<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
*System.Object ThinkGeo.MapSuite.Core.JoiningDataSource *ThinkGeo.MapSuite.Core.DbfJoiningDataSource
*DbfJoiningDataSource | |||
*DbfJoiningDataSource | String | ||
*DbfJoiningDataSource | String, Encoding, CultureInfo |
*Close | JoiningDataSource | ||
*Equals | Object | Object | |
*GetHashCode | Object | ||
*GetJoinedColumnValues | GetJoinedColumnValuesParameter | JoiningDataSource | |
*GetRequiredSourceColumnNames | JoiningDataSource | ||
*GetType | Object | ||
*Open | JoiningDataSource | ||
*ToString | Object |
*ColumnNamesForJoining | Collection<String> | JoiningDataSource | |
*CultureInfo | CultureInfo | ||
*DbfPathFileName | String | ||
*Encoding | Encoding | ||
*IsOpen | Boolean | JoiningDataSource | |
*RequireIndex | Boolean | ||
*SourceColumnToMatch | String | ||
*TargetColumnToMatch | String |
| dbfPathFileName | String<!– System.String –> |
| dbfPathFileName | String<!– System.String –> | |
| encoding | Encoding<!– System.Text.Encoding –> | |
| cultureInfo | CultureInfo<!– System.Globalization.CultureInfo –> |
<!– ThinkGeo.MapSuite.Core.JoiningDataSource –> Go Back
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
| parameter | GetJoinedColumnValuesParameter<!– ThinkGeo.MapSuite.Core.GetJoinedColumnValuesParameter –> |
<!– ThinkGeo.MapSuite.Core.JoiningDataSource(overriden) –> Go Back
| e | GettingJoinedColumnValuesJoiningDataSourceEventArgs<!– ThinkGeo.MapSuite.Core.GettingJoinedColumnValuesJoiningDataSourceEventArgs –> |
| e | GottenJoinedColumnValuesJoiningDataSourceEventArgs<!– ThinkGeo.MapSuite.Core.GottenJoinedColumnValuesJoiningDataSourceEventArgs –> |
| e | JoinedColumnNameDuplicateResolvingJoiningDataSourceEventArgs<!– ThinkGeo.MapSuite.Core.JoinedColumnNameDuplicateResolvingJoiningDataSourceEventArgs –> |
<!– ThinkGeo.MapSuite.Core.DbfJoiningDataSource –> Go Back
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
