thinkgeo.mapsuite.core.joiningdatasource
ThinkGeo.MapSuite.Core.JoiningDataSource
article_rating
<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
Protected Method*JoiningDataSource
Public Property*ColumnNamesForJoining Collection<String>
Public Property*IsOpen Boolean
*JoiningDataSource()
Name Type Description
Go Back
*Close()
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.Core.JoiningDataSource –> Go Back
*Equals(Object)
Boolean<!– System.Boolean –>
*GetHashCode()
Int32<!– System.Int32 –>
*GetJoinedColumnValues(GetJoinedColumnValuesParameter)
Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –>
parameter GetJoinedColumnValuesParameter<!– ThinkGeo.MapSuite.Core.GetJoinedColumnValuesParameter –>
*GetRequiredSourceColumnNames()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
*GetType()
Type<!– System.Type –>
*Open()
*ToString()
String<!– System.String –>
*CloseCore()
*Finalize()
*GetJoinedColumnValuesCore(GetJoinedColumnValuesParameter)
*GetRequiredSourceColumnNamesCore()
*MemberwiseClone()
*OnGettingJoinedFeature(GettingJoinedColumnValuesJoiningDataSourceEventArgs)
e GettingJoinedColumnValuesJoiningDataSourceEventArgs<!– ThinkGeo.MapSuite.Core.GettingJoinedColumnValuesJoiningDataSourceEventArgs –>
*OnGottenJoinedFeature(GottenJoinedColumnValuesJoiningDataSourceEventArgs)
e GottenJoinedColumnValuesJoiningDataSourceEventArgs<!– ThinkGeo.MapSuite.Core.GottenJoinedColumnValuesJoiningDataSourceEventArgs –>
*OnJoinedColumnNameDuplicateResolving(JoinedColumnNameDuplicateResolvingJoiningDataSourceEventArgs)
e JoinedColumnNameDuplicateResolvingJoiningDataSourceEventArgs<!– ThinkGeo.MapSuite.Core.JoinedColumnNameDuplicateResolvingJoiningDataSourceEventArgs –>
*OpenCore()
Return Type
*IsOpen
Return Type
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
thinkgeo.mapsuite.core.joiningdatasource.txt · Last modified: 2017/03/16 21:59 (external edit)
