<!– Class –> This class represents a MultilineShape, which is defined as one or more lines, each with two or more points.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape *ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape
MultilineShape | This constructor creates the MultilineShape. | ||
MultilineShape | IEnumerable<LineShape> | ||
MultilineShape | String | This constructor creates the MultilineShape. | |
MultilineShape | Byte[] | This constructor creates the MultilineShape. |
Buffer | Double, Int32, BufferCapType, GeographyUnit, DistanceUnit | BaseShape | This method computes the area containing all of the points within a given distance from this shape. |
Buffer | Double, GeographyUnit, DistanceUnit | BaseShape | This method computes the area containing all of the points within a given distance from this shape. |
Buffer | Double, Int32, GeographyUnit, DistanceUnit | BaseShape | This method computes the area containing all of the points within a given distance from this shape. |
CloneDeep | BaseShape | This method returns a complete copy of the shape without any references in common. | |
Contains | Feature | BaseShape | This method returns if the targetFeature lies within the interior of the current shape. |
Contains | BaseShape | BaseShape | This method returns if the targetShape lies within the interior of the current shape. |
ConvexHull | LineBaseShape | This method returns the convex hull of the shape defined as the smallest convex ring that contains all the points in the shape. | |
![]() CreateShapeFromWellKnownData | Byte[] | BaseShape | This method creates a BaseShape from a string of well-known binary. |
![]() CreateShapeFromWellKnownData | String | BaseShape | This method creates a BaseShape from a string of well-known text. |
Crosses | Feature | BaseShape | This method returns if the current shape and the targetFeature share some but not all interior points. |
Crosses | BaseShape | BaseShape | This method returns if the current shape and the targetShape share some but not all interior points. |
GetBoundingBox | BaseShape | This method calculates the smallest RectangleShape that encompasses the entire geometry. | |
GetCenterPoint | BaseShape | This method returns the center point of the current shape's bounding box. | |
GetClosestPointTo | BaseShape, GeographyUnit | BaseShape | This method returns the point of the current shape that is closest to the target shape. |
GetClosestPointTo | Feature, GeographyUnit | BaseShape | This method returns the point of the current shape that is closest to the target feature. |
GetCrossing | BaseShape | BaseShape | This method returns the crossing points between the current shape and the passed-in target shape. |
GetDistanceTo | BaseShape, GeographyUnit, DistanceUnit | BaseShape | This method computes the distance between the current shape and the targetShape. |
GetDistanceTo | Feature, GeographyUnit, DistanceUnit | BaseShape | This method computes the distance between the current shape and the targetFeature. |
GetFeature | BaseShape | Get a corresponding feature which has the same Id and BaseShape as the current shape. | |
GetFeature | IDictionary<String, String> | BaseShape | Get a corresponding feature which has the same Id and BaseShape as the current shape. Additionally, pass the specified columnValues into the returned feature. |
GetIntersection | Feature | LineBaseShape | |
GetIntersection | AreaBaseShape | LineBaseShape | |
GetLength | GeographyUnit, DistanceUnit | LineBaseShape | This method returns the length of the line shape. |
GetLineOnALine | StartingPoint, PointShape | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetLineOnALine | PointShape, PointShape | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetLineOnALine | StartingPoint, Double, Double, GeographyUnit, DistanceUnit | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetLineOnALine | StartingPoint, Single, Single | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetLineOnALine | StartingPoint, Single | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetPointOnALine | StartingPoint, Double, GeographyUnit, DistanceUnit | This method returns a PointShape on the line, based on a distance on the line from the first or last vertex (as defined by the startingPoint parameter). | |
GetPointOnALine | StartingPoint, Single | This method returns a PointShape on the line, based on a percentage of the length of the line from either its first or last vertex (as defined by the startingPoint parameter). | |
GetShortestLineTo | BaseShape, GeographyUnit | BaseShape | This method returns the shortest LineShape between this shape and the targetShape parameter. |
GetShortestLineTo | Feature, GeographyUnit | BaseShape | This method returns the shortest LineShape between this shape and the targetFeature. parameter. |
GetWellKnownBinary | WkbByteOrder | BaseShape | This method returns a byte array that represents the shape in well-known binary. |
GetWellKnownBinary | BaseShape | This method returns a byte array that represents the shape in well-known binary. | |
GetWellKnownText | BaseShape | This method returns the well-known text representation of this shape. | |
GetWellKnownType | BaseShape | This method returns the well-known type for the shape. | |
Intersects | Feature | BaseShape | This method returns if the current shape and the targetFeature have at least one point in common. |
Intersects | BaseShape | BaseShape | This method returns if the current shape and the targetShape have at least one point in common. |
IsDisjointed | Feature | BaseShape | This method returns if the current shape and the targetFeature have no points in common. |
IsDisjointed | BaseShape | BaseShape | This method returns if the current shape and the targetShape have no points in common. |
IsTopologicallyEqual | BaseShape | BaseShape | This method returns if the current shape and the targetShape are topologically equal. |
IsTopologicallyEqual | Feature | BaseShape | This method returns if the current shape and the targetFeature are topologically equal. |
