<!– Class –> This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.iOSEdition.Overlay *ThinkGeo.MapSuite.iOSEdition.InteractiveOverlay ThinkGeo.MapSuite.iOSEdition.ExtentInteractiveOverlay
ExtentInteractiveOverlay | Initializes a new instance of the class. |
CloseCore | Overlay | Closes the core. | |
Dispose | Boolean | Overlay(overriden) | |
DoubleTapCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the DoubleTap logic in its base class InterativeOverlay. |
DrawCore | MapArguments, OverlayRefreshType | Overlay(overriden) | |
DrawException | GeoCanvas, Exception | Overlay | Draws the exception. |
DrawExceptionCore | GeoCanvas, Exception | Overlay | Draws the exception core. |
Finalize | Object(overriden) | ||
GetBoundingBoxCore | Overlay | Gets the bounding box core. | |
InitializeCore | MapArguments | Overlay(overriden) | |
LongPressCore | InteractionArguments | InteractiveOverlay | Longs the press core. |
MemberwiseClone | Object | ||
OnDrawingException | DrawingExceptionOverlayEventArgs | Overlay | Handles the event. |
OnDrawnException | DrawnExceptionOverlayEventArgs | Overlay | Handles the event. |
PostTransformCore | TransformArguments, MapArguments | Overlay(overriden) | |
RefreshCore | Overlay | Refreshes the core. | |
SingleTapCore | InteractionArguments | InteractiveOverlay | Singles the tap core. |
TouchDownCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the TouchDown logic in its base class InterativeOverlay. |
TouchMoveCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the TouchMove logic in its base class InterativeOverlay. |
TouchPointerDownCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the TouchPointerDown logic in its base class InterativeOverlay. |
TouchUpCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the TouchUp logic in its base class InterativeOverlay. |
Attribution | String | Overlay | Gets or sets the attribution. |
DoubleTapMode | MapDoubleTapMode | Gets or sets the double tap mode. | |
DrawingExceptionMode | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
DrawingQuality | DrawingQuality | Overlay | Gets or sets the drawing quality. |
InteractiveView | TileView | InteractiveOverlay | Gets or sets the interactive view. |
IsBusy | Boolean | Gets a value indicating whether this instance is busy. | |
IsEmpty | Boolean | Overlay | Gets a value indicating whether this instance is empty. |
IsInertiallyPanEnabled | Boolean | Gets or sets a value indicating whether this instance is inertially pan enabled. | |
IsVisible | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
MapArguments | MapArguments | Overlay | Gets or sets the map arguments. |
Name | String | Overlay | Gets or sets the name. |
Opacity | Double | Overlay | Gets or sets the opacity. |
OverlayView | UIView | Overlay | Gets or sets the overlay view. |
DrawingException | DrawingExceptionOverlayEventArgs | Overlay | This event raises when exception. |
DrawnException | DrawnExceptionOverlayEventArgs | Overlay | This event raises when exception. |
Closes this instance.
<!– ThinkGeo.MapSuite.iOSEdition.Overlay –> Go Back
Disposes this instance.
Doubles the tap.
| InteractiveResult<!– ThinkGeo.MapSuite.iOSEdition.InteractiveResult –> | InteractiveResult. |
| e | InteractionArguments<!– ThinkGeo.MapSuite.iOSEdition.InteractionArguments –> | The e. |
<!– ThinkGeo.MapSuite.iOSEdition.InteractiveOverlay –> Go Back
This method draws the overlay by the specified arguments.
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | This parameter indicates an mapArguments to draw the overlay. |
| refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.iOSEdition.OverlayRefreshType –> | This parameter indicates whether this overlay needs to be refresh or not. |
Gets the bounding box.
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape value for the overlay. |
Initializes the specified map arguments.
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map arguments. |
Longs the press.
Posts the transform for the overlay.
| transformInfo | TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> | The transform information. |
Refreshes this instance.
Singles the tap.
Touches down.
Touches the move.
Touches the pointer down.
Touches up.
Closes the core.
| isDisposing | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.iOSEdition.Overlay(overriden) –> Go Back
| InteractiveResult<!– ThinkGeo.MapSuite.iOSEdition.InteractiveResult –> | Interaction results of this method. |
| e | InteractionArguments<!– ThinkGeo.MapSuite.iOSEdition.InteractionArguments –> | This parameter is the interaction arguments for the method. |
<!– ThinkGeo.MapSuite.iOSEdition.InteractiveOverlay(overriden) –> Go Back
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | |
| geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The geo canvas. |
| exception | Exception<!– System.Exception –> | The exception. |
| ex | Exception<!– System.Exception –> | The ex. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
| mapArgument | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> |
Handles the event.
| args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawingExceptionOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
| args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawnExceptionOverlayEventArgs –> | The instance containing the event data. |
| transformInfo | TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> | |
Refreshes the core.
| MapDoubleTapMode<!– ThinkGeo.MapSuite.iOSEdition.MapDoubleTapMode –> |
<!– ThinkGeo.MapSuite.iOSEdition.ExtentInteractiveOverlay –> Go Back
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
| TileView<!– ThinkGeo.MapSuite.iOSEdition.TileView –> |
| UIView<!– MonoTouch.UIKit.UIView –> |
| Event Arguments |
| Event Arguments |
NOTOC iOSEdition ThinkGeo.MapSuite.iOSEdition UpdateDocumentation
