.
  • Description:The calculated scale based on the CurrentExtent.
  • screenWidth
    • Type:Single
    • Description:This parameter specifies the screen width responding to the CurrentExtent.
  • mapUnit
Draw(IEnumerable<Layer>,GeoImage,GeographyUnit)
  • Draw a group of layers on the specified “background” image.
  • Type:GeoImage
  • Description:The resulting image after drawing the target layers on the specified “background” image.
  • layers
    • Type:IEnumerable<Layer>
    • Description:This parameter specifies the target layers to be drawn.
  • image
    • Type:GeoImage
    • Description:This parameter specifies the “background” image of the returning image.
  • mapUnit
Draw(IEnumerable<Layer>,Int32,Int32,GeographyUnit)
  • Draw a group of layers and return a new image with the specified width and height.
  • Type:GeoImage
  • Description:The resulting image after drawing the target layers based on the specified width and height.
  • layers
  • width
  • height
  • mapUnit
DrawStaticLayers(GeoImage,GeographyUnit)
  • Draw a group of static layers on the specified “background” image.
  • Type:GeoImage
  • Description:The resulting image after drawing the group of static layers on the specified “background” image.
  • image
    • Type:GeoImage
  • mapUnit
DrawDynamicLayers(GeoImage,GeographyUnit)
  • Draw a group of dynamic layers on the specified “background” image.
  • Type:GeoImage
  • Description:The resulting image after drawing the group of dynamic layers on the specified “background” image.
  • image
    • Type:GeoImage
  • mapUnit
DrawAdornmentLayers(GeoImage,GeographyUnit)
  • Draw a group of AdornmentLayers on the specified “background” image.
  • Type:GeoImage
  • Description:The resulting image after drawing the group of AdornmentLayers on the specified “background” image.
  • image
    • Type:GeoImage
  • mapUnit
ZoomIn(RectangleShape,Int32)
  • This method returns a new extent that is zoomed in by the percentage provided.
  • None
  • Description:This method returns a new extent that is zoomed in by the percentage provided.
  • worldExtent
    • Description:This parameter is the world extent you want to zoom.
  • percentage
ZoomIntoCenter(RectangleShape,Int32,PointShape,Single,Single)
  • worldExtent
    • Description:This parameter is the world extent that you want centered and zoomed.
  • percentage
  • worldPoint
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ZoomIntoCenter(RectangleShape,Int32,Feature,Single,Single)
  • None
  • worldExtent
  • percentage
  • centerFeature
    • Type:Feature
    • Description:This parameter is the world point feature you want the extent to be centered on.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ZoomIntoCenter(RectangleShape,Int32,Single,Single,Single,Single)
  • worldExtent
    • Description:This parameter is the world extent you want to center and zoom.
  • percentage
  • screenX
    • Type:Single
  • screenY
    • Type:Single
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ZoomOut(RectangleShape,Int32)
  • This method returns a new extent that is zoomed out by the percentage provided.
  • None
  • Description:This method returns a new extent that is zoomed out by the percentage provided.
  • worldExtent
  • percentage
ZoomOutToCenter(RectangleShape,Int32,PointShape,Single,Single)
  • This method returns an extent that is centered and zoomed out.
  • Description:This method returns an extent that is centered and zoomed out.
  • worldExtent
  • percentage
  • worldPoint
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ZoomOutToCenter(RectangleShape,Int32,Feature,Single,Single)
  • worldExtent
  • percentage
  • centerFeature
    • Type:Feature
    • Description:This parameter is the feature you want the extent to be centered on.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ZoomOutToCenter(RectangleShape,Int32,Single,Single,Single,Single)
  • worldExtent
  • percentage
  • screenX
    • Type:Single
  • screenY
    • Type:Single
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
Pan(RectangleShape,PanDirection,Int32)
  • This method returns a panned extent.
  • None
  • Description:This method returns a panned extent.
  • worldExtent
    • Description:This parameter is the world extent you want to pan.
  • direction
  • percentage
Pan(RectangleShape,Single,Int32)
  • None
  • worldExtent
  • degree
    • Type:Single
  • percentage
ToScreenCoordinate(RectangleShape,Double,Double,Single,Single)
  • This method returns screen coordinates from world coordinates.
  • None
  • Description:This method returns screen coordinates from world coordinates.
  • worldExtent
  • worldX
    • Description:This parameter is the world X you want converted to screen points.
