<!– Class –> Represents a MarkerOverlay object to which you can add markers directly.
The <strong>SimpleMarkerOverlay</strong> class has a <strong>Markers</strong> collection to which you can add markers directly. All of these markers will be placed on the map loading. You can also specify whether the markers can be dragged by setting the <strong>DragMode</strong> property.
*System.Object ThinkGeo.MapSuite.WpfDesktopEdition.Overlay *ThinkGeo.MapSuite.WpfDesktopEdition.MarkerOverlay ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay
SimpleMarkerOverlay | Constructor of SimpleMarkerOverlay class. | ||
SimpleMarkerOverlay | IEnumerable<Marker> | Constructor of SimpleMarkerOver |
Close | Overlay | ||
Dispose | Overlay | This method dispose unmanaged resource used in this class. | |
Draw | RectangleShape, OverlayRefreshType | Overlay | This method draws the overlay with the provided extent in world coordinate. |
Draw | RectangleShape | Overlay | This method draws the overlay with the provided extent in world coordinate. |
GetBoundingBox | Overlay | This method gets a bounding box of the Overlay. | |
GetMarkersForDrawing | RectangleShape | MarkerOverlay | This method gets a marker collection for drawing on the overlay. |
Initialize | MapArguments | Overlay | This method initializes overlay object. |
LoadState | Byte[] | Overlay | This method restore the overlay state back from the specified state. |
Open | Overlay | ||
PanTo | RectangleShape | Overlay | This method pans the overlay to the provided world extent. |
Refresh | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Overlay | |
Refresh | RectangleShape | Overlay | |
Refresh | IEnumerable<RectangleShape> | Overlay | |
Refresh | TimeSpan | Overlay | |
Refresh | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Overlay | |
Refresh | TimeSpan, RequestDrawingBufferTimeType | Overlay | |
Refresh | RectangleShape, TimeSpan | Overlay | |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
Refresh | IEnumerable<RectangleShape>, TimeSpan | Overlay | |
SaveState | Overlay | This method saves overlay state to a byte array. | |
CloseCore | Overlay | ||
Dispose | Boolean | Overlay | This method dispose unmanaged resource used in this class. |
DrawAttributionCore | GeoCanvas | Overlay | |
DrawCore | RectangleShape, OverlayRefreshType | Overlay(overriden) | |
Finalize | Object(overriden) | ||
GetBoundingBoxCore | Overlay(overriden) | This method gets a bounding box that maintains all the markers which are added in this overlay. | |
GetMarkersForDrawingCore | RectangleShape | MarkerOverlay(overriden) | Gets all the markers that are containing in the provided world extent. |
InitializeCore | MapArguments | Overlay | This method initializes overlay object. |
LoadStateCore | Byte[] | Overlay(overriden) | This method restore the simple marker overlay state back from the specified state. |
MemberwiseClone | Object | ||
OnDrawing | DrawingOverlayEventArgs | Overlay | This method raises before the overlay is drawing. |
OnDrawingAttribution | DrawingAttributionOverlayEventArgs | Overlay | |
OnDrawn | DrawnOverlayEventArgs | Overlay | This method raises after the overlay is drawn. |
OnDrawnAttribution | DrawnAttributionOverlayEventArgs | Overlay | |
OnMarkerDragged | MarkerDraggedSimpleMarkerOverlayEventArgs | This method raises after the marker is dragged. | |
OnMarkerDragging | MarkerDraggingSimpleMarkerOverlayEventArgs | This method raises before the marker is dragging. | |
OpenCore | Overlay | ||
PanToCore | RectangleShape | Overlay | This method pans the overlay to the provided world extent. |
RefreshCore | RectangleShape | Overlay | |
RefreshCore | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
SaveStateCore | Overlay(overriden) | This method saves simple marker overlay state to a byte array. |
Attribution | String | Overlay | |
AutoRefreshInterval | TimeSpan | Overlay | |
CanRefreshRegion | Boolean | Overlay | |
DragMode | MarkerDragMode | Gets a value that specifies how the markers can be dragged. | |
DrawingExceptionMode | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
IsBase | Boolean | Overlay | |
IsEmpty | Boolean | Overlay | This property gets if this overlay is empty or not. |
IsVisible | Boolean | Overlay | Gets or sets if this overlay is visible. |
MapArguments | MapArguments | Overlay | Gets or sets current map information which will be used for calculating mechanism. |
Markers | GeoCollection<Marker> | A collection that holds all the marker objects adding in the overlay. | |
Name | String | Overlay | Gets or sets the name of this overaly. |
OverlayCanvas | Canvas | Overlay | Gets or sets the actual canvas which maintains all the visual elements on the overlay. |
IsOverlayInitialized | Boolean | Overlay | Gets or sets if the overlay canvas is initialized. |
PreviousExtent | RectangleShape | Overlay | Gets or sets the previous exent of the overlay. |
Drawing | DrawingOverlayEventArgs | Overlay | This event raises before the overlay is drawing. |
Drawn | DrawnOverlayEventArgs | Overlay | This event raises after the overlay is drawn. |
MarkerDragged | MarkerDraggedSimpleMarkerOverlayEventArgs | This is an event raises after the marker is dragged. | |
MarkerDragging | MarkerDraggingSimpleMarkerOverlayEventArgs | This is an event raises before the marker is dragging. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#SimpleMarkerOverlay.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#SimpleMarkerOverlay.28.29</a>
| markers | IEnumerable<Marker><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WpfDesktopEdition.Marker} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Close.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Close.28.29</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Dispose.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Dispose.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Draw.28RectangleShape.2C_OverlayRefreshType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Draw.28RectangleShape.2C_OverlayRefreshType.29</a>
| targetExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter indicates an extent in world coordinate for drawing the overlay. |
| refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.WpfDesktopEdition.OverlayRefreshType –> | This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Draw.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Draw.28RectangleShape.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Equals.28Object.29</a>
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay.As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape indicating the bounding box of this overlay |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetHashCode.28.29</a>
This is a wrapper method for the abstract method GetDrawingMarkersCore.
