<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
*System.Object System.EventArgs *System.ComponentModel.CancelEventArgs ThinkGeo.MapSuite.Core.GettingJoinedColumnValuesJoiningDataSourceEventArgs
*GettingJoinedColumnValuesJoiningDataSourceEventArgs | |||
*GettingJoinedColumnValuesJoiningDataSourceEventArgs | GetJoinedColumnValuesParameter |
*Equals | Object | Object | |
*GetHashCode | Object | ||
*GetType | Object | ||
*ToString | Object |
*Finalize | Object | ||
*MemberwiseClone | Object |
*Cancel | Boolean | CancelEventArgs | |
*Parameter | GetJoinedColumnValuesParameter |
| parameter | GetJoinedColumnValuesParameter<!– ThinkGeo.MapSuite.Core.GetJoinedColumnValuesParameter –> |
<!– System.ComponentModel.CancelEventArgs –> Go Back
<!– ThinkGeo.MapSuite.Core.GettingJoinedColumnValuesJoiningDataSourceEventArgs –> Go Back
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