IsWithin | BaseShape | BaseShape | This method returns if the current shape lies within the interior of the targetShape. |
IsWithin | Feature | BaseShape | This method returns if the current shape lies within the interior of the targetFeature. |
LoadFromWellKnownData | String | BaseShape | This method hydrates the current shape with its data from well-known text. |
LoadFromWellKnownData | Byte[] | BaseShape | This method hydrates the current shape with its data from well-known binary. |
Overlaps | BaseShape | BaseShape | This method returns if the current shape and the targetShape share some but not all points in common. |
Overlaps | Feature | BaseShape | This method returns if the current shape and the targetFeature share some but not all points in common. |
Register | Feature, Feature, DistanceUnit, GeographyUnit | BaseShape | This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes. |
Register | PointShape, PointShape, DistanceUnit, GeographyUnit | BaseShape | This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes. |
RemoveVertex | Vertex | ||
![]() RemoveVertex | Vertex, MultilineShape | ||
Reorder | PointShape, Double | This API is used to make the lines within the Multiline ordered. | |
Reorder | PointShape, Double, GeographyUnit, DistanceUnit | This API is used to make the lines within the Multiline ordered. | |
Rotate | PointShape, Single | BaseShape | This method rotates a shape a number of degrees based on a pivot point. |
![]() Rotate | Feature, PointShape, Single | BaseShape | This method returns a feature rotated by a number of degrees based on a pivot point. |
![]() Rotate | BaseShape, PointShape, Single | BaseShape | This method returns a shape rotated by a number of degrees based on a pivot point. |
ScaleDown | Double | LineBaseShape | This method decreases the size of the LineShape by the percentage given in the percentage parameter. |
![]() ScaleDown | LineBaseShape, Double | LineBaseShape | This method returns a new shape that is decreases by the percentage given in the percentage parameter. |
![]() ScaleDown | Feature, Double | LineBaseShape | This method returns a new feature that is decreases by the percentage given in the percentage parameter. |
ScaleTo | Double | BaseShape | |
![]() ScaleTo | BaseShape, Double | BaseShape | |
![]() ScaleUp | Feature, Double | LineBaseShape | This method returns a new feature that is increased by the percentage given in the percentage parameter. |
![]() ScaleUp | LineBaseShape, Double | LineBaseShape | This method returns a new shape that is increased by the percentage given in the percentage parameter. |
ScaleUp | Double | LineBaseShape | This method increases the size of the LineShape by the percentage given in the percentage parameter. |
Simplify | Double, SimplificationType | LineBaseShape | Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType. |
Simplify | GeographyUnit, Double, DistanceUnit, SimplificationType | LineBaseShape | Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType. |
![]() Simplify | LineBaseShape, Double, SimplificationType | LineBaseShape | Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType. |
![]() Simplify | LineBaseShape, GeographyUnit, Double, DistanceUnit, SimplificationType | LineBaseShape | Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType. |
ToString | Object | ||
Touches | BaseShape | BaseShape | This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points. |
Touches | Feature | BaseShape | This method returns of the current shape and the targetFeature have at least one boundary point in common, but no interior points. |
![]() TranslateByDegree | BaseShape, Double, Double, GeographyUnit, DistanceUnit | BaseShape | This method returns a shape repositioned from one location to another based on a distance and a direction in degrees. |
![]() TranslateByDegree | Feature, Double, Double, GeographyUnit, DistanceUnit | BaseShape | This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees. |
TranslateByDegree | Double, Double | BaseShape | This method moves a base shape from one location to another based on a distance and a direction in degrees. |
TranslateByDegree | Double, Double, GeographyUnit, DistanceUnit | BaseShape | This method moves a base shape from one location to another based on a distance and a direction in degrees. |
TranslateByOffset | Double, Double | BaseShape | |
![]() TranslateByOffset | Feature, Double, Double, GeographyUnit, DistanceUnit | BaseShape | This method returns a feature repositioned from one location to another based on an X and Y offset distance. |
TranslateByOffset | Double, Double, GeographyUnit, DistanceUnit | BaseShape | This method moves a base shape from one location to another based on an X and Y offset distance. |
![]() TranslateByOffset | BaseShape, Double, Double, GeographyUnit, DistanceUnit | BaseShape | This method returns a shape repositioned from one location to another based on an X and Y offset distance. |
Union | Feature | LineBaseShape | |
Union | LineBaseShape | LineBaseShape | Calculates a new geometry that contains all the points in this LineBaseShape and input LineBaseShape |
![]() Union | IEnumerable<Feature> | LineBaseShape | |
![]() Union | IEnumerable<LineBaseShape> | LineBaseShape | Calculates a new geometry that contains all the points in this LineBaseShape and input LineBaseShape set. |
Validate | ShapeValidationMode | BaseShape | This method returns a ShapeValidationResult based on a series of tests. |
BufferCore | Double, Int32, BufferCapType, GeographyUnit, DistanceUnit | BaseShape | This method computes the area containing all of the points within a given distance from this shape. |
CloneDeepCore | BaseShape(overriden) | This method returns a complete copy of the shape without any references in common. | |
ContainsCore | BaseShape | BaseShape | This method returns if the targetShape lies within the interior of the current shape. |