  • worldY
    • Description:This parameter is the world Y you want converted to screen points.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ToScreenCoordinate(RectangleShape,PointShape,Single,Single)
  • None
  • worldExtent
  • worldPoint
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ToScreenCoordinate(RectangleShape,Feature,Single,Single)
  • None
  • worldExtent
  • worldPointFeature
    • Type:Feature
    • Description:This parameter is the world point feature you want converted to a screen point.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ToWorldCoordinate(RectangleShape,Single,Single,Single,Single)
  • This method returns world coordinates from screen coordinates.
  • None
  • Description:This method returns world coordinates from screen coordinates.
  • worldExtent
  • screenX
    • Type:Single
    • Description:This parameter is the X coordinate of the point you want converted to world coordinates.
  • screenY
    • Type:Single
    • Description:This parameter is the Y coordinate of the point you want converted to world coordinates.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
ToWorldCoordinate(RectangleShape,ScreenPointF,Single,Single)
  • None
  • worldExtent
  • screenPoint
    • Description:This parameter is the screen point you want converted to a world point.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
SnapToZoomLevel(RectangleShape,GeographyUnit,Single,Single,ZoomLevelSet)
  • This method returns an extent that is snapped to a zoom level in the provided zoom level set.
  • None
  • Description:This method returns an extent that is snapped to a zoom level in the provided zoom level set.
  • worldExtent
    • Description:This parameter is the world extent you want snapped.
  • worldExtentUnit
    • Description:This parameter is the geographic unit of the world extent parameter.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
  • zoomLevelSet
ZoomToScale(Double,RectangleShape,GeographyUnit,Single,Single)
  • This method returns a extent that has been zoomed into a certain scale.
  • None
  • Description:This method returns a extent that has been zoomed into a certain scale.
  • targetScale
  • worldExtent
    • Description:This parameter is the world extent you want zoomed into the scale.
  • worldExtentUnit
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
GetVersion()
  • Get the current MapSuiteCore.dll file version.
  • Description:A string representing the file version of MapSuiteCore.dll.
GetDrawingExtent(RectangleShape,Single,Single)
  • This function is used because the extent to draw must be the rame ratio as the screen width and height. If they are not, then the image drawn will be stretched or compressed. We always adjust the extent upwards to ensure that no matter how we adjust it, the original extent will fit within the new extent. This ensures that everything you wanted to see in the first extent is visible and maybe a bit more. This function takes a height and width in screen coordinates, then looks at a world extent passed, and returns an adjusted world rectangle so that the ratio to height and width in screen and world coordinates match.
  • worldExtent
    • Description:This parameter is the world extent you want to adjust for drawing.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
CenterAt(RectangleShape,PointShape,Single,Single)
  • This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
  • None
  • Description:This method returns an adjusted extent centered on a point.
  • worldExtent
    • Description:This parameter is the current extent you want to center.
  • worldPoint
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
CenterAt(RectangleShape,Feature,Single,Single)
  • None
  • worldExtent
  • centerFeature
    • Type:Feature
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
CenterAt(RectangleShape,Single,Single,Single,Single)
  • This is a static function that allows you to pass in a world rectangle, a point in screen coordinates to center on, and a height and width in screen units. The function will center the rectangle based on the screen point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
  • None
  • worldExtent
  • screenX
    • Type:Single
    • Description:This parameter is the X coordinate on the screen to center to.
  • screenY
    • Type:Single
    • Description:This parameter is the Y coordinate on the screen to center to.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape,PointShape,PointShape,Single,Single)
  • This method returns the number of pixels between two world points.
  • None
  • Type:Single
  • worldExtent
  • worldPoint1
  • worldPoint2
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape,Feature,Feature,Single,Single)
  • None
  • Type:Single
  • worldExtent
    • Type:Feature
    • Description:This parameter is the first point Feature – the one you want to measure from.
    • Type:Feature
    • Description:This parameter is the second point Feature – the one you want to measure to.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape,ScreenPointF,ScreenPointF,Single,Single,GeographyUnit,DistanceUnit)
  • This method returns the distance in world units between two screen points.
  • None
  • Description:This method returns the distance in wold units between two screen points.
  • worldExtent
  • screenPoint1
  • screenPoint2
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
  • worldExtentUnit
    • Description:This is the geographic unit of the world extent rectangle.
  • distanceUnit
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape,Single,Single,Single,Single,Single,Single,GeographyUnit,DistanceUnit)
  • This method returns the distance in wold units between two screen points.