| GeoCollection<Marker><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.WpfDesktopEdition.Marker} –> | An marker collection for drawing. |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the extent in world coordinate for requesting markers. |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.MarkerOverlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetType.28.29</a>
This is a wrapper method for the virtual method InitializeCore.
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments –> | This parameter maintains current map information for calculating mechanism. |
| state | Byte[]<!– System.Bytethinkgeo.mapsuite.wpfdesktopedition.simplemarkeroverlay –> | This parameter indicates the state for restore the overlay. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Open.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Open.28.29</a>
Some overlay doesn't need to continously drawing all the tile. For example, MarkerOverlay is formed by markers. When mouse down to pan, the markers don't need to redraw, we can only change its position. When mouse up to end panning, we can redraw the overlay for better performance.
| targetExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the target world extent for panning. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Refresh.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Refresh.28RectangleShape.29</a>
| extent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Refresh.28TimeSpan.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Refresh.28TimeSpan.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Refresh.28RectangleShape.2C_TimeSpan.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Refresh.28RectangleShape.2C_TimeSpan.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#SaveState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#SaveState.28.29</a>
| Byte[]<!– System.Bytethinkgeo.mapsuite.wpfdesktopedition.simplemarkeroverlay –> | A byte array indicates current overlay state. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#CloseCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#CloseCore.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Dispose.28Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Dispose.28Boolean.29</a>
| disposing | Boolean<!– System.Boolean –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#DrawAttributionCore.28GeoCanvas.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#DrawAttributionCore.28GeoCanvas.29</a>
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#DrawCore.28RectangleShape.2C_OverlayRefreshType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#DrawCore.28RectangleShape.2C_OverlayRefreshType.29</a>
| targetExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| overlayRefreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.WpfDesktopEdition.OverlayRefreshType –> |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.Overlay(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetBoundingBoxCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetBoundingBoxCore.28.29</a>
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | Returns a RectangleShape that maintains all the markers which are added in this overlay. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetMarkersForDrawingCore.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetMarkersForDrawingCore.28RectangleShape.29</a>
| GeoCollection<Marker><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.WpfDesktopEdition.Marker} –> | A collection of marker objects that are in the provided world extent. |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A world extent of current viewport. |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.MarkerOverlay(overriden) –> Go Back
When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnDrawing.28DrawingOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnDrawing.28DrawingOverlayEventArgs.29</a>
| e | DrawingOverlayEventArgs<!– ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs –> | This parameter is the event argument for Drawing event. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29</a>
| args | DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.WpfDesktopEdition.DrawingAttributionOverlayEventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnDrawn.28DrawnOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnDrawn.28DrawnOverlayEventArgs.29</a>
| e | DrawnOverlayEventArgs<!– ThinkGeo.MapSuite.WpfDesktopEdition.DrawnOverlayEventArgs –> | This parameter is the event argument for Drawn event. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29</a>
| args | DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.WpfDesktopEdition.DrawnAttributionOverlayEventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnMarkerDragged.28MarkerDraggedSimpleMarkerOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnMarkerDragged.28MarkerDraggedSimpleMarkerOverlayEventArgs.29</a>
| args | MarkerDraggedSimpleMarkerOverlayEventArgs<!– ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggedSimpleMarkerOverlayEventArgs –> | This parameter is the event args for the MarkerDragged event. |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnMarkerDragging.28MarkerDraggingSimpleMarkerOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OnMarkerDragging.28MarkerDraggingSimpleMarkerOverlayEventArgs.29</a>
| args | MarkerDraggingSimpleMarkerOverlayEventArgs<!– ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDraggingSimpleMarkerOverlayEventArgs –> | This parameter is the event args for the MarkerDragging event. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OpenCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OpenCore.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#RefreshCore.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#RefreshCore.28RectangleShape.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#SaveStateCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#SaveStateCore.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#AutoRefreshInterval</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#CanRefreshRegion” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#CanRefreshRegion</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#DragMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#DragMode</a>
| MarkerDragMode<!– ThinkGeo.MapSuite.WpfDesktopEdition.MarkerDragMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#DrawingExceptionMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#DrawingExceptionMode</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#IsBase” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#IsBase</a>
This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#IsVisible</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Initialize.28MapArguments.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Initialize.28MapArguments.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetMarkersForDrawing.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#GetMarkersForDrawing.28RectangleShape.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#Name</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OverlayCanvas” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#OverlayCanvas</a>
| Canvas<!– System.Windows.Controls.Canvas –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#IsOverlayInitialized” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#IsOverlayInitialized</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#PreviousExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.SimpleMarkerOverlay#PreviousExtent</a>
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC WpfDesktopEdition ThinkGeo.MapSuite.WpfDesktopEdition UpdateDocumentation