ConvexHullCore | LineBaseShape | This method returns the convex hull of the shape defined as the smallest convex ring that contains all the points in the shape. | |
CrossesCore | BaseShape | BaseShape | This method returns if the current shape and the targetShape share some but not all interior points. |
GetBoundingBoxCore | BaseShape(overriden) | This method calculates the smallest RectangleShape that encompasses the entire geometry. | |
GetCenterPointCore | BaseShape | This method returns the center point of the current shape's bounding box. | |
GetClosestPointToCore | BaseShape, GeographyUnit | BaseShape(overriden) | This method returns the point of the current shape that is closest to the target shape. |
GetCrossingCore | BaseShape | BaseShape(overriden) | This method returns the crossing points between the current shape and the passed-in target shape. |
GetDistanceToCore | BaseShape, GeographyUnit, DistanceUnit | BaseShape(overriden) | This method computes the distance between the current shape and the targetShape. |
GetIntersectionCore | AreaBaseShape | LineBaseShape | |
GetLengthCore | GeographyUnit, DistanceUnit | LineBaseShape(overriden) | This method returns the length of the LineShape. |
GetLineOnALineCore | PointShape, PointShape | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetLineOnALineCore | StartingPoint, Double, Double, GeographyUnit, DistanceUnit | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetLineOnALineCore | StartingPoint, Single | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetLineOnALineCore | StartingPoint, PointShape | This method returns a BaseLineShape, based on a starting position and other factors. | |
GetPointOnALineCore | StartingPoint, Double, GeographyUnit, DistanceUnit | This method returns a PointShape on the line, based on a distance on the line from the first or last vertex (as defined by the startingPoint parameter). | |
GetPointOnALineCore | StartingPoint, Single | This method returns a PointShape on the line, based on a percentage of the length of the line from the first or last vertex (as defined by the startingPoint parameter). | |
GetShortestLineToCore | BaseShape, GeographyUnit | BaseShape | This method returns the shortest LineShape between this shape and the targetShape parameter. |
GetWellKnownBinaryCore | WkbByteOrder | BaseShape(overriden) | This method returns a byte array that represents the shape in well known binary. |
GetWellKnownTextCore | BaseShape(overriden) | This method returns the well-known text representation of this shape. | |
GetWellKnownTypeCore | BaseShape(overriden) | This method returns the well-known type for the shape. | |
IntersectsCore | BaseShape | BaseShape | This method returns if the current shape and the targetShape have at least one point in common. |
IsDisjointedCore | BaseShape | BaseShape | This method returns if the current shape and the targetShape have no points in common. |
IsTopologicallyEqualCore | BaseShape | BaseShape | This method returns if the current shape and the targetShape are topologically equal. |
IsWithinCore | BaseShape | BaseShape | This method returns if the current shape lies within the interior of the targetShape. |
LoadFromWellKnownDataCore | String | BaseShape(overriden) | This method hydrates the current shape with its data from well-known text. |
LoadFromWellKnownDataCore | Byte[] | BaseShape(overriden) | This method hydrates the current shape with its data from well-known binary. |
MemberwiseClone | Object | ||
OverlapsCore | BaseShape | BaseShape | This method returns if the current shape and the targetShape share some but not all points in common. |
RegisterCore | PointShape, PointShape, DistanceUnit, GeographyUnit | BaseShape(overriden) | This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes. |
ReorderCore | PointShape, Double, GeographyUnit, DistanceUnit | This API is used to make the lines within the Multiline ordered. | |
RotateCore | PointShape, Single | BaseShape(overriden) | This method rotates the shape a number of degrees based on a pivot point. |
ScaleDownCore | Double | LineBaseShape(overriden) | This method decreases the size of the LineShape by the percentage given in the percentage parameter. |
ScaleToCore | Double | BaseShape | |
ScaleUpCore | Double | LineBaseShape(overriden) | This method increases the size of the LineShape by the percentage given in the percentage parameter. |
SimplifyCore | Double, SimplificationType | LineBaseShape | Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType. |
TouchesCore | BaseShape | BaseShape | This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points. |
TranslateByDegreeCore | Double, Double, GeographyUnit, DistanceUnit | BaseShape(overriden) | This method moves the base shape from one location to another based on a distance and a direction in degrees. |
TranslateByOffsetCore | Double, Double, GeographyUnit, DistanceUnit | BaseShape(overriden) | This method returns a BaseLineShape, based on a starting position and other factors. |
UnionCore | IEnumerable<LineBaseShape> | LineBaseShape | The protected virtual method used by “Union” that you can overwrite to implement your own logic. |
ValidateCore | ShapeValidationMode | BaseShape(overriden) | This method returns a ShapeValidationResult based on a series of tests. |
CanRotate | Boolean | BaseShape(overriden) | This property specifies whether the shape can be rotated. |
Id | String | BaseShape | The id of the shape. |
Lines | Collection<LineShape> | This property is the collection of lines that make up the MultilineShape. | |
Tag | Object | BaseShape | The tag of the shape. |
This overload creates the MultilineShape without any points.
| lineShapes | IEnumerable<LineShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.LineShape} –> |
This constructor allows you to build the shape from well-known text.
| wellKnownText | String<!– System.String –> | This parameter is the well-known text used to build the shape. |
This constructor allows you to build the shape from well-known binary.
