thinkgeo.mapsuite.mvcedition.maptools
ThinkGeo.MapSuite.MvcEdition.MapTools
<!– Class –> Contains the different map tools as properties and acts as an entrance for setting these map controls.
This class is designed to be easy to use. It contains all the available tools of the map. You can find and set those map tools easily by using this class.
Public MethodMapTools Initialize an instance of the MapTools class.
Public MethodFromJson String Load this object from a json string.
Public MethodGetType Object
Public MethodToJson Returns a JSON string that contains all of the map tools settings.
Public MethodToString Object
Public PropertyAnimationPanMapTool AnimationPanMapTool Gets an AnimationPanMapTool object for setting.
Public PropertyKeyboardMapTool KeyboardMapTool Gets a KeyboardMapTool object for setting.
Public PropertyLoadingImage LoadingImageMapTool Gets a LoadingImageMapTool object for setting
Public PropertyLogo LogoMapTool Gets a LogoMapTool object for setting
Public PropertyMeasureMapTool MeasureMapTool Gets an MeasureMapTool object for setting.
Public PropertyMiniMap MiniMapMapTool Gets a MiniMapMapTool object for setting.
Public PropertyMouseCoordinate MouseCoordinateMapTool Gets a MouseCoordinateMapTool object for setting.
Public PropertyMouseMapTool MouseMapTool Gets a MouseMapTool object for setting.
Public PropertyOverlaySwitcher OverlaySwitcherMapTool Gets an OverlaySwitcherMapTool object for setting.
Public PropertyPanZoom PanZoomMapTool Gets a PanZoomMapTool object for setting.
Public PropertyPanZoomBar PanZoomBarMapTool Gets a PanZoomBarMapTool object for setting.
Public PropertyScaleLine ScaleLineMapTool Gets a ScaleLineMapTool object for setting.
Public PropertyTouchMapTool TouchMapTool Gets an TouchMapTool object for setting
MapTools()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –> a json string
<!– ThinkGeo.MapSuite.MvcEdition.MapTools –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
This method is used to generate the JSON string for all of the map controls. The JSON string will be sent to the client side to create corresponding client-side map controls.
String<!– System.String –> A JSON string that represents the settings for all of the map tools.
AnimationPanMapTool
Return Type
AnimationPanMapTool<!– ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool –>
KeyboardMapTool
Return Type
KeyboardMapTool<!– ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool –>
LoadingImage
Return Type
LoadingImageMapTool<!– ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool –>
Return Type
LogoMapTool<!– ThinkGeo.MapSuite.MvcEdition.LogoMapTool –>
MeasureMapTool
Return Type
MeasureMapTool<!– ThinkGeo.MapSuite.MvcEdition.MeasureMapTool –>
MiniMap
Return Type
MiniMapMapTool<!– ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool –>
MouseCoordinate
Return Type
MouseCoordinateMapTool<!– ThinkGeo.MapSuite.MvcEdition.MouseCoordinateMapTool –>
MouseMapTool
Return Type
MouseMapTool<!– ThinkGeo.MapSuite.MvcEdition.MouseMapTool –>
OverlaySwitcher
Return Type
OverlaySwitcherMapTool<!– ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapTool –>
PanZoom
Return Type
PanZoomMapTool<!– ThinkGeo.MapSuite.MvcEdition.PanZoomMapTool –>
PanZoomBar
Return Type
PanZoomBarMapTool<!– ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool –>
ScaleLine
Return Type
ScaleLineMapTool<!– ThinkGeo.MapSuite.MvcEdition.ScaleLineMapTool –>
TouchMapTool
Return Type
TouchMapTool<!– ThinkGeo.MapSuite.MvcEdition.TouchMapTool –>
thinkgeo.mapsuite.mvcedition.maptools.1440040131.txt.gz · Last modified: 2015/09/21 03:34 (external edit)
