thinkgeo.mapsuite.desktopedition.worldmapkitwmsdesktopoverlay
ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay
This class is used in Desktop Edition to access the WorldMapKit Web Map Service (WMS).
    • ThinkGeo.MapSuite.DesktopEdition.Overlay
      • ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay
WorldMapKitWmsDesktopOverlay()
  • This is the constructor of the class.
  • If you use this constructor, you must set the properties manually before use, otherwise it will use their default values.
WorldMapKitWmsDesktopOverlay(WorldMapKitLayerType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#WorldMapKitWmsDesktopOverlay.28WorldMapKitLayerType.29
WorldMapKitWmsDesktopOverlay(String,String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#WorldMapKitWmsDesktopOverlay.28String.2C_String.29
  • clientId
    • Description:The clientId for the WMS Server.
  • privateKey
    • Description:The privateKey for the WMS Server.
WorldMapKitWmsDesktopOverlay(WorldMapKitLayerType,String,String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#WorldMapKitWmsDesktopOverlay.28WorldMapKitLayerType.2C_String.2C_String.29
  • clientId
  • privateKey
WorldMapKitWmsDesktopOverlay(WebProxy,String,String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#WorldMapKitWmsDesktopOverlay.28WebProxy.2C_String.2C_String.29
  • webProxy
    • Type:WebProxy
    • Description:Proxy to use for the WMS Server.
  • clientId
  • privateKey
WorldMapKitWmsDesktopOverlay(WorldMapKitLayerType,WebProxy,String,String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#WorldMapKitWmsDesktopOverlay.28WorldMapKitLayerType.2C_WebProxy.2C_String.2C_String.29
  • webProxy
    • Type:WebProxy
  • clientId
  • privateKey
ClearCache()
  • This method will clear the cache for the Overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#ClearCache.28.29
Refresh(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#Refresh.28GeoCanvas.2C_RectangleShape.29
DrawPreview(GeoCanvas)
  • This method will be used to draw preview tiles to the canvas.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#DrawPreview.28GeoCanvas.29
  • Description:The tile existing type, which indicates whether any tiles exist.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object to draw on.
Draw(GeoCanvas)
  • This method draws the Overlay.
  • This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • canvas
    • Type:GeoCanvas
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#GetType.28.29
DrawPreviewCore(GeoCanvas)
  • This method overrides its DrawPreviewCore virtual method in its base class Overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#DrawPreviewCore.28GeoCanvas.29
  • canvas
    • Type:GeoCanvas
DrawCore(GeoCanvas)
  • This method draws the WorldMapKitDesktopOverlay.
  • This method draws the representation of the overlay based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#DrawExceptionCore.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
    • Description:The target canvas to draw the layer.
  • e
    • Type:Exception
    • Description:The exception thrown when layer.Draw().
OnSendingWebRequest(SendingWebRequestEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnSendingWebRequest.28SendingWebRequestEventArgs.29
OnSentWebRequest(SentWebRequestEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29
OnDrawing(DrawingOverlayEventArgs)
  • This event will be fired before Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnDrawing.28DrawingOverlayEventArgs.29
OnDrawn(DrawnOverlayEventArgs)
  • This event will be fired after Overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnDrawn.28DrawnOverlayEventArgs.29
RefreshCore(GeoCanvas,RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#RefreshCore.28GeoCanvas.2C_RectangleShape.29
sBM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#DrawAttributionCore.28GeoCanvas.29
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
  • This method will draw on the canvas when an exception occurs during the drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#DrawException.28GeoCanvas.2C_Exception.29
  • canvas
    • Type:GeoCanvas
  • e
    • Type:Exception
    • Description:This parameter is the exception that is occurring.
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#MemberwiseClone.28.29
HBU=(Bitmap,RectangleShape,RectangleShape,Double,Int32,Int32)
  • higherScaleTileImage
    • Type:Bitmap
  • previewScale
  • previewImageWidth
  • previewImageHeight
ClientId
Gets or sets a value that is your Client Id.
PrivateKey
Gets or sets a value that is unique to your client ID, please keep your key secure.
LayerType
MapType
Projection
Gets or sets the Projection of the Overlay.
TileCache
Gets or sets the BitmapTileCache for the Overlay.
WebProxy
This property gets or sets the proxy used for requesting a Web Response.
  • Type:WebProxy
Attribution
Lock
This property gets the OverlayLock object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#Lock
IsBase
Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false.
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
Gets or sets the name of the overlay, which can be used to represent a specific overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#Name
PreviewTileCache
This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set.
IsEmpty
This property can be overridden by its base class. If it is not overridden, its default return value will be false. If this property is empty, we can skip drawing to achieve better performance.
DrawingTime
This property gets the last drawing time for the Overlay.
We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
  • Type:TimeSpan
AutoRefreshInterval
  • Type:TimeSpan
rxM=
SendingWebRequest N/A
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29
Event Arguments:SentWebRequestEventArgs
Drawing This event will be fired before the Overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnDrawing.28DrawingOverlayEventArgs.29
Event Arguments:DrawingOverlayEventArgs
Drawn This event will be fired after the Overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnDrawn.28DrawnOverlayEventArgs.29
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution N/A
Event Arguments:RequestedDrawingOverlayEventArgs
RequestingDrawing N/A
Event Arguments:RequestingDrawingOverlayEventArgs
thinkgeo.mapsuite.desktopedition.worldmapkitwmsdesktopoverlay.1442909625.txt.gz · Last modified: 2015/09/22 08:13 by admin