| wellKnownBinary | Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.multilineshape –> | This parameter is the well-known binary used to build the shape. |
| MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> | The return type is a MultiPolygonShape that represents all of the points within a given distance from the shape. |
| distance | Double<!– System.Double –> | The distance is the number of units to buffer the current shape. The distance unit will be the one specified in the distanceUnit paramater. The distance must be greater than 0. |
| quadrantSegments | Int32<!– System.Int32 –> | The quadrant segments are the number of points in each quarter circle. A good default is 8, but if you want smoother edges you can increase this number. The valid range for this number is from 3 to 100. |
| bufferCapType | BufferCapType<!– ThinkGeo.MapSuite.WindowsPhoneCore.BufferCapType –> | The bufferCapType determines how the caps of the buffered object look. They range from rounded to squared off. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | This is the geographic unit of the shape you are performing the operation on. |
| distanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This is the distance unit you would like to use as the distance. For example, if you select miles as your distanceUnit, then the distance will be calculated in miles for the operation. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> Go Back
This method computes the area containing all of the points within a given distance from this shape. In this case, you will be using the rounded RoundedBufferCapStyle and the default 8 quadrant segments. The distance unit is determined by the distanceUnit argument.
| distance | Double<!– System.Double –> | The distance is the number of units to buffer the current shape. The distance unit will be the one specified in the distanceUnit parameter. The distance must be greater than 0. |
This method computes the area containing all of the points within a given distance from this shape. In this case, you will be using the rounded RoundedBufferCapStyle. The distance unit is determined by the distanceUnit argument.
| BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This method returns a complete copy of the shape without any references in common. |
| Boolean<!– System.Boolean –> | This method returns if the targetFeature lies within the interior of the current shape. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | The targetFeature that contains a shape you wish to compare the current one to. |
| Boolean<!– System.Boolean –> | This method returns if the targetShape lies within the interior of the current shape. |
| targetShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | The shape you wish to compare the current one to. |
This method is useful when you want to create a perimeter around the shape. For example if you had a MultiPolygon which represented buildings in a campus you could easily get the convex hull of the buildings and determine the perimeter of all of the buildings together. This also works with MultiPoint shapes where each point may represent a certain type of person you are doing statistics on. With convex hull you can get an idea of the regions those points are located in.
As this is a concrete public method that wraps a Core method we reserve the right to add events and other logic to pre or post process data returned by the Core version of the method. In this way we leave our framework open on our end but also allow you the developer to extend our logic to your needs. If you have questions about this please contact support as we would be happy to work with you on extending our framework.
| RingShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RingShape –> | This method returns a RingShape defined as the smallest convex ring that contains all the points in the shape. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> Go Back
<!– static –> This method creates a BaseShape from a string of well-known binary.
This method creates a BaseShape from a string of well-known binary. Well-known binary allows you to describe geometries as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well-known text as well.
| BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | The return type is a higher level shape constructed from the well-known binary you passed into the method. Though the object is a higher level shape, such as a PolygonShape or MultiPointShape, you will need to cast it to that shape in order to use its unique properties. |
| wellKnownBinary | Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.multilineshape –> | An array of bytes representing the geometry in well-known binary format. |
<!– static –> This method creates a BaseShape from a string of well-known text.
This method creates a BaseShape from a string of well-known text. Well-known text allows you to describe geometries as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometries.
POINT(5 17)
LINESTRING(4 5,10 50,25 80)
POLYGON1)
MULTIPOINT(3.7 9.7,4.9 11.6)
MULTILINESTRING2)
| BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | The return type is a higher level shape constructed from the well-known text you passed into the method. Though the object is a higher level shape, such as a PolygonShape or MultiPointShape, you will need to cast it to that shape in order to use its unique properties. |
| wellKnownText | String<!– System.String –> | A string representing the geometry in well-known text format. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetFeature share some but not all interior points. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetShape share some but not all interior points. |
The GetBoundingBox method calculates the smallest RectangleShape that can encompass the entire geometry by examining each point in the geometry.
Depending on the number of PointShapes and complexity of the geometry, this operation can take longer for larger objects.
If the shape is a PointShape, then the bounding box's upper left and lower right points will be equal. This will create a RectangleShape with no area.
| RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> | The RectangleShape returned is the smallest RectangleShape that can encompass the entire geometry. |
This method returns the center point of the current shape's bounding box. It is important to note that this is the center point of the bounding box. There are numerous ways to calculate the “center” of a geometry, such as its weighted center, etc. You can find other centers by examining the various methods of the shape itself.
| PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | A PointShape representing the center point of the current shape's bounding box. |
| PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | A PointShape representing the closest point of the current shape to the targetShape. |
| targetShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | The shape you are trying to find the closest point to. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | The geographic unit of the shape you are trying to find the closet point to. |
This method returns the point of the current shape that is closest to the target feature. It is often the case that the point returned is not a point of the object itself. An example would be a line with two points that are far apart from each other. If you set the targetFeature to be a point midway between the points but a short distance away from the line, the method would return a point that is on the line but not either of the two points that make up the line.
| PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | A PointShape representing the closest point of the current shape to the targetFeature. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | The feature you are trying to find the closest point to. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | The geographic unit of the feature you are trying to find the closet point to. |
| MultipointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipointShape –> | This method returns the crossing points between the current shape and the passed-in target shape. |
| targetShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | The target shape you wish to get crossing points with. |
In this method we compute the closest distance between the two shapes. The returned unit will be in the unit of distance specified.
| Double<!– System.Double –> | The return type is the distance between this shape and the targetShape in the GeographyUnit of the shape. |
| targetShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | The shape you are trying to find the distance to. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | This parameter is the unit of the shape you are getting the distance to. |
| distanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This parameter is the unit of the distance you want the return value to be in. |
In this method we compute the closest distance between a shape and a feature. The returned unit will be in the unit of distance specified.
| Double<!– System.Double –> | The return type is the distance between this shape and the targetFeature in the GeographyUnit of the shape. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | The feature you are trying to find the distance to. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | This parameter is the unit of the shape which is contained in the targetFeature you are getting the distance to. |
| Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | The feature with the same Id and BaseShape as the current BaseShape, and with empty columnValues in it. |
| Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | The feature with the same Id and BaseShape as the current BaseShape and with empty columnValues in it, substituted with the passed-in columnValues. |
| columnValues | IDictionary<String,String><!– System.Collections.Generic.IDictionary{System.String,System.String} –> | The columnValues will be passed into returning feature. |
| MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> |
| targetShape | AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> |
This is a useful method when you want to know the total length of a line-based shape. If the shape is a MultiLineShape, then the length is the sum of all of its lines.
| Double<!– System.Double –> | This overload returns the length in the unit of your choice, based on the returningUnit parameter specified. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | This is the GeographyUnit of the shape you are performing the operation on. |
| returningUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This is the distance unit you would like to use as the return value. For example, if you select miles as your returningUnit, then the distance will be returned in miles. |
This overload allows you to specify the starting point and another point.
| LineBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> | This method returns a BaseLineShape, based on a starting position and other factors. |
| startingPoint | StartingPoint<!– ThinkGeo.MapSuite.WindowsPhoneCore.StartingPoint –> | The startingPoint defines whether the method starts at the beginning or the end of the line. |
| endPointShape | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | The BaseLineShape returned will be between the startingPoint and the endPointShape specified in this parameter. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> Go Back
This overload allows you to pass in two points to get a BaseLineShape from the original MultilineShape.
| LineBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> | This method returns a BaseLineShape based on a start PointShape and an end PointShape. |
| startPointShape | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | The startPointShape defines where you will start to get the line. If it does not stand on this MultilineShape, the closest point on the MultilineShape will be the start PointShape. |
| endPointShape | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | The endPointShape defines where you will stop getting the line. If it does not stand on this MultilineShape, the closest point on the MultilineShape will be the end PointShape. |
This overload allows you to specify the starting point along with the starting distance. This allows you to get a certain distance of the line after the starting distance.
| startingDistance | Double<!– System.Double –> | The starting distance from where you will start getting the line. For example, if the line is 3 units long and you have a starting distance of 1 unit, the result will be the last two units of the line. Valid values must be greater than 0. The starting distance will be in the GeographyUnit of the shape. |
| distance | Double<!– System.Double –> | The amount of the line you want to get after the startingDistance. Valid values must be greater than 0. |
| distanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This is the DistanceUnit you would like to use for the distance parameter. For example, if you select miles as your distanceUnit, then the distance will be measured in miles. |
This overload allows you to pass the starting point, starting percentage of the line and percentage of the line.
| startingPercentageOfTheLine | Single<!– System.Single –> | This parameter defines the starting percentage into the line. Valid values must be greater than 0 and less than or equal to 100. |
| percentageOfTheLine | Single<!– System.Single –> | This parameter defines the percentage into the line. Valid values must be greater than 0 and less than or equal to 100. |
This overload allows you to pass the starting point and percentage of the line.
| percentageOfLine | Single<!– System.Single –> | This parameter defines the percentage into the line. Valid values must be greater than 0 and less than or equal to 100. |
This overload allows you to pass in a distance, which determines how far you want to move along the line. You can also choose whether to start from the beginning or the end of the line.
Passing in a distance of 0 will return either the first or last point on the line, depending on the value of the startingPoint parameter.
| PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | This method returns a PointShape on the line, based on a distance on the line from the first or last vertex (as defined by the startingPoint parameter). |
| distance | Double<!– System.Double –> | This parameter specifies the distance into the line you wish to move, in the unit of the shape itself. Valid values must be greater than or equal to 0. |
This overload allows you to pass a percentage determining how far you want to move along the line, as well as whether to start from the beginning or the end of the line.
If you pass 100 or 0 as the percentage of the line, it will return either the first or last vertex, depending on the value of the startingPoint argument.
| PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | This method returns a PointShape on the line, based on a percentage of the length of the line from either its first or last vertex (as defined by the startingPoint parameter). |
| percentageOfLine | Single<!– System.Single –> | This parameter defines the percentage into the line. Valid values are between 0 and 100. |
This method returns a LineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This effect is similar to what you might see on an international flight when the displayed flight path is curved.
| MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> | A LineShape representing the shortest distance between the shape you're calling the method on and the targetShape. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | The geographic unit of the Shape you are trying to find the distance to. |
This method returns a MultiLineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This is effect is similar to what you might see on an international flight when the displayed flight path is curved.
