<!– Class –> Defines the fluent interface for configuring the Map control.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.MapBuilder * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcControlBuilderBase`2[[ThinkGeo.MapSuite.MvcEdition.Map ThinkGeo.MapSuite.MvcEdition.MapBuilder
MapBuilder | Map | Initializes a new instance of the MapBuilder. | |
MapBuilder | Map, ViewContext | Initializes a new instance of the MapBuilder. |
ActiveBaseOverlay | Overlay | Sets the active base Overlay. | |
AdornmentOverlay | Action<AdornmentOverlaySetting> | Configures a AdormentOverlay object in the map control. | |
BackgroundOverlay | Overlay | Sets an Overlay object that displays as the background map by default. | |
ContextMenu | Action<ContextMenuSetting> | Sets the ContextMenu of the map. | |
CurrentExtent | Double, Double, Double, Double | Sets the current extent of the map. | |
CurrentScale | Double | Sets the current scale of the map. | |
Cursor | CursorType | Sets the cursor that appears when the mouse pointer is over the map control. | |
CustomOverlays | Action<OverlayCollection> | Configures the Overlays added to the map. | |
DynamicOverlay | Action<LayerOverlaySetting> | Configures a LayerOverlay object that can overlap other overlays. | |
EditOverlay | Action<EditFeatureOverlaySetting> | Configures an EditOverlay object, with which you can draw and edit shapes on client side. | |
HighlightOverlay | Action<HighlightFeatureOverlaySetting> | Configures a HighlightFeatureOverlay object, which draws its features on client side and can attach the specified click event and context menu to them. | |
HtmlAttributes | Dictionary<String, String> | MvcControlBuilderBase<Map,MapBuilder> | |
IsDefaultJavascriptLibraryDisabled | Boolean | Gets or sets whether the default javascript library is disabled or not. | |
MapBackground | BackgroundLayer | Sets the BackgroundLayer object that paints the map background. | |
MapTools | Action<MapToolsSettingCollection> | Configures the MapTools in the map control. | |
MapUnit | GeographyUnit | Sets the GeographyUnit of the map. | |
MarkerOverlay | Action<InMemoryMarkerOverlaySetting> | Configures an InMemoryMarkerOverlay object that renders markers by the specified features. | |
Name | String | MvcControlBuilderBase<Map,MapBuilder> | |
OnClientBaseOverlayChanged | String | Sets the ClientBaseOverlayChanged event of the map. | |
OnClientClick | String | Sets the client click event of the map. | |
OnClientDoubleClick | String | Sets the ClientDoubleClick event of the map. | |
OnClientDrawEnd | String | Sets the ClientDrawEnd event of the map. | |
OnClientEditEnd | String | Sets the ClientEditEnd event of the map. | |
OnClientExtentChanged | String | Sets the ClientExtentChanged event of the map. | |
OnClientPopupsRequested | String | ||
OnClientPopupsRequesting | String | ||
OnClientTrackShapeFinished | String | Sets the OnClientTrackShapeFinished event of the map. | |
Popups | Action<PopupCollection> | Sets the popups of the map. | |
Render | Sends the map control content to a provided HtmlTextWriter object, which wirtes the content to be rendered on the client. | ||
ResourceDeploymentMode | ResourceDeploymentMode | sets a value that indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “ResourceDeploymentMode.Automatically”, otherwise, you need to copy images to the directory. | |
RestrictedExtent | RectangleShape | Sets an extent that limits the area to which the map can be navigated within. | |
ScriptBlocks | Dictionary<String, String> | MvcControlBuilderBase<Map,MapBuilder> | |
ScriptFileNames | Dictionary<String, String> | MvcControlBuilderBase<Map,MapBuilder> | |
StaticOverlay | Action<LayerOverlaySetting> | Configures a LayerOverlay object that displays as a background map. | |
StyleSheetFileNames | IEnumerable<String> | MvcControlBuilderBase<Map,MapBuilder> | |
ToString | Object(overriden) | ||
WebConfigRegisterMode | WebConfigRegistrationMode | Sets a value that indicates whether the application allows map to register the Web.config on the fly in runtime. The default value is “WebConfigRegisterMode.AutoRegistered”, otherwise, you need to copy the code below to the web.config manually. | |
ZoomLevelSet | ZoomLevelSet | Sets the ZoomLevelSet applied to the map. |
Control | Map | MvcControlBuilderBase<Map,MapBuilder> |
| map | Map<!– ThinkGeo.MapSuite.MvcEdition.Map –> | The map control instance. |
| viewContext | ViewContext<!– System.Web.Mvc.ViewContext –> | The ViewContext of the page. |
The map can contain multiple base Overlays, though only one of them can be displayed at a time. The ActiveBaseOverlay property specifies the one that is currently displayed. When you switch the base Overlays in the OverSwitcher, the currently selected overlay will be synchronized to this property after postback.
