thinkgeo.mapsuite.wmsserveredition.wmshandler
ThinkGeo.MapSuite.WmsServerEdition.WmsHandler
This is an asynchronous HTTP handler which is used to handle web map services.
    • ThinkGeo.MapSuite.WmsServerEdition.WmsHandler
WmsHandler()
  • This is the default constructor for the WmsHandler class.
BeginProcessRequest(HttpContext,AsyncCallback,Object)
  • Initiates an asynchronous call to the HTTP handler.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#BeginProcessRequest.28HttpContext.2C_AsyncCallback.2C_Object.29
  • Type:IAsyncResult
  • Description:A System.IAsyncResult that contains information about the status of the process.
  • context
    • Type:HttpContext
    • Description:A System.Web.HttpContext object that provides references to intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests.
  • cb
    • Type:AsyncCallback
    • Description:The System.AsyncCallback to call when the asynchronous method call is complete. If cb is null, the delegate is not called.
  • extraData
    • Description:Any extra data needed to process the request.
EndProcessRequest(IAsyncResult)
  • Provides an asynchronous process End method when the process ends.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#EndProcessRequest.28IAsyncResult.29
  • result
    • Type:IAsyncResult
ProcessRequest(HttpContext)
  • Enables processing of HTTP Web requests by a custom HttpHandler that implements the System.Web.IHttpHandler interface.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#ProcessRequest.28HttpContext.29
  • context
    • Type:HttpContext
    • Description:A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#GetType.28.29
ProcessRequestCore(HttpContext)
  • This abstract method is called from the concrete public method ProcessRequest. This method processes the request from client.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#ProcessRequestCore.28HttpContext.29
  • context
    • Type:HttpContext
GetCapabilities(GetCapabilitiesRequest,HttpContext)
  • The purpose of the GetCapabilities WMS operation is to retrieve general information about the service itself and specific information about the available layers.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#GetCapabilities.28GetCapabilitiesRequest.2C_HttpContext.29
  • Description:This method returns general information about the service itself and specific information about the available layers.
  • getCapabilitiesRequest
    • Description:The RequestInfo object corresponding to the QueryString from the client's request.
  • context
    • Type:HttpContext
GetCapabilitiesCore(GetCapabilitiesRequest,HttpContext)
  • This abstract method is called from the concrete public method GetCapabilities.
  • context
    • Type:HttpContext
GetMap(GetMapRequest,HttpContext)
  • The GetMap WMS operation is designed to produce a map, which is defined as either a pictorial image or a set of graphical elements.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#GetMap.28GetMapRequest.2C_HttpContext.29
  • Type:Bitmap
  • Description:This method returns a pictorial image or a set of graphical elements.
  • getMapRequest
  • context
    • Type:HttpContext
GetMapCore(GetMapRequest,HttpContext)
  • This abstract method is called from the concrete public method GetMap.
  • Type:Bitmap
  • getMapRequest
  • context
    • Type:HttpContext
GetFeatureInfo(GetFeatureInfoRequest,HttpContext)
  • This method implements the WMS GetFeatureInfo operation and returns feature information depending on the request from the client.
  • This method is the concrete wrapper for the abstract method GetFeatureInfo. The canonical use case for GetFeatureInfo is that a user sees the response of a GetMap request and chooses a point on that map for which to obtain more information. The basic operation provides the ability for a client to specify which pixel is being asked about, which layer(s) should be investigated, and what format the information should be returned in.
  • Description:This method returns feature information depending on the request from the client.
  • getFeatureInfoRequest
  • context
    • Type:HttpContext
GetFeatureInfoCore(GetFeatureInfoRequest,HttpContext)
  • This method implements the WMS GetFeatureInfo operation and returns feature information depending on the request from client.
  • This abstract method is called from the concrete public method GetFeatureInfo. The canonical use case for GetFeatureInfo is that a user sees the response of a GetMap request and chooses a point on that map for which to obtain more information. The basic operation provides the ability for a client to specify which pixel is being asked about, which layer(s) should be investigated, and what format the information should be returned in.
  • context
    • Type:HttpContext
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#MemberwiseClone.28.29
IsReusable
Gets a value indicating whether another request can use the System.Web.IHttpHandler instance.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.WmsHandler#IsReusable
CapabilitiesFilePathName
The file path for your capabilites xml document
OhQ=
thinkgeo.mapsuite.wmsserveredition.wmshandler.txt · Last modified: 2017/03/16 21:59 (external edit)
