thinkgeo.mapsuite.windowsphonecore.gradientstyle
ThinkGeo.MapSuite.WindowsPhoneCore.GradientStyle
<!– Class –> This gradient style is a new style with the concept of GradientBrush. By specifying the LowerValue and its color, as well as the UpperValue and its color, we can set the color of each feature based on a column value using linear interpolation.
Public MethodGradientStyle String, Double, GeoSolidBrush, Double, GeoSolidBrush This constructor creates a new instance by passing the ColumnName (which it will get the data from) as well as the lowerValue and its corresponding SolidBrush, and the upperValue and its corresponding SolidBrush.
Public MethodGradientStyle String, Double, GeoSolidBrush, Double, GeoSolidBrush, Double, GeoSolidBrush This constructor creates a new instance by passing the ColumnName (which it will get the data from) as well as the lowerValue and its corresponding SolidBrush, the upperValue and its corresponding SolidBrush, and the NoDataValue and its corresponding SolidBrush.
Public MethodDraw IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the shapes on the canvas you provided.
Public MethodDraw IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the features on the canvas you provided.
Public MethodDrawSample GeoCanvas, DrawingRectangleF Style
Public MethodGetRequiredColumnNames Style This method returns the column data for each feature that is required for the style to properly draw.
Public MethodGetType Object
Public MethodToString Object
Protected MethodDrawCore IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style(overriden) This method draws the features on the canvas you provided.
Protected MethodDrawSampleCore GeoCanvas, DrawingRectangleF Style
Protected MethodGetRequiredColumnNamesCore Style(overriden) This method returns the column data for each feature that is required for the style to properly draw.
Public PropertyColumnName String This property gets and sets the column name used in the style.
Public PropertyIsActive Boolean Style This property gets and sets the active status of the style.
Public PropertyLowerGeoSolidBrush GeoSolidBrush This property gets and sets the solid brush that is used for the style's lower value.
Public PropertyLowerValue Double This property gets and sets the lower value used in the style.
Public PropertyName String Style This property gets and set the name of the style.
Public PropertyNoDataSolidBrush GeoSolidBrush This property gets and sets the solid brush that is used for the style's NoDataValue.
Public PropertyNoDataValue Double This property gets and sets the no data value used in the style.
Public PropertyRequiredColumnNames Collection<String> Style This property gets the collection of fields that are required for the style.
Public PropertyUpperGeoSolidBrush GeoSolidBrush This property gets and sets the solid brush that is used for the style's upper value.
Public PropertyUpperValue Double This property gets and sets the upper value used in the style.
GradientStyle(String, Double, GeoSolidBrush, Double, GeoSolidBrush)
In this constructor, the NoDataValue defaults to -9999 and the NoDataBrush color is transparent.
Name Type Description
columnName String<!– System.String –>
lowerValue Double<!– System.Double –>
lowerGeoSolidBrush GeoSolidBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush –>
upperValue Double<!– System.Double –>
upperGeoSolidBrush GeoSolidBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush –>
Go Back
GradientStyle(String, Double, GeoSolidBrush, Double, GeoSolidBrush, Double, GeoSolidBrush)
noDataValue Double<!– System.Double –>
noDataSolidBrush GeoSolidBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush –>
Go Back
Draw(IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
Return Type Description
Void<!– System.Void –>
shapes IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape} –> This parameter represents the shapes you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter represents the canvas you want to draw the shapes on.
labelsInThisLayer Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> The labels will be drawn in the current layer only.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> The labels will be drawn in all layers.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style –> Go Back
Draw(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This parameter represents the features you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter represents the canvas you want to draw the features on.
DrawSample(GeoCanvas, DrawingRectangleF)
drawingExtent DrawingRectangleF<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingRectangleF –>
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetRequiredColumnNames()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> This method returns a collection of column names that the style needs.
Type<!– System.Type –>
DrawCore(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
This virtual method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When implementing this virtual method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style(overriden) –> Go Back
DrawSampleCore(GeoCanvas, DrawingRectangleF)
GetRequiredColumnNamesCore()
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
ColumnName
None.
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GradientStyle –> Go Back
IsActive
Return Type
LowerGeoSolidBrush
None.
Return Type
LowerValue
None.
Return Type
Return Type
NoDataSolidBrush
None.
Return Type
NoDataValue
None.
Return Type
RequiredColumnNames
Return Type
UpperGeoSolidBrush
None.
Return Type
UpperValue
None.
Return Type
thinkgeo.mapsuite.windowsphonecore.gradientstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
