<!– Class –> This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.AndroidEdition.Overlay *ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay ThinkGeo.MapSuite.AndroidEdition.EditInteractiveOverlay ThinkGeo.MapSuite.AndroidEdition.ExtentInteractiveOverlay ThinkGeo.MapSuite.AndroidEdition.TrackInteractiveOverlay
InteractiveOverlay | Default constructor of this abstract class. |
Close | Overlay | This method will simulate the Close interaction. | |
Dispose | Overlay | This method dispose unmanaged resource used in this class. | |
DoubleTap | InteractionArguments | This method will simulate the DoubleTap interaction. | |
Draw | MapArguments, OverlayRefreshType | Overlay | This method draws the overlay with the provided extent in world coordinate. |
GetBoundingBox | Overlay | This method gets a bounding box of the Overlay. | |
Initialize | MapArguments | Overlay | This method initializes overlay object. |
LongPress | InteractionArguments | This method will simulate the LongPress interaction. | |
Open | Overlay | This method will simulate the Open interaction. | |
PostTransform | TransformArguments, MapArguments | Overlay | This method will simulate the PostTransform interaction. |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
SingleTap | InteractionArguments | This method will simulate the SingleTap interaction. | |
ToString | Object | ||
TouchDown | InteractionArguments | This method will simulate the TouchDown interaction. | |
TouchMove | InteractionArguments | This method will simulate the TouchMove interaction. | |
TouchPointerDown | InteractionArguments | This method will simulate the TouchPointerDown interaction. | |
TouchUp | InteractionArguments | This method will simulate the TouchUp interaction. |
CloseCore | Overlay | This protected virtual method is the Core method of Close API. | |
Dispose | Boolean | Overlay(overriden) | This method dispose unmanaged resource used in this class. |
DoubleTapCore | InteractionArguments | This protected virtual method is the Core method of MouseDoubleClick API. | |
DrawCore | MapArguments, OverlayRefreshType | Overlay(overriden) | This method draws the InterativeOverlay abstract class. You have to override this API in its sub concrete classes, Or you will see nothing. |
DrawException | GeoCanvas, Exception | Overlay | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
DrawExceptionCore | GeoCanvas, Exception | Overlay | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
Finalize | Object(overriden) | ||
GetBoundingBoxCore | Overlay | This method returns the bounding box of the Overlay. | |
InitializeCore | MapArguments | Overlay(overriden) | This protected virtual method is the Core method of Initialize API. |
LongPressCore | InteractionArguments | This protected virtual method is the Core method of LongPress API. | |
MemberwiseClone | Object | ||
OnDrawingException | DrawingExceptionOverlayEventArgs | Overlay | This method raises before the overlay is drawing exception. |
OnDrawnException | DrawnExceptionOverlayEventArgs | Overlay | This method raises after the overlay is drawn exception. |
OpenCore | Overlay | This protected virtual method is the Core method of Open API. | |
PostTransformCore | TransformArguments, MapArguments | Overlay(overriden) | This protected virtual method is the Core method of PostTransform API. |
RefreshCore | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
SingleTapCore | InteractionArguments | This protected virtual method is the Core method of SingleTap API. | |
TouchDownCore | InteractionArguments | This protected virtual method is the Core method of TouchDown API. | |
TouchMoveCore | InteractionArguments | This protected virtual method is the Core method of TouchMove API. | |
TouchPointerDownCore | InteractionArguments | This protected virtual method is the Core method of TouchPointerDown API. | |
TouchUpCore | InteractionArguments | This protected virtual method is the Core method of TouchUp API. |
Attribution | String | Overlay | Gets or sets the attribution for this overlay. |
DrawingExceptionMode | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
DrawingQuality | DrawingQuality | Overlay | Gets or sets the drawingQuality for this overlay. |
InteractiveView | TileView | Gets or sets Overlay's the interactiveView. | |
IsEmpty | Boolean | Overlay | This property gets if this overlay is empty or not. |
IsVisible | Boolean | Overlay | Gets or sets if this overlay is visible. |
MapArguments | MapArguments | Overlay | Gets or sets the mapArguments for this overlay. |
Name | String | Overlay | Gets or sets the name of this overaly. |
Opacity | Double | Overlay | Gets or sets the opacity for this overlay. |
DrawingException | DrawingExceptionOverlayEventArgs | Overlay | Occurs before exception is drawing on map. |
DrawnException | DrawnExceptionOverlayEventArgs | Overlay | Occurs after exception is drawn on map. |
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay –> Go Back
This method is the concrete wrapper for its virtual Core method.
| InteractiveResult<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveResult –> | Interaction results of this method. |
| e | InteractionArguments<!– ThinkGeo.MapSuite.AndroidEdition.InteractionArguments –> | This parameter is the interaction auguments for the method. |
<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay –> Go Back
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> | This parameter maintains current map information for calculating mechanism. |
| refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.AndroidEdition.OverlayRefreshType –> | This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode. |
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay.
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape indicating the bounding box of this overlay. |
This is a wrapper method for the virtual method InitializeCore.
| transformInfo | TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> | This parameter maintains the transfrom information for calculating transform. |
| isDisposing | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay(overriden) –> Go Back
This method draws the representation of the overlay based on the extent you provided.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
| geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
| exception | Exception<!– System.Exception –> |
| ex | Exception<!– System.Exception –> |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns the bounding box of the Overlay. |
| args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawingExceptionOverlayEventArgs –> | This parameter is the event argument for DrawingException event. |
| args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawnExceptionOverlayEventArgs –> | This parameter is the event argument for DrawingException event. |
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
| TileView<!– ThinkGeo.MapSuite.AndroidEdition.TileView –> |
This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
| Event Arguments |
| Event Arguments |
NOTOC AndroidEdition ThinkGeo.MapSuite.AndroidEdition UpdateDocumentation
