thinkgeo.mapsuite.windowsphonecore.valuestyle
ThinkGeo.MapSuite.WindowsPhoneCore.ValueStyle
<!– Class –> This class allows you to match a value with data in the feature to determine how to draw that feature.
Value Style:
The ValueStyle allows you to match data in the FeatureSource against a value string. If the value matches, then we will use the style defined in that item to do the drawing. For example, let's say you have some data that contains states, and each state is categorized as either a high, medium or low pollution state. Based on the string values of “High”, Medium“ and “Low”, we can match on these. If a feature's data for the column matched the string “High”, then we would use the high ValueItem's styles to draw that feature. This can be applied to all kinds of things, such as road classifications, etc.
This can be somewhat slow because we have to match data from the FeatureSource. If performance is key, then instead of using the ValueStyle, we recommend that you create a set custom index for your layer, one index with only “High” elements, one for “Medium” and so on. Then load each as a separate layer. In this way, you would only have one data set, but multiple indexes. This is the fastest way if you are working with Shape Files. If you are working with spatial databases, then we suggest creating a view to segment out each category.
Public MethodValueStyle This is a constructor for the class.
Public MethodValueStyle String, Collection<ValueItem> This is a constructor for this class.
Public MethodDraw IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the shapes on the canvas you provided.
Public MethodDraw IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the features on the canvas you provided.
Public MethodDrawSample GeoCanvas, DrawingRectangleF Style
Public MethodGetRequiredColumnNames Style This method returns the column data for each feature that is required for the style to properly draw.
Public MethodGetType Object
Public MethodToString Object
Protected MethodDrawCore IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style(overriden) This method draws the features on the canvas you provided.
Protected MethodDrawSampleCore GeoCanvas, DrawingRectangleF Style
Protected MethodGetRequiredColumnNamesCore Style(overriden) This method returns the column data for each feature that is required for the style to properly draw.
Public PropertyColumnName String This property gets and sets the column name used to match with the value specified in the items.
Public PropertyIsActive Boolean Style This property gets and sets the active status of the style.
Public PropertyName String Style This property gets and set the name of the style.
Public PropertyRequiredColumnNames Collection<String> Style This property gets the collection of fields that are required for the style.
Public PropertyValueItems Collection<ValueItem> This property gets the collection of ValueItems. Each item can have its own value to match.
ValueStyle()
Overloads
This is the default constructor. If you use this constructor, you need to set the required properties manually.
Name Type Description
Go Back
ValueStyle(String, Collection<ValueItem>)
columnName String<!– System.String –> The columnName used to match with the value specified in the items.
valueItems Collection<ValueItem><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.ValueItem} –> The collection of ValueItems. Each item can have its own value to match.
Go Back
Draw(IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
Return Type Description
Void<!– System.Void –>
shapes IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape} –> This parameter represents the shapes you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter represents the canvas you want to draw the shapes on.
labelsInThisLayer Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> The labels will be drawn in the current layer only.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> The labels will be drawn in all layers.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style –> Go Back
Draw(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This parameter represents the features you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter represents the canvas you want to draw the features on.
DrawSample(GeoCanvas, DrawingRectangleF)
drawingExtent DrawingRectangleF<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingRectangleF –>
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetRequiredColumnNames()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> This method returns a collection of column names that the style needs.
Type<!– System.Type –>
DrawCore(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style(overriden) –> Go Back
DrawSampleCore(GeoCanvas, DrawingRectangleF)
GetRequiredColumnNamesCore()
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> This method returns a collection of the column names that it needs.
ColumnName
This is the column we use for matching.
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.ValueStyle –> Go Back
IsActive
Return Type
Return Type
RequiredColumnNames
Return Type
ValueItems
You will want to add ValueItems to this collection. Each item can have its own style and matching string.
Return Type
thinkgeo.mapsuite.windowsphonecore.valuestyle.txt · Last modified: 2017/03/16 21:59 (external edit)
