thinkgeo.mapsuite.wmsserveredition.mapconfiguration
ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration
This class maintains the layers collection and TileCache object.
    • ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration
MapConfiguration()
  • Provide a defalut constructor.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration#MapConfiguration.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration#MemberwiseClone.28.29
Layers
Gets a GeoCollection that contains the layers that will draw on the image that is sent to the browser.
The <strong>Layers</strong> property holds all of the layers that are used by the <strong>Draw</strong> method. The Draw method loops through all layers to filter out features and draw with specified styles to the image that will be sent to the browser.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WmsServerEdition.MapConfiguration#TileCache
thinkgeo.mapsuite.wmsserveredition.mapconfiguration.txt · Last modified: 2017/03/16 21:59 (external edit)
