<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.GottenJoinedColumnValuesJoiningDataSourceEventArgs
*GottenJoinedColumnValuesJoiningDataSourceEventArgs | |||
*GottenJoinedColumnValuesJoiningDataSourceEventArgs | GetJoinedColumnValuesParameter, Dictionary<String, String> |
*Equals | Object | Object | |
*GetHashCode | Object | ||
*GetType | Object | ||
*ToString | Object |
*Finalize | Object | ||
*MemberwiseClone | Object |
*JoinedColumnValues | Dictionary<String,String> | ||
*Parameter | GetJoinedColumnValuesParameter |
| parameter | GetJoinedColumnValuesParameter<!– ThinkGeo.MapSuite.Core.GetJoinedColumnValuesParameter –> | |
| joinedColumnValues | Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
<!– ThinkGeo.MapSuite.Core.GottenJoinedColumnValuesJoiningDataSourceEventArgs –> Go Back
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
