thinkgeo.mapsuite.mvcedition.mapbuilder
ThinkGeo.MapSuite.MvcEdition.MapBuilder
Defines the fluent interface for configuring the Map control.
MapBuilder(Map)
  • Initializes a new instance of the MapBuilder.
  • map
    • Type:Map
    • Description:The map control instance.
MapBuilder(Map,ViewContext)
  • map
    • Type:Map
  • viewContext
    • Type:ViewContext
    • Description:The ViewContext of the page.
ZoomLevelSet(ZoomLevelSet)
  • Sets the ZoomLevelSet applied to the map.
  • zoomLevelSet
    • Description:ZoomLevels that will be applied to map.
MapBackground(BackgroundLayer)
  • Sets the BackgroundLayer object that paints the map background.
  • backgroundLayer
ContextMenu(Action<ContextMenuSetting>)
  • Sets the ContextMenu of the map.
CurrentExtent(Double,Double,Double,Double)
  • Sets the current extent of the map.
  • minX
    • Description:This property specifies the minimum X value. This is also the upper left X.
  • maxY
    • Description:This property specifies the maximum Y value. This is also the upper left Y.
  • maxX
    • Description:This property specifies the maximum X value. This is also the lower right X.
  • minY
    • Description:This property specifies the minimum Y value. This is also the lower right Y.
Cursor(CursorType)
  • Sets the cursor that appears when the mouse pointer is over the map control.
  • cursorType
    • Description:The type of the cursor that appears when the pointer moves over the map.
WebConfigRegisterMode(WebConfigRegistrationMode)
  • Sets a value that indicates whether the application allows map to register the Web.config on the fly in runtime. The default value is “WebConfigRegisterMode.AutoRegistered”, otherwise, you need to copy the code below to the web.config manually.
  • webConfigRegisterMode
    • Description:The register mode that indicates whether the application allows map to register the Web.config on the fly in runtime.
ResourceDeploymentMode(ResourceDeploymentMode)
  • sets a value that indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “ResourceDeploymentMode.Automatically”, otherwise, you need to copy images to the directory.
  • resourceDeploymentMode
    • Description:The depolymentMode indicates whether the control creates and releases the theme files to application folder automatically.
IsDefaultJavascriptLibraryDisabled(Boolean)
  • Gets or sets whether the default javascript library is disabled or not.
  • disabled
MapUnit(GeographyUnit)
  • Sets the GeographyUnit of the map.
  • mapUnit
ActiveBaseOverlay(Overlay)
  • Sets the active base Overlay.
  • The map can contain multiple base Overlays, though only one of them can be displayed at a time. The ActiveBaseOverlay property specifies the one that is currently displayed. When you switch the base Overlays in the OverSwitcher, the currently selected overlay will be synchronized to this property after postback.
  • overlay
    • Type:Overlay
    • Description:The overlay selected from the overlay's collection.
BackgroundOverlay(Overlay)
  • Sets an Overlay object that displays as the background map by default.
  • overlay
    • Type:Overlay
    • Description:A LayerOverlay object that displays as the background map by default.
StaticOverlay(Action<LayerOverlaySetting>)
  • Configures a LayerOverlay object that displays as a background map.
  • configOverlayAction
DynamicOverlay(Action<LayerOverlaySetting>)
  • Configures a LayerOverlay object that can overlap other overlays.
MarkerOverlay(Action<InMemoryMarkerOverlaySetting>)
  • Configures an InMemoryMarkerOverlay object that renders markers by the specified features.
EditOverlay(Action<EditFeatureOverlaySetting>)
  • Configures an EditOverlay object, with which you can draw and edit shapes on client side.
HighlightOverlay(Action<HighlightFeatureOverlaySetting>)
  • Configures a HighlightFeatureOverlay object, which draws its features on client side and can attach the specified click event and context menu to them.
AdornmentOverlay(Action<AdornmentOverlaySetting>)
  • Configures a AdormentOverlay object in the map control.
  • configAdormentOverlaySettingAction
MapTools(Action<MapToolsSettingCollection>)
  • Configures the MapTools in the map control.
CurrentScale(Double)
  • Sets the current scale of the map.
  • scale
    • Description:scale value.
CustomOverlays(Action<OverlayCollection>)
  • Configures the Overlays added to the map.
  • addOverlayAction
Popups(Action<PopupCollection>)
  • Sets the popups of the map.
  • addPopupAction
RestrictedExtent(RectangleShape)
  • Sets an extent that limits the area to which the map can be navigated within.
OnClientDrawEnd(String)
  • Sets the ClientDrawEnd event of the map.
  • clientDrawEnd
    • Description:The JavaScript function name.
OnClientEditEnd(String)
  • Sets the ClientEditEnd event of the map.
  • clientEditEnd
OnClientClick(String)
  • Sets the client click event of the map.
  • clientClick
OnClientExtentChanged(String)
  • Sets the ClientExtentChanged event of the map.
  • clientExtentChanged
OnClientBaseOverlayChanged(String)
  • Sets the ClientBaseOverlayChanged event of the map.
  • clientBaseOverlayChanged
OnClientDoubleClick(String)
  • Sets the ClientDoubleClick event of the map.
  • clientDoubleClick
OnClientTrackShapeFinished(String)
  • Sets the OnClientTrackShapeFinished event of the map.
  • clientTrackShapeFinishedEventHandler
OnClientPopupsRequesting(String)
  • clientPopupsRequestingEventHandler
OnClientPopupsRequested(String)
  • clientPopupsRequestedEventHandler
Render()
  • Sends the map control content to a provided HtmlTextWriter object, which wirtes the content to be rendered on the client.
Name(String)
  • name
HtmlAttributes(Dictionary<String,String>)
  • htmlAttributes
ScriptFileNames(Dictionary<String,String>)
  • scriptFileNames
ScriptBlocks(Dictionary<String,String>)
  • scriptBlocks
StyleSheetFileNames(IEnumerable<String>)
  • cssFileNames
    • Type:IEnumerable<String>
Control
thinkgeo.mapsuite.mvcedition.mapbuilder.1442910904.txt.gz · Last modified: 2015/09/22 08:35 by admin
