<!– Class –> This class maintains all of the requested information from a WMS request.
*System.Object **ThinkGeo.MapSuite.WmsServerEdition.GetFeatureInfoRequest
GetFeatureInfoRequest | Initialize an instance of the RequestInfo class. |
BoundingBox | RectangleShape | Gets or sets the bounding box of the currently requested viewport, in world coordinates. | |
Crs | String | Gets or sets a CRS parameter from a WMS request. | |
CustomParameter | String | Represents the custom parameter that comes from the client's request. | |
FeatureCount | Int32 | The number of features about which to return information (default=1). | |
Height | Int32 | Gets or sets the height, in pixel units, of the image being requested. | |
InfoFormat | String | Returns the format of the feature information (MIME type). | |
QueryLayers | Collection<String> | A comma-separated list of one or more layers to be queried. | |
ScreenX | Single | The X coordinate, in pixels, of the feature (measured from the upper left corner, which is 0) | |
ScreenY | Single | The Y coordinate, in pixels, of the feature (measured from the upper left corner, which is 0) | |
Version | String | Gets or sets the WMS version from the currently requested URI. | |
Width | Int32 | Gets or sets the width, in pixel unit, of the image being requested. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.WmsServerEdition.GetFeatureInfoRequest –> Go Back
Gets or sets a CRS parameter from a WMS request. The parameter refers to the MapUnit property.
For example, if you set the CRS parameter to “EPSG:4326”, the MapUnit will be automatically set to DecimalDegree. Similarly, if you set the CRS parameter to “EPSG:900913”, the MapUnit will be automatically set to Meter.