Overriding:
Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
| MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> | A MultiLineShape representing the shortest distance between the shape you're calling the method on and the targetFeature. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | The geographic unit of the feature you are trying to find the distance to. |
This method returns a byte array that represents the shape in well-known binary. Well-known binary allows you to describe geometries as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well known text as well.
| Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.multilineshape –> | This method returns a byte array that represents the shape in well-known binary. |
| byteOrder | WkbByteOrder<!– ThinkGeo.MapSuite.WindowsPhoneCore.WkbByteOrder –> | This parameter is the byte order used to encode the well-known binary. |
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe geometries as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometries.
POINT(5 17)
POLYGON5)
MULTILINESTRING6)
| String<!– System.String –> | This method returns a string that represents the shape in well-known text. |
| WellKnownType<!– ThinkGeo.MapSuite.WindowsPhoneCore.WellKnownType –> | This method returns the well-known type for the shape. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetFeature have at least one point in common. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | The targetFeature you wish to compare the current one to. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetShape have at least one point in common. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetFeature have no points in common. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | The feature you wish to compare the current one to. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetShape have no points in common. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework. |
Topologically equal means that the shapes are essentially the same. For example, let's say you have a line with two points, point A and point B. You also have another line that is made up of point A, point B and point C. Point A of line one shares the same vertex as point A of line two, and point B of line one shares the same vertex as point C of line two. They are both straight lines, so point B of line two would lie on the first line. Essentially the two lines are the same, with line 2 having just one extra point. Topologically they are the same line, so this method would return true.
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetShape are topologically equal. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetFeature are topologically equal. |
| Boolean<!– System.Boolean –> | This method returns if the current shape lies within the interior of the targetShape. |
| Boolean<!– System.Boolean –> | This method returns if the current shape lies within the interior of the targetFeature. |
| wellKnownText | String<!– System.String –> | This parameter is the well-known text you will use to hydrate your object. |
| wellKnownBinary | Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.multilineshape –> | This parameter is the well-known binary used to populate the shape. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetShape share some but not all points in common. |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetFeature share some but not all points in common. |
Registering allows you to take a geometric shape generated in a planar system and attach it to the ground in a Geographic Unit.
A common scenario is integrating geometric shapes from external programs (such as CAD software or a modeling system) and placing them onto a map. You may have the schematics of a building in a CAD system and the relationship between all the points of the building are in feet. You want to then take the CAD image and attach it to where it really exists on a map. You would use the register method to do this.
Registering is also useful for scientific modeling, where software models things such as a plume of hazardous materials or the fallout from a volcano. The modeling software typically generates these models in a fictitious planar system. You would then use the register to take the abstract model and attach it to a map with real coordinates.
| BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes. |
| fromPoint | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | This parameter is the anchor PointFeature in the coordinate of origin. |
| toPoint | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | This parameter is the anchor PointFeature in the coordinate of destination. |
| fromUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This parameter is the DistanceUnit of the coordinate of origin. |
| toUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | This parameter is the GeographyUnit of the coordinate of destination. |
| fromPoint | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | This parameter is the anchor PointShape in the coordinate of origin. |
| toPoint | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | This parameter is the anchor PointShape in the coordinate of destination. |
| selectedVertex | Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> |
<!– static –>
| selectedVertex | Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> | |
| multilineShape | MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> |
An ordered Multiline means that we can walk though the MultiLine from the first point to the last point without any branches, and that each line's end points should be within the given tolerance. If using this overload, the unit of the Multiline and the tolerance are both defaulted to meters. Please use the other overload if you want to specify the units yourself.
| Void<!– System.Void –> | Returns a re-ordered MultilineShape. |
| startPoint | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | This parameter specifies the start point of the resulting re-ordered MultilineShape. |
| tolerance | Double<!– System.Double –> | This parameter specifies the tolerance between each line among the lines in the Multiline. This parameter is very critial. If it is too large or too samll, the re-order cannot suceed. |
An ordered Multiline means that we can walk though the MultiLine from the first point to the last point without any branches, and that each line's end points should be within the given tolerance. When using this overload, you can specify the unit for the Multiline as well as the unit for the tolerance.
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | This parameter specifies the GeographicUnit for the Multineline. |
| unitOfTolerance | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This parameter specifies the distance unit used when considering the tolerance. |
This method returns a shape rotated by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape you can achieve in-place rotation. By moving the pivot point outside of the center of the shape you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
| pivotPoint | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | The pivotPoint represents the center of rotation. |
| degreeAngle | Single<!– System.Single –> | The number of degrees of rotation required, from 0 to 360. |
<!– static –> This method returns a feature rotated by a number of degrees based on a pivot point.
