thinkgeo.mapsuite.core.getjoinedcolumnvaluesparameter
ThinkGeo.MapSuite.Core.GetJoinedColumnValuesParameter
article_rating
<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
Public Method*GetJoinedColumnValuesParameter
Public Method*GetJoinedColumnValuesParameter String, Dictionary<String, String>, IEnumerable<String>
Public Method*Equals Object Object
Public Method*GetHashCode Object
Public Method*GetType Object
Public Method*ToString Object
Protected Method*Finalize Object
Protected Method*MemberwiseClone Object
Public Property*ColumnNamesForJoining Collection<String>
Public Property*FeatureId String
Public Property*SourceColumnValues Dictionary<String,String>
*GetJoinedColumnValuesParameter()
Name Type Description
Go Back
*GetJoinedColumnValuesParameter(String, Dictionary<String, String>, IEnumerable<String>)
featureId String<!– System.String –>
sourceColumnValues Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –>
columnNamesForJoining IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –>
Go Back
*Equals(Object)
Return Type Description
Boolean<!– System.Boolean –>
*GetHashCode()
Int32<!– System.Int32 –>
*GetType()
Type<!– System.Type –>
*ToString()
*Finalize()
Void<!– System.Void –>
*MemberwiseClone()
Return Type
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
<!– ThinkGeo.MapSuite.Core.GetJoinedColumnValuesParameter –> Go Back
*FeatureId
Return Type
*SourceColumnValues
Return Type
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
thinkgeo.mapsuite.core.getjoinedcolumnvaluesparameter.txt · Last modified: 2017/03/16 21:59 (external edit)
