Map Suite for iOS is a powerful .NET control that lets you add interactive maps and professional-grade GIS to your iPhone® and iPad® apps. Using the power of the Xamarin mobile platform and ThinkGeo's Map Suite together, you can develop native iOS apps using the C# language and .NET libraries you're already familiar with.
All Chapters
All of the chapters of the Map Suite Developer Manual in one place so you can easily search for a topic.
Learn More
Learn about what the WebAPI Edition has to offer and how you can get started building your own web application with it.
Overlays
Discover how to use Overlays to build up your own map or add existing basemaps to your application.
Videos
Samples
Learn More
Layers
Explore all the different types of layers and data formats you can use to build up your map.
Videos
Learn More
Styling
Learn how to apply basic styles to render your vector data layers.
Videos
Samples
Learn More
Learn about the styles you can use with Map Suite to visualize your data.
Markers & Pop Ups
Explore how to make your maps more interactive by using Markers and Pop Ups.
Videos
Samples
Learn More
Learn how to draw new features or edit existing features on the map.
Querying
Learn about all the different ways you can query your data.
Videos
Samples
Learn More
Projection
Learn about Map Projection and how to apply it your data.
Videos
Samples
Learn More
Explore the different ways to manipulate features using geometric functions.
Adornments
Learn how to add legends, scale bars, north arrows and many more adornments to your map.
Videos
Samples
Learn More
Project Templates
Now that you have learned the basics of Map Suite, explore these project templates which combine several different concepts to make real world applications.
Videos
Learn More
How Do I Samples
Contains dozens of interactive samples that hit all the highlights of Map Suite iOS Edition.
Videos
Learn More
The Core API documentation covers the ThinkGeo.MapSuite.Core namespace which resides in the MapSuiteCore.dll assembly. It contains all of the core GIS classes that are shared between the different Map Suite edition map controls and servers. It includes such classes as Style, FeatureSource, Layer, Projection etc. This is where the bulk of the classes are for most of the Map Suite products.
The iOS Edition API documentation covers the ThinkGeo.MapSuite.iOSEdition namespace which resides in the iOSEdition.dll assembly. It contains all of the iOS Edition specific classes such as the map control itself, Overlays, and supported map classes.
The FormsEdition API documentation covers the ThinkGeo.MapSuite.FormsEdition namespace which resides in the MapSuiteFormsEdition.dll assembly. It contains all of the MapSuiteForms Edition specific classes such as the map control itself, Overlays, and supported map classes.
The FormsEdition.iOS API documentation covers the ThinkGeo.MapSuite.FormsEdition.iOS namespace which resides in the MapSuiteFormsEdition.iOS.dll assembly. It contains all of the FormsEdition.iOS Edition specific classes such as the Forms.
Step through the iOS Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
The iOS Edition screenshots gallery section showcases a wide range of screenshots covering various GIS features of the iOS Edition map control.