This method returns a feature rotated by a number of degrees based on a pivot point. By placing the pivot point in the center of the feature you can achieve in-place rotation. By moving the pivot point outside of the center of the feature you can translate the feature in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
| BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This method returns a shape rotated by a number of degrees based on a pivot point. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | This parameter is the basis for the rotation. |
<!– static –> This method returns a shape rotated by a number of degrees based on a pivot point.
| sourceBaseShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This parameter is the basis for the rotation. |
This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster as you apply the operation multiple times. There is also a ScaleUp method that will enlarge the shape as well.
| percentage | Double<!– System.Double –> | This is the percentage by which to decrease the shape’s size. |
<!– static –> This method returns a new shape that is decreases by the percentage given in the percentage parameter.
| LineBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> | a scaled down line type shape. |
| sourceLineBaseShape | LineBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> | This parameter is the basis for the scale up up but is not modified. |
<!– static –> This method returns a new feature that is decreases by the percentage given in the percentage parameter.
This method is useful when you would like to decrease the size of the feature. Note that a larger percentage will scale the shape down faster as you apply the operation multiple times. There is also a ScaleUp method that will enlarge the shape as well.
| Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | a scaled down line type feature. |
| sourceLine | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | This parameter is the basis for the scale up up but is not modified. |
| scale | Double<!– System.Double –> |
<!– static –>
| baseShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | |
<!– static –> This method returns a new feature that is increased by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the feature. Note that a larger percentage will scale the shape up faster as you apply the operation multiple times. There is also a ScaleDown method that will shrink the shape as well.
| Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | a scaled line type feature. |
| percentage | Double<!– System.Double –> | This is the percentage by which to increase the shape’s size. |
<!– static –> This method returns a new shape that is increased by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster as you apply the operation multiple times. There is also a ScaleDown method that will shrink the shape as well.
| LineBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> | a scaled line type shape. |
| sourceShape | LineBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> | This parameter is the basis for the scale up up but is not modified. |
| MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> | Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType. |
| tolerance | Double<!– System.Double –> | distance tolerance |
| simplificationType | SimplificationType<!– ThinkGeo.MapSuite.WindowsPhoneCore.SimplificationType –> | Specifies which algorthm will be use to simplify. |
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | the geography unit of the target shape |
| toleranceUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | the distance unit of tolerance |
<!– static –> Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType.
| targetShape | LineBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> | target shape which will be simplified. |
| targetShapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | the geography unit of the target shape |
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points. |
| Boolean<!– System.Boolean –> | This method returns of the current shape and the targetFeature have at least one boundary point in common, but no interior points. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | The targetFeature which contains a shape that you wish to compare the current one to. |
<!– static –> This method returns a shape repositioned from one location to another based on a distance and a direction in degrees.
This method returns a shape repositioned from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this shape a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
If you pass a distance of 0, then the operation is ignored.
| BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This method returns a shape repositioned from one location to another based on a distance and a direction in degrees. |
| targetShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This parameter is the basis of the move. |
| distance | Double<!– System.Double –> | The distance is the number of units to move the shape using the angle specified. The distance unit will be the one specified in the distanceUnit parameter. The distance must be greater than or equal to 0. |
| angleInDegrees | Double<!– System.Double –> | A number between 0 and 360 degrees that represents the direction you wish to move the shape, with 0 being up. |
| distanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This is the distance unit you would like to use as the measure for the move. For example, if you select miles as your distance unit, then the distance will be calculated in miles. |
<!– static –> This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees.
This method returns a feature repositioned from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this feature a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
| BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | This parameter is the basis of the move. |
| distance | Double<!– System.Double –> | The distance is the number of units to move the shape using the angle specified. The distance unit will be the DistanceUnit specified in the distanceUnit parameter. The distance must be greater than or equal to 0. |
| angleInDegrees | Double<!– System.Double –> | A number between 0 and 360 degrees that represents the direction you wish to move the feature, with 0 being up. |
This method moves a base shape from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this shape a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
| distanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This is the DistanceUnit you would like to use as the measure of the translate. For example if you select miles as your distanceUnit then the distance will be calculated in miles. |
| xOffsetDistance | Double<!– System.Double –> | |
| yOffsetDistance | Double<!– System.Double –> |
<!– static –> This method returns a feature repositioned from one location to another based on an X and Y offset distance.
This method returns a feature repositioned from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
| Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | This method returns a feature repositioned from one location to another based on an X and Y offset distance. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> | This parameter is the basis of the moved feature. |
| xOffsetDistance | Double<!– System.Double –> | This is the number of horizontal units of movement in the distance unit specified in the distanceUnit parameter. |
| yOffsetDistance | Double<!– System.Double –> | This is the number of horizontal units of movement in the distance unit specified in the distanceUnit parameter. |
| distanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This is the distance unit you would like to use as the measure for the move. For example, if you select miles as your distance unit, then the xOffsetDistance and yOffsetDistance will be calculated in miles. |
This method moves a base shape from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | This is the geographic unit of the base shape you are performing the operation on. |
<!– static –> This method returns a shape repositioned from one location to another based on an X and Y offset distance.
