thinkgeo.mapsuite.windowsphonecore.buffercaptype
ThinkGeo.MapSuite.WindowsPhoneCore.BufferCapType
<!– Enumeration –> This class represents various ways a buffer operation can cap the objects buffered.
Buffered shapes can be computed with different line-end buffer cap styles. The buffer cap style determines how the line-work for the buffer polygon is constructed at the ends of lines.
Items
Name Summary
Round End caps are rounded at the line ends.
Square End caps are truncated flat at the line ends.
Butt End caps are squared off at the buffer distance beyond the line ends.
thinkgeo.mapsuite.windowsphonecore.buffercaptype.txt · Last modified: 2017/03/16 21:59 (external edit)
