thinkgeo.mapsuite.wmsserveredition
ThinkGeo.MapSuite.WmsServerEdition
WmsServerEdition
Classes
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
G
  • GetCapabilitiesRequest
    This class maintains all of the requested information from a WMS GetCapabilitiesRequest.
  • GetFeatureInfoRequest
    This class maintains all of the requested information from a WMS request.
  • GetMapRequest
M
  • MapConfiguration
    This class maintains the layers collection and TileCache object.
W
  • WmsHandler
    This is an asynchronous HTTP handler which is used to handle web map services.
  • WmsLayerPlugin
    This class is the base class for all types of WMS Plug-ins. The WmsLayerPlugin class is where all other types of WMS Plug-ins are inherited from. It provides the base set of functionality. As it is abstract, there are a number of methods you need to implement. The first one is GetMapConfigurationCore. In this method, you are responsible for generating a MapConfiguration which includes layers collection and TileCache object you will use. The other two required methods are GetProjectionCore and GetBoundingBoxCore. These get projection string and the BoundingBox for your WMS Plug-in. Another required method is GetNameCore which returns the layer name which will used in the GetMap WMS operation.
  • WmsLayerStyle
    This is a structure that maintains the Style informations for the Capabilities XML DTD.
Structures
Enums
W
  • WmsQueryMode
    Indicates whether or not this layer supports the GetFeatureInfo WMS operation.
Interfaces
thinkgeo.mapsuite.wmsserveredition.txt · Last modified: 2017/03/16 21:59 (external edit)
