map_suite_ios_edition
Map Suite iOS Edition
Map Suite for iOS is a powerful .NET control that lets you add interactive maps and professional-grade GIS to your iPhone® and iPad® apps. Using the power of the Xamarin mobile platform and ThinkGeo's Map Suite together, you can develop native iOS apps using the C# language and .NET libraries you're already familiar with.
Learning Samples
Product Guides
Helps you get started building your first application with the Map Suite iOS Edition.
Introduces the dependencies Map Suite Desktop Edition needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.Core
    The Core API documentation covers the ThinkGeo.MapSuite.Core namespace which resides in the MapSuiteCore.dll assembly. It contains all of the core GIS classes that are shared between the different Map Suite edition map controls and servers. It includes such classes as Style, FeatureSource, Layer, Projection etc. This is where the bulk of the classes are for most of the Map Suite products.
  • ThinkGeo.MapSuite.iOSEdition
    The iOS Edition API documentation covers the ThinkGeo.MapSuite.iOSEdition namespace which resides in the iOSEdition.dll assembly. It contains all of the iOS Edition specific classes such as the map control itself, Overlays, and supported map classes.
API Documentation (Xamarin.Forms)
  • ThinkGeo.MapSuite.FormsEdition
    The FormsEdition API documentation covers the ThinkGeo.MapSuite.FormsEdition namespace which resides in the MapSuiteFormsEdition.dll assembly. It contains all of the MapSuiteForms Edition specific classes such as the map control itself, Overlays, and supported map classes.
  • ThinkGeo.MapSuite.FormsEdition.iOS
    The FormsEdition.iOS API documentation covers the ThinkGeo.MapSuite.FormsEdition.iOS namespace which resides in the MapSuiteFormsEdition.iOS.dll assembly. It contains all of the FormsEdition.iOS Edition specific classes such as the Forms.
Videos
Step through the iOS Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
iOS Getting Started Sample
iOS Getting Started
iOS Map Visualization Learning Sample
iOS Labeling Learning Sample
iOS Drawing & Editing Sample
iOS Geometric Functions Learning Sample
Screenshots
The iOS Edition screenshots gallery section showcases a wide range of screenshots covering various GIS features of the iOS Edition map control.
Tablets
Getting Started with Map
Visualization
Visualization
Label Styling
Label Styling
Geometric Functions
Geometric Functions
Drawing And Editing Features
Siteselection
Siteselection
Visualization-US Weather
US Earthquake Statistics
Phones
Visualization
Visualization
Label Styling
Label Styling
Geometric Functions
Geometric Functions
Siteselection
Siteselection
Change Logs
  • API Change Log
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_ios_edition.1443081712.txt.gz · Last modified: 2015/09/24 08:01 by admin