| MapBuilder<!– ThinkGeo.MapSuite.MvcEdition.MapBuilder –> |
| overlay | Overlay<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> | The overlay selected from the overlay's collection. |
<!– ThinkGeo.MapSuite.MvcEdition.MapBuilder –> Go Back
| configAdormentOverlaySettingAction | Action<AdornmentOverlaySetting><!– System.Action{ThinkGeo.MapSuite.MvcEdition.AdornmentOverlaySetting} –> | The AdormentOverlay configuration action. |
| overlay | Overlay<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> | A LayerOverlay object that displays as the background map by default. |
| addContextMenuAction | Action<ContextMenuSetting><!– System.Action{ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting} –> | The action. |
| minX | Double<!– System.Double –> | This property specifies the minimum X value. This is also the upper left X. |
| maxY | Double<!– System.Double –> | This property specifies the maximum Y value. This is also the upper left Y. |
| maxX | Double<!– System.Double –> | This property specifies the maximum X value. This is also the lower right X. |
| minY | Double<!– System.Double –> | This property specifies the minimum Y value. This is also the lower right Y. |
| scale | Double<!– System.Double –> | scale value. |
| cursorType | CursorType<!– ThinkGeo.MapSuite.MvcEdition.CursorType –> | The type of the cursor that appears when the pointer moves over the map. |
| addOverlayAction | Action<OverlayCollection><!– System.Action{ThinkGeo.MapSuite.MvcEdition.OverlayCollection} –> | CustomOverlay setting action. |
| configOverlayAction | Action<LayerOverlaySetting><!– System.Action{ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting} –> | Overlay configuration action. |
| configEditOverlayAction | Action<EditFeatureOverlaySetting><!– System.Action{ThinkGeo.MapSuite.MvcEdition.EditFeatureOverlaySetting} –> | The editOvelay configuration action. |
| configHighlightOverlayAction | Action<HighlightFeatureOverlaySetting><!– System.Action{ThinkGeo.MapSuite.MvcEdition.HighlightFeatureOverlaySetting} –> | The HighlightFeatureOverlay configuration action. |
| htmlAttributes | Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
<!– ThinkGeo.MapSuite.MvcEdition.MvcControlBuilderBase{ThinkGeo.MapSuite.MvcEdition.Map,ThinkGeo.MapSuite.MvcEdition.MapBuilder} –> Go Back
| disabled | Boolean<!– System.Boolean –> |
| backgroundLayer | BackgroundLayer<!– ThinkGeo.MapSuite.Core.BackgroundLayer –> | BackgroundLayer of the map. |
| mapToolsSettingAction | Action<MapToolsSettingCollection><!– System.Action{ThinkGeo.MapSuite.MvcEdition.MapToolsSettingCollection} –> | MapTools configuration action. |
| mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | GeographyUnit of the map. |
| configMarkerOverlayAction | Action<InMemoryMarkerOverlaySetting><!– System.Action{ThinkGeo.MapSuite.MvcEdition.InMemoryMarkerOverlaySetting} –> | The InMemoryMarkerOverlay configuration action. |
| name | String<!– System.String –> |
| clientBaseOverlayChanged | String<!– System.String –> | The JavaScript function name. |
| clientClick | String<!– System.String –> | The JavaScript function name. |
| clientDoubleClick | String<!– System.String –> | The JavaScript function name. |
| clientDrawEnd | String<!– System.String –> | The JavaScript function name. |
| clientEditEnd | String<!– System.String –> | The JavaScript function name. |
| clientExtentChanged | String<!– System.String –> | The JavaScript function name. |
| clientPopupsRequestedEventHandler | String<!– System.String –> |
| clientPopupsRequestingEventHandler | String<!– System.String –> |
| clientTrackShapeFinishedEventHandler | String<!– System.String –> | The JavaScript function name. |
| addPopupAction | Action<PopupCollection><!– System.Action{ThinkGeo.MapSuite.MvcEdition.PopupCollection} –> | Popup setting action. |
| resourceDeploymentMode | ResourceDeploymentMode<!– ThinkGeo.MapSuite.MvcEdition.ResourceDeploymentMode –> | The depolymentMode indicates whether the control creates and releases the theme files to application folder automatically. |
| extent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| scriptBlocks | Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
| scriptFileNames | Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
| cssFileNames | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> |
| webConfigRegisterMode | WebConfigRegistrationMode<!– ThinkGeo.MapSuite.MvcEdition.WebConfigRegistrationMode –> | The register mode that indicates whether the application allows map to register the Web.config on the fly in runtime. |
| zoomLevelSet | ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> | ZoomLevels that will be applied to map. |
