This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
TouchDown(InteractionArguments)
This method will simulate the TouchDown interaction.
TouchMove(InteractionArguments)
This method will simulate the TouchMove interaction.
TouchPointerDown(InteractionArguments)
This method will simulate the TouchPointerDown interaction.
SingleTap(InteractionArguments)
This method will simulate the SingleTap interaction.
DoubleTap(InteractionArguments)
This method will simulate the DoubleTap interaction.
LongPress(InteractionArguments)
This method will simulate the LongPress interaction.
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan,BufferTimeType)
Refresh(RectangleShape,TimeSpan,BufferTimeType)
Refresh(IEnumerable<RectangleShape>,TimeSpan,BufferTimeType)
PostTransform(TransformArguments,MapArguments)
DrawCore(MapArguments,OverlayRefreshType)
This method draws the InterativeOverlay abstract class. You have to override this API in its sub concrete classes, Or you will see nothing.
This method draws the representation of the overlay based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
TouchUpCore(InteractionArguments)
This protected virtual method is the Core method of TouchUp API.
TouchDownCore(InteractionArguments)
This protected virtual method is the Core method of TouchDown API.
TouchMoveCore(InteractionArguments)
This protected virtual method is the Core method of TouchMove API.
TouchPointerDownCore(InteractionArguments)
This protected virtual method is the Core method of TouchPointerDown API.
SingleTapCore(InteractionArguments)
This protected virtual method is the Core method of SingleTap API.
DoubleTapCore(InteractionArguments)
This protected virtual method is the Core method of MouseDoubleClick API.
LongPressCore(InteractionArguments)
This protected virtual method is the Core method of LongPress API.
PostTransformCore(TransformArguments,MapArguments)
This protected virtual method is the Core method of PostTransform API.
This method dispose unmanaged resource used in this class.
OnDrawingException(DrawingExceptionOverlayEventArgs)
Event Arguments:DrawnExceptionOverlayEventArgs
