| Format | Support Type | Map Suite Version |
| GeoTIFF | Read | 9.0 |
| BMP | Read/Write | 9.0 |
| PNG | Read/Write | 9.0 |
| GIF | Read/Write | 9.0 |
| JPG | Read/Write | 9.0 |
| TIFF | Read/Write | 9.0 |
| Format/Provider | Map Suite Version | Description |
| World Map Kit Online | 9.0 | ThinkGeo's basemap based on Open Street Map Data that is displayed in most of the sample applications. You can check out what the maps look like at http://maps.thinkgeo.com |
| WMS (Web Map Service) | 9.0 | WMS is a open standard set by the OGC to consume maps over the web. |
| WFS (Web Feature Service) | 9.0 | WFS is a open standard set by the OGC. |
| Google Maps 2) | 9.0 | Google Maps |
| Bing Maps 3) | 9.0 | Bing Maps |
| NOAA Radar | 9.0 | NEXRAD Radar updated every 15 minutes covering most of the United States. |
| NOAA Weather Watches & Warnings | 9.0 | Current weather watches and warnings covering the United States. |
| NOAA Weather Stations | 9.0 | Current temperatures and other weather information from NOAA weather stations around the United States. |
