thinkgeo.mapsuite.windowsphonecore.ellipseshape
Table of Contents
ThinkGeo.MapSuite.WindowsPhoneCore.EllipseShape
<!– Class –> This class represents an ellipse that is defined with a center point, a height and a width.
Public MethodEllipseShape This constructor creates the EllipseShape.
Public MethodEllipseShape PointShape, Double This constructor creates the EllipseShape.
Public MethodEllipseShape Feature, Double This constructor creates the EllipseShape.
Public MethodEllipseShape PointShape, Double, Double This constructor creates the EllipseShape.
Public MethodEllipseShape Feature, Double, Double This constructor creates the EllipseShape.
Public MethodEllipseShape String This constructor creates the EllipseShape.
Public MethodEllipseShape Byte[] This constructor creates the EllipseShape.
Public MethodEllipseShape PointShape, Double, GeographyUnit, DistanceUnit This constructor creates the EllipseShape.
Public MethodEllipseShape Feature, Double, GeographyUnit, DistanceUnit This constructor creates the EllipseShape.
Public MethodEllipseShape PointShape, Double, Double, GeographyUnit, DistanceUnit This constructor creates the EllipseShape.
Public MethodEllipseShape Feature, Double, Double, GeographyUnit, DistanceUnit This constructor creates the EllipseShape.
Public MethodBuffer Double, Int32, GeographyUnit, DistanceUnit BaseShape This method computes the area containing all of the points within a given distance from this shape.
Public MethodBuffer Double, Int32, BufferCapType, GeographyUnit, DistanceUnit BaseShape This method computes the area containing all of the points within a given distance from this shape.
Public MethodBuffer Double, GeographyUnit, DistanceUnit BaseShape This method computes the area containing all of the points within a given distance from this shape.
Public MethodCloneDeep BaseShape This method returns a complete copy of the shape without any references in common.
Public MethodContains Feature BaseShape This method returns if the targetFeature lies within the interior of the current shape.
Public MethodContains BaseShape BaseShape This method returns if the targetShape lies within the interior of the current shape.
Public MethodStatic MemberCreateShapeFromWellKnownData String BaseShape This method creates a BaseShape from a string of well-known text.
Public MethodStatic MemberCreateShapeFromWellKnownData Byte[] BaseShape This method creates a BaseShape from a string of well-known binary.
Public MethodCrosses BaseShape BaseShape This method returns if the current shape and the targetShape share some but not all interior points.
Public MethodCrosses Feature BaseShape This method returns if the current shape and the targetFeature share some but not all interior points.
Public MethodGetArea GeographyUnit, AreaUnit AreaBaseShape This method returns the area of the shape, defined as the size of the region enclosed by the figure.
Public MethodGetBoundingBox BaseShape This method calculates the smallest RectangleShape that encompasses the entire geometry.
Public MethodGetCenterPoint BaseShape This method returns the center point of the current shape's bounding box.
Public MethodGetClosestPointTo BaseShape, GeographyUnit BaseShape This method returns the point of the current shape that is closest to the target shape.
Public MethodGetClosestPointTo Feature, GeographyUnit BaseShape This method returns the point of the current shape that is closest to the target feature.
Public MethodGetConvexHull AreaBaseShape This method returns the convex hull of the shape, defined as the smallest convex ring that contains all of the points in the shape.
Public MethodGetCrossing BaseShape BaseShape This method returns the crossing points between the current shape and the passed-in target shape.
Public MethodGetDifference AreaBaseShape AreaBaseShape This method returns the difference between two shapes, defined as the set of all points which lie in the current shape but not in the targetShape.
Public MethodGetDifference Feature AreaBaseShape This method returns the difference between current shape and the specified feature, defined as the set of all points which lie in the current shape but not in the targetShape.
Public MethodGetDistanceTo Feature, GeographyUnit, DistanceUnit BaseShape This method computes the distance between the current shape and the targetFeature.
