<!– Enumeration –> This enumeration describes the type of validation test to run on shapes.
The simple tests are used internally before any method call is made to a shape. In this way, we have a certain level of confidence that the operation will succeed. The advanced tests are meant to be performed by users if they get a shape from an external source and consider it suspect.
| Name | Summary |
| Simple | The simple tests are designed to be very fast. |
| Advanced | The advanced tests are designed to be comprehensive with no regard to speed. |