  • worldExtent
  • screenPoint1X
    • Type:Single
    • Description:This parameter is the X of the point you want to measure from.
  • screenPoint1Y
    • Type:Single
    • Description:This parameter is the Y of the point you want to measure from.
  • screenPoint2X
    • Type:Single
    • Description:This parameter is the X of the point you want to measure to.
  • screenPoint2Y
    • Type:Single
    • Description:This parameter is the Y of the point you want to measure to.
  • screenWidth
    • Type:Single
  • screenHeight
    • Type:Single
  • worldExtentUnit
    • Description:This is the geographic unit of the world extent you passed in.
  • distanceUnit
GetCurrentScale(RectangleShape,Single,GeographyUnit)
  • This Static API is used to calculate the scale based on the specified worldExtent and its corresponding ScreenWidth and MapUnit.
  • worldExtent
    • Description:This parameter specifies the worldExtent used to calculate the current scale.
  • screenWidth
    • Type:Single
    • Description:This parameter specifies the screenWidth corresponding to the worldExtent.
  • mapUnit
    • Description:This parameter specifies the unit for the extent, the result will be different if choose DecimalDegree as Unit and Meter as Unit.
GetBoundingBoxOfItems(IEnumerable<BaseShape>)
  • This API gets the BoundingBox of a group of BaseShapes.
  • Description:The BoundingBox that contains all the shapes you passed in.
  • shapes
    • Type:IEnumerable<BaseShape>
    • Description:The target group of BaseShapes to get the BoundingBox for.
GetBoundingBoxOfItems(IEnumerable<Feature>)
  • This API gets the BoundingBox of a group of Features.
  • Description:The BoundingBox that contains all the features you passed in.
  • features
    • Type:IEnumerable<Feature>
    • Description:The target group of Features to get the BoundingBox for.
OnAdornmentLayersDrawing(AdornmentLayersDrawingEventArgs)
  • This event is raised before AdornmentLayers are drawn.
OnAdornmentLayersDrawn(AdornmentLayersDrawnEventArgs)
  • This event is raised after AdornmentLayers are drawn.
OnAdornmentLayerDrawing(AdornmentLayerDrawingEventArgs)
  • This event is raised before an AdornmentLayer is drawn.
OnAdornmentLayerDrawn(AdornmentLayerDrawnEventArgs)
  • This event is raised after an AdornmentLayer is drawn.
OnLayersDrawing(LayersDrawingEventArgs)
  • This event is raised before Layers are drawn.
OnLayersDrawn(LayersDrawnEventArgs)
  • This event is raised after Layers are drawn.
OnLayerDrawing(LayerDrawingEventArgs)
  • This event is raised before a Layer is drawn.
OnLayerDrawn(LayerDrawnEventArgs)
  • This event is raised after a Layer is drawn.
Canvas
  • Gets and sets the GeoCanvas used to draw the Layers.
ShowLogo
  • This property specifies whether the logo is shown on the Map or not.
AdornmentLayers
  • This property holds a collection of AdornmentLayers to be drawn on the MapEngine.
  • This collection of Layers StaticLayers will be drawn when calling the DrawAdornmentLayers API.
CurrentExtent
  • This property gets or sets the current extent of the MapEngine.
  • The current extent is the rectangle that is currently being shown on the MapEngine.
StaticLayers
  • This property holds a group of Layers to be drawn on the MapEngine.
  • This collection of Layers StaticLayers will be drawn when calling the DrawStaticLayers API.
DynamicLayers
  • This collection of Layers StaticLayers will be drawn when calling the DrawDynamicLayers API.
BackgroundFillBrush
  • Gets or sets the GeoBrush for the background of the MapEngine.
LayersDrawing
Event Arguments:LayersDrawingEventArgs
LayersDrawn
Event Arguments:LayersDrawnEventArgs
LayerDrawing
Event Arguments:LayerDrawingEventArgs
LayerDrawn
Event Arguments:LayerDrawnEventArgs
Event Arguments:AdornmentLayersDrawingEventArgs
Event Arguments:AdornmentLayersDrawnEventArgs
Event Arguments:AdornmentLayerDrawingEventArgs
AdornmentLayerDrawn
Event Arguments:AdornmentLayerDrawnEventArgs
thinkgeo.mapsuite.portablecore.mapengine.txt · Last modified: 2017/03/16 21:59 (external edit)