Public MethodGetDistanceTo BaseShape, GeographyUnit, DistanceUnit BaseShape This method computes the distance between the current shape and the targetShape.
Public MethodGetFeature BaseShape Get a corresponding feature which has the same Id and BaseShape as the current shape.
Public MethodGetFeature IDictionary<String, String> BaseShape Get a corresponding feature which has the same Id and BaseShape as the current shape. Additionally, pass the specified columnValues into the returned feature.
Public MethodGetHeightByUnit GeographyUnit, DistanceUnit This method returns the height of the EllipseShape in the unit specified in the returningUnit parameter.
Public MethodGetIntersection AreaBaseShape AreaBaseShape This method returns the intersection of the current shape and the target shape, defined as the set of all points which lie in both the current shape and the target shape.
Public MethodGetIntersection Feature AreaBaseShape This method returns the intersection of the current shape and the target feature, defined as the set of all points which lie in both the current shape and the target feature.
Public MethodGetPerimeter GeographyUnit, DistanceUnit AreaBaseShape This method returns the perimeter of the shape, defined as the sum of the lengths of all its sides.
Public MethodGetShortestLineTo Feature, GeographyUnit BaseShape This method returns the shortest LineShape between this shape and the targetFeature. parameter.
Public MethodGetShortestLineTo BaseShape, GeographyUnit BaseShape This method returns the shortest LineShape between this shape and the targetShape parameter.
Public MethodGetSymmetricalDifference AreaBaseShape AreaBaseShape This method returns the symmetrical difference between two shapes, defined as the set of all points which lie in the current shape or the targetShape but not both.
Public MethodGetSymmetricalDifference Feature AreaBaseShape This method returns the symmetrical difference between current shape and the specified feature, defined as the set of all points which lie in the current shape or the targetFeature but not both.
Public MethodGetTangents EllipseShape This method returns the tangent points of the current ellipse in relation to the target ellipse you specify.
Public MethodGetType Object
Public MethodGetWellKnownBinary WkbByteOrder BaseShape This method returns a byte array that represents the shape in well-known binary.
Public MethodGetWellKnownBinary BaseShape This method returns a byte array that represents the shape in well-known binary.
Public MethodGetWellKnownText BaseShape This method returns the well-known text representation of this shape.
Public MethodGetWellKnownType BaseShape This method returns the well-known type for the shape.
Public MethodGetWidthByUnit GeographyUnit, DistanceUnit This method returns the width of the EllipseShape in the unit specified in the returningUnit parameter.
Public MethodIntersects BaseShape BaseShape This method returns if the current shape and the targetShape have at least one point in common.
Public MethodIntersects Feature BaseShape This method returns if the current shape and the targetFeature have at least one point in common.
Public MethodIsDisjointed BaseShape BaseShape This method returns if the current shape and the targetShape have no points in common.
Public MethodIsDisjointed Feature BaseShape This method returns if the current shape and the targetFeature have no points in common.
Public MethodIsTopologicallyEqual Feature BaseShape This method returns if the current shape and the targetFeature are topologically equal.
Public MethodIsTopologicallyEqual BaseShape BaseShape This method returns if the current shape and the targetShape are topologically equal.
Public MethodIsWithin Feature BaseShape This method returns if the current shape lies within the interior of the targetFeature.
Public MethodIsWithin BaseShape BaseShape This method returns if the current shape lies within the interior of the targetShape.
Public MethodLoadFromWellKnownData String BaseShape This method hydrates the current shape with its data from well-known text.
Public MethodLoadFromWellKnownData Byte[] BaseShape This method hydrates the current shape with its data from well-known binary.
Public MethodOverlaps BaseShape BaseShape This method returns if the current shape and the targetShape share some but not all points in common.
Public MethodOverlaps Feature BaseShape This method returns if the current shape and the targetFeature share some but not all points in common.
Public MethodRegister PointShape, PointShape, DistanceUnit, GeographyUnit BaseShape This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Public MethodRegister Feature, Feature, DistanceUnit, GeographyUnit BaseShape This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Public MethodStatic MemberRotate BaseShape, PointShape, Single BaseShape This method returns a shape rotated by a number of degrees based on a pivot point.
