thinkgeo.mapsuite.portablecore.geometrycollectionshape
ThinkGeo.MapSuite.Core.GeometryCollectionShape
    • ThinkGeo.MapSuite.Core.BaseShape
      • ThinkGeo.MapSuite.Core.GeometryCollectionShape
GeometryCollectionShape()
  • This constructor creates the GeometryCollectionShape.
  • None
GeometryCollectionShape(IEnumerable<BaseShape>)
  • baseShapes
    • Type:IEnumerable<BaseShape>
GeometryCollectionShape(IEnumerable<Feature>)
  • features
    • Type:IEnumerable<Feature>
GeometryCollectionShape(String)
  • None
  • wellKnownText
GeometryCollectionShape(Byte[])
  • None
  • wellKnownBinary
    • Type:Byte[]
GetIntersection(BaseShape)
Union(BaseShape)
Union(IEnumerable<BaseShape>)
  • targetShape
GetDifference(BaseShape)
GetSymmetricalDifference(BaseShape)
GetConvexHull()
  • tolerance
  • tolerance
Touches(BaseShape)
Touches(Feature)
  • targetFeature
Crosses(BaseShape)
Crosses(Feature)
  • targetFeature
IsWithin(BaseShape)
IsWithin(Feature)
  • targetFeature
Contains(BaseShape)
Contains(Feature)
  • targetFeature
Overlaps(BaseShape)
Overlaps(Feature)
  • targetFeature
IsTopologicallyEqual(Feature)
  • targetFeature
GetFeature()
  • columnValues
GetCrossing(BaseShape)
ScaleTo(Double)
  • scale
LoadFromWellKnownData(String)
  • wellKnownText
GetWellKnownText()
GetGeoJson()
GetWellKnownText(RingOrder)
  • outerRingOrder
LoadFromWellKnownData(Byte[])
  • wellKnownBinary
    • Type:Byte[]
GetWellKnownBinary()
  • Type:Byte[]
  • Type:Byte[]
GetWellKnownBinary(RingOrder)
  • Type:Byte[]
  • outerRingOrder
GetWellKnownBinary(RingOrder,WkbByteOrder)
  • Type:Byte[]
  • outerRingOrder
GetBoundingBox()
GetWellKnownType()
CloneDeep()
  • xOffsetDistance
  • yOffsetDistance
  • xOffsetDistance
  • yOffsetDistance
  • distance
  • angleInDegrees
  • distance
  • angleInDegrees
Rotate(PointShape,Single)
  • degreeAngle
    • Type:Single
  • targetFeature
  • targetFeature
GetCenterPoint()
  • distance
  • distance
  • quadrantSegments
  • distance
  • quadrantSegments
  • targetFeature
  • fromPoint
  • toPoint
Validate(ShapeValidationMode)
IsDisjointed(BaseShape)
IsDisjointed(Feature)
  • targetFeature
Intersects(BaseShape)
Intersects(Feature)
  • targetFeature
  • wellKnownBinary
    • Type:Byte[]
  • wellKnownText
  • outerRingOrder
  • Type:Byte[]
  • outerRingOrder
GetWellKnownTypeCore()
GetCrossingCore(BaseShape)
GetBoundingBoxCore()
  • distance
  • quadrantSegments
IsDisjointedCore(BaseShape)
IntersectsCore(BaseShape)
TouchesCore(BaseShape)
IsWithinCore(BaseShape)
GetIntersectionCore(BaseShape)
UnionCore(IEnumerable<BaseShape>)
  • targetShape
GetDifferenceCore(BaseShape)
GetSymmetricalDifferenceCore(BaseShape)
GetConvexHullCore()
  • tolerance
CrossesCore(BaseShape)
ContainsCore(BaseShape)
OverlapsCore(BaseShape)
ScaleToCore(Double)
  • scale
GetGeoJsonCore()
CloneDeepCore()
  • xOffsetDistance
  • yOffsetDistance
  • distance
  • angleInDegrees
RotateCore(PointShape,Single)
  • degreeAngle
    • Type:Single
GetCenterPointCore()
UnionIncludeGeometryCollections(IEnumerable<BaseShape>)
  • shapes
Shapes
Id
Tag
CanRotate
thinkgeo.mapsuite.portablecore.geometrycollectionshape.txt · Last modified: 2017/03/16 21:59 (external edit)