This method returns a shape repositioned from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
| BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This method returns a shape repositioned from one location to another based on an X and Y offset distance. |
| targetShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | This parameter is the basis of the moved shape. |
| yOffsetDistance | Double<!– System.Double –> | This is the number of vertical units of movement in the distance unit specified in the distanceUnit parameter. |
| MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> | A set combining the points of this LineBaseShape and the points of input LineBaseShape. |
| targetShape | LineBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape –> | The target LineBasheShape with which to compute the union |
<!– static –>
| targetFeatures | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> |
<!– static –> Calculates a new geometry that contains all the points in this LineBaseShape and input LineBaseShape set.
| MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> | A set combining the points of this LineBaseShape and the points of input LineBaseShape set. |
| lineBaseShapes | IEnumerable<LineBaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape} –> |
| ShapeValidationResult<!– ThinkGeo.MapSuite.WindowsPhoneCore.ShapeValidationResult –> | This method returns a ShapeValidationResult based on a series of tests. |
| validationMode | ShapeValidationMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.ShapeValidationMode –> | This parameter determines whether the test is simple or advanced. In some cases, the advanced tests can take some time. The simple test is designed to always be fast. |
Overriding:
| quadrantSegments | Int32<!– System.Int32 –> | The number of quadrantSegments used in the buffer logic. |
| bufferCapType | BufferCapType<!– ThinkGeo.MapSuite.WindowsPhoneCore.BufferCapType –> | The bufferCapType used in the buffer logic. |
When you override this method, you need to ensure that there are no references in common between the original and the copy.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape(overriden) –> Go Back
Overriding:
This method is useful when you want to create a perimeter around the shape. For example, if you had a MultiPolygon that represented buildings on a campus, you could easily get the convex hull of the buildings and determine the perimeter of all of the buildings together. This also works with MultiPoint shapes, where each point may represent a certain type of person you are doing statistics on. With convex hull, you can get an idea of the regions those points are located in.
Overriding:
Overriding:
Overriding:
| targetShape | BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> | The target shape you wish to get crossing with. |
| Double<!– System.Double –> | This method returns the distance between the current shape and the targetShape. |
This overload returns the length in the GeographyUnit of the shape.
This method is useful when you want to know the total length of a line-based shape. If the shape is a MultilineShape, then the length is the sum of all of its lines. There is also an overload which allows you to specify the returning length in the unit of your choice.
| Double<!– System.Double –> | The returned length is in the GeographyUnit of the shape. |
| returningUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | This is the DistanceUnit you would like to use for the distance parameter. For example, if you select miles as your returningUnit, then the distance will be returned in miles. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape(overriden) –> Go Back
| PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | This method returns a PointShape on the line, based on a percentage of the length of the line from the first or last vertex (as defined by the startingPoint parameter). |
This method returns a LineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This is effect is similar to what you might see on an international flight when the displayed flight path is curved.
Overriding:
| shapeUnit | GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> | The geographic unit of the shape you are trying to find the distance to. |
This method returns a byte array that represents the shape in well-known binary. Well-known binary allows you to describe a geometry as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well-known text as well.
| Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.multilineshape –> | This method returns a byte array that represents the shape in well known binary. |
| byteOrder | WkbByteOrder<!– ThinkGeo.MapSuite.WindowsPhoneCore.WkbByteOrder –> | This parameter specifies whether the byte order is big- or little-endian. |
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe a geometry as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometric shapes.
POINT(5 17)
POLYGON9)
MULTILINESTRING10)
Overriding:
Overriding:
| Boolean<!– System.Boolean –> | This method returns if the current shape and the targetShape have no points in common. |
Overriding:
Overriding:
Overriding:
This method rotates the shape by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape, you can achieve in-place rotation. By moving the pivot point outside of the center of the shape, you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
| degreeAngle | Single<!– System.Single –> | The number of degrees of rotation required from 0 to 360. |
This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster, as you are applying the operation multiple times. There is also a ScaleUp method that will enlarge the shape.
| percentage | Double<!– System.Double –> | This is the percentage by which to decrease the shape's size. |
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster, as you are applying the operation multiple times. There is also a ScaleDown method that will shrink the shape.
| percentage | Double<!– System.Double –> | This is the percentage by which to increase the shape's size. |
Overriding:
In this overload, the distance is in the same GeographicUnit as the shape.
This method moves the base shape from one location to another, based on an angleInDegrees and distance parameter. With this overload, it is important to note that the distance units are the same GeographicUnit as the shape. For example, if your shape is in decimal degrees and you call this method with a distance of 1, you're going to move this shape 1 decimal degree in direction of the angleInDegrees. In many cases it is more useful to specify the DistanceUnit of movement, such as in miles or yards, so for these scenarios there is another overload you may want to use instead.
| distance | Double<!– System.Double –> | The distance is the number of units to move the shape in the angle specified. The distance unit will be the same as the GeographyUnit for the shape. The distance must be greater than or equal to 0. |
| Void<!– System.Void –> | This method returns a BaseLineShape, based on a starting position and other factors. |
| xOffsetDistance | Double<!– System.Double –> | This is the number of horizontal units of movement in the DistanceUnit specified in the distanceUnit parameter. |
| yOffsetDistance | Double<!– System.Double –> | This is the number of vertical units of movement in the DistanceUnit specified in the distanceUnit parameter. |
| lineBaseShapes | IEnumerable<LineBaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.LineBaseShape} –> | The target LineBasheShape set with which to compute the union |
| Collection<LineShape><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.LineShape} –> |