Public MethodStatic MemberRotate Feature, PointShape, Single BaseShape This method returns a feature rotated by a number of degrees based on a pivot point.
Public MethodRotate PointShape, Single BaseShape This method rotates a shape a number of degrees based on a pivot point.
Public MethodStatic MemberScaleDown Feature, Double AreaBaseShape This method returns a new area feature that has been scaled down by the percentage given in the percentage parameter.
Public MethodStatic MemberScaleDown AreaBaseShape, Double AreaBaseShape This method returns a new area shape that has been scaled down by the percentage given in the percentage parameter.
Public MethodScaleDown Double AreaBaseShape This method decreases the size of the area shape by the percentage given in the percentage parameter.
Public MethodStatic MemberScaleTo BaseShape, Double BaseShape
Public MethodScaleTo Double BaseShape
Public MethodStatic MemberScaleUp AreaBaseShape, Double AreaBaseShape This method returns a new area shape that has been scaled up by the percentage given in the percentage parameter.
Public MethodScaleUp Double AreaBaseShape This method increases the size of the area shape by the percentage given in the percentage parameter.
Public MethodStatic MemberScaleUp Feature, Double AreaBaseShape This method returns a new area shape that has been scaled up by the percentage given in the percentage parameter.
Public MethodSetHeightByUnit Double, GeographyUnit, DistanceUnit This method allows you to set the height of the EllipseShape in the unit specified in the unitOfWidth.
Public MethodSetWidthByUnit Double, GeographyUnit, DistanceUnit This method allows you to set the width of the EllipseShape in the unit specified in the unitOfWidth parameter.
Public MethodSimplify GeographyUnit, Double, DistanceUnit, SimplificationType AreaBaseShape This method performed a simplification operation based on the parameters passed in. Simplify permanently alters the input geometry so that the geometry becomes topologically consistent.
Public MethodSimplify Double, SimplificationType AreaBaseShape This method performed a simplification operation based on the parameters passed in. Simplify permanently alters the input geometry so that the geometry becomes topologically consistent.
Public MethodStatic MemberSimplify AreaBaseShape, GeographyUnit, Double, DistanceUnit, SimplificationType AreaBaseShape This method performed a simplification operation based on the parameters passed in. Simplify permanently alters the input geometry so that the geometry becomes topologically consistent.
Public MethodStatic MemberSimplify AreaBaseShape, Double, SimplificationType AreaBaseShape This method performed a simplification operation based on the parameters passed in. Simplify permanently alters the input geometry so that the geometry becomes topologically consistent.
Public MethodStatic MemberSplit Feature, Feature AreaBaseShape This method returns a collection of Features split by the specified parameters.
Public MethodStatic MemberSplit AreaBaseShape, AreaBaseShape AreaBaseShape This method returns a collection of MultiPolygonShapes split by the specified parameters.
Public MethodToPolygon This method returns the current shape as a PolygonShape.
Public MethodToPolygon Int32 This method returns the current shape as a PolygonShape.
Public MethodToString Object
Public MethodTouches Feature BaseShape This method returns of the current shape and the targetFeature have at least one boundary point in common, but no interior points.
Public MethodTouches BaseShape BaseShape This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points.
Public MethodTranslateByDegree Double, Double, GeographyUnit, DistanceUnit BaseShape This method moves a base shape from one location to another based on a distance and a direction in degrees.
Public MethodTranslateByDegree Double, Double BaseShape This method moves a base shape from one location to another based on a distance and a direction in degrees.
Public MethodStatic MemberTranslateByDegree BaseShape, Double, Double, GeographyUnit, DistanceUnit BaseShape This method returns a shape repositioned from one location to another based on a distance and a direction in degrees.
Public MethodStatic MemberTranslateByDegree Feature, Double, Double, GeographyUnit, DistanceUnit BaseShape This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees.
Public MethodStatic MemberTranslateByOffset Feature, Double, Double, GeographyUnit, DistanceUnit BaseShape This method returns a feature repositioned from one location to another based on an X and Y offset distance.
Public MethodTranslateByOffset Double, Double BaseShape
Public MethodTranslateByOffset Double, Double, GeographyUnit, DistanceUnit BaseShape This method moves a base shape from one location to another based on an X and Y offset distance.
Public MethodStatic MemberTranslateByOffset BaseShape, Double, Double, GeographyUnit, DistanceUnit BaseShape This method returns a shape repositioned from one location to another based on an X and Y offset distance.
Public MethodStatic MemberUnion IEnumerable<AreaBaseShape> AreaBaseShape This method returns the union of the specified area shapes.
Public MethodUnion AreaBaseShape AreaBaseShape This method returns the union of the current shape and the target shape, defined as the set of all points in the current shape or the target shape.
Public MethodUnion Feature AreaBaseShape This method returns the union of the current shape and the target feature, defined as the set of all points in the current shape or the target feature.
Public MethodStatic MemberUnion IEnumerable<Feature> AreaBaseShape This method returns the union of the current shape and the target features, defined as the set of all points in the current shape or the target features.
Public MethodValidate ShapeValidationMode BaseShape This method returns a ShapeValidationResult based on a series of tests.
Protected MethodBufferCore Double, Int32, BufferCapType, GeographyUnit, DistanceUnit BaseShape This method computes the area containing all of the points within a given distance from this shape.
Protected MethodCloneDeepCore BaseShape(overriden) This method returns a complete copy of the shape without any references in common.
Protected MethodContainsCore BaseShape BaseShape(overriden) This method returns whether the targetShape lies within the interior of the current shape.
Protected MethodCrossesCore BaseShape BaseShape This method returns if the current shape and the targetShape share some but not all interior points.
Protected MethodGetAreaCore GeographyUnit, AreaUnit AreaBaseShape(overriden) This method returns the area of the shape, which is defined as the size of the region enclosed by the figure.
Protected MethodGetBoundingBoxCore BaseShape(overriden) This method calculates the smallest RectangleShape that encompasses the entire geometry.
Protected MethodGetCenterPointCore BaseShape This method returns the center point of the current shape's bounding box.
Protected MethodGetClosestPointToCore BaseShape, GeographyUnit BaseShape(overriden) This method returns the point of the current shape that is closest to the target shape.
Protected MethodGetConvexHullCore AreaBaseShape This method returns the convex hull of the shape, defined as the smallest convex ring that contains all of the points in the shape.
Protected MethodGetCrossingCore BaseShape BaseShape(overriden) This method returns the crossing points of the current shape and the passed-in target shape.
Protected MethodGetDifferenceCore AreaBaseShape AreaBaseShape This method returns the difference between two shapes, defined as the set of all points which lie in the current shape but not in the targetShape.
Protected MethodGetDistanceToCore BaseShape, GeographyUnit, DistanceUnit BaseShape(overriden) This method computes the distance between the current shape and the targetShape.
Protected MethodGetIntersectionCore AreaBaseShape AreaBaseShape This method returns the intersection of the current shape and the target shape, defined as the set of all points which lie in both the current shape and the target shape.
Protected MethodGetPerimeterCore GeographyUnit, DistanceUnit AreaBaseShape(overriden) This method returns the perimeter of the shape, which is defined as the sum of the lengths of all its sides.
Protected MethodGetShortestLineToCore BaseShape, GeographyUnit BaseShape This method returns the shortest LineShape between this shape and the targetShape parameter.
Protected MethodGetSymmetricalDifferenceCore AreaBaseShape AreaBaseShape This method returns the symmetrical difference between two shapes, defined as the set of all points which lie in the current shape or the targetShape but not both.
Protected MethodGetWellKnownBinaryCore WkbByteOrder, Int32 This method returns a byte array that represents the shape in well-known binary.
Protected MethodGetWellKnownBinaryCore WkbByteOrder BaseShape(overriden) This method returns a byte array that represents the shape in well-known binary.
Protected MethodGetWellKnownTextCore Int32 This method returns the well-known text representation of this shape.
Protected MethodGetWellKnownTextCore BaseShape(overriden) This method returns the well-known text representation of this shape.
Protected MethodGetWellKnownTypeCore BaseShape(overriden) This method returns the well-known type for the shape.
Protected MethodIntersectsCore BaseShape BaseShape(overriden) This method returns whether the current shape and the targetShape have at least one point in common.
Protected MethodIsDisjointedCore BaseShape BaseShape This method returns if the current shape and the targetShape have no points in common.
Protected MethodIsTopologicallyEqualCore BaseShape BaseShape This method returns if the current shape and the targetShape are topologically equal.
Protected MethodIsWithinCore BaseShape BaseShape This method returns if the current shape lies within the interior of the targetShape.
Protected MethodLoadFromWellKnownDataCore String BaseShape(overriden) This method hydrates the current shape with its data from well-known text.
Protected MethodLoadFromWellKnownDataCore Byte[] BaseShape(overriden) This method hydrates the current shape with its data from well-known binary.
Protected MethodOverlapsCore BaseShape BaseShape This method returns if the current shape and the targetShape share some but not all points in common.
Protected MethodRegisterCore PointShape, PointShape, DistanceUnit, GeographyUnit BaseShape(overriden) This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Protected MethodRotateCore PointShape, Single BaseShape(overriden) This method rotates the shape a number of degrees based on a pivot point.
Protected MethodScaleDownCore Double AreaBaseShape(overriden) This method decreases the size of the area shape by the percentage given in the percentage parameter.
Protected MethodScaleToCore Double BaseShape
Protected MethodScaleUpCore Double AreaBaseShape(overriden) This method increases the size of the area shape by the percentage given in the percentage parameter.
Protected MethodSimplifyCore Double, SimplificationType AreaBaseShape This method performed a simplification operation based on the parameters passed in. Simplify permanently alters the input geometry so that the geometry becomes topologically consistent.
Protected MethodTouchesCore BaseShape BaseShape This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points.
Protected MethodTranslateByDegreeCore Double, Double, GeographyUnit, DistanceUnit BaseShape(overriden) This method moves the base shape from one location to another based on a direction in degrees and distance.
Protected MethodTranslateByOffsetCore Double, Double, GeographyUnit, DistanceUnit BaseShape(overriden) This method moves the base shape from one location to another based on an X and Y offset distance.
Protected MethodUnionCore AreaBaseShape AreaBaseShape This method returns the union of the current shape and the target shapes, defined as the set of all points in the current shape or the target shape.
Protected MethodValidateCore ShapeValidationMode BaseShape(overriden) This method returns a ShapeValidationResult based on a series of tests.
Public PropertyCanRotate Boolean BaseShape(overriden) This property specifies whether the shape can be rotated.
Public PropertyCenter PointShape This property allows you to get or set the center PointShape of the EllipseShape.
Public PropertyHeight Double This property returns the height of the EllipseShape in the unit of the shape.
Public PropertyId String BaseShape The id of the shape.
Public PropertyTag Object BaseShape The tag of the shape.
Public PropertyWidth Double This property returns the width of the EllipseShape in the unit of the shape.
EllipseShape()
Overloads
This overload creates the EllipseShape with no area.
Name Type Description
Go Back
EllipseShape(PointShape, Double)
Overloads
This overload allows you to specify the center point along with the radius in the shape's unit. This overload will create a circle.
Using this overload will create a circle.
center PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the center PointShape for the EllipseShape.
radius Double<!– System.Double –> This parameter allows you to set the radius of the EllipseShape.
Go Back
EllipseShape(Feature, Double)
Overloads
This overload allows you to specify the center point feature along with the radius in the shape's unit. This overload will create a circle.
centerPointFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the center PointFeature for the EllipseShape.
Go Back
EllipseShape(PointShape, Double, Double)
Overloads
This overload allows you to specify the center point along with the horizontal and vertical radius in the unit of the shape.
horizontalRadius Double<!– System.Double –> This parameter allows you to set the horizontal radius of the EllipseShape in the unit of the shape.
verticalRadius Double<!– System.Double –> This parameter allows you to set the vertical radius of the EllipseShape in the unit of the shape.
Go Back
EllipseShape(Feature, Double, Double)
Overloads
This overload allows you to specify the center point feature along with the horizontal and vertical radius in the unit of the shape.
Go Back
EllipseShape(String)
Overloads
This constructor allows you to create the shape from well-known text.
wellKnownText String<!– System.String –> This parameter is the well-known text used to create the shape.
Go Back
EllipseShape(Byte[])
Overloads
This constructor allows you to create the shape from well-known binary.
wellKnownBinary Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.ellipseshape –> This parameter is the well-known binary used to create the shape.
Go Back
EllipseShape(PointShape, Double, GeographyUnit, DistanceUnit)
Overloads
This overload allows you to specify the center point along with the radius in the unit specified by the unitOfRadius parameter. This overload will create a circle.
radius Double<!– System.Double –> This parameter allows you to set the radius of the EllipseShape in the unit specified by the unitOfRadius parameter.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This is the GeographyUnit of the shape you are performing the operation on.
unitOfRadius DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the DistanceUnit you would like to use for the radius value. For example, if you select miles as your unitOfRadius, then it will use miles.
Go Back
EllipseShape(Feature, Double, GeographyUnit, DistanceUnit)
Overloads
This overload allows you to specify the center point feature along with the radius in the unit specified by the unitOfRadius parameter. This overload will create a circle.
centerPointFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the center Point Feature for the EllipseShape.
Go Back
EllipseShape(PointShape, Double, Double, GeographyUnit, DistanceUnit)
Overloads
This overload allows you to specify the center point along with the horizontal and vertical radius in the unit specified by the unitOfRadius parameter.
horizontalRadius Double<!– System.Double –> This parameter allows you to set the horizontal radius of the EllipseShape in the unit specified by the unitOfRadius parameter.
verticalRadius Double<!– System.Double –> This parameter allows you to set the vertical radius of the EllipseShape in the unit specified by the unitOfRadius parameter.
Go Back
EllipseShape(Feature, Double, Double, GeographyUnit, DistanceUnit)
Overloads
Go Back
Buffer(Double, Int32, GeographyUnit, DistanceUnit)
This method computes the area containing all of the points within a given distance from this shape. In this case, you will be using the rounded RoundedBufferCapStyle. The distance unit is determined by the distanceUnit argument.
Return Type Description
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that represents all of the points within a given distance from the shape.
distance Double<!– System.Double –> The distance is the number of units to buffer the current shape. The distance unit will be the one specified in the distanceUnit paramater. The distance must be greater than 0.
quadrantSegments Int32<!– System.Int32 –> The quadrant segments are the number of points in each quarter circle. A good default is 8, but if you want smoother edges you can increase this number. The valid range for this number is from 3 to 100.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This is the geographic unit of the shape you are performing the operation on.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the distance unit you would like to use as the distance. For example, if you select miles as your distanceUnit, then the distance will be calculated in miles for the operation.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> Go Back
Buffer(Double, Int32, BufferCapType, GeographyUnit, DistanceUnit)
bufferCapType BufferCapType<!– ThinkGeo.MapSuite.WindowsPhoneCore.BufferCapType –> The bufferCapType determines how the caps of the buffered object look. They range from rounded to squared off.
Buffer(Double, GeographyUnit, DistanceUnit)
This method computes the area containing all of the points within a given distance from this shape. In this case, you will be using the rounded RoundedBufferCapStyle and the default 8 quadrant segments. The distance unit is determined by the distanceUnit argument.
distance Double<!– System.Double –> The distance is the number of units to buffer the current shape. The distance unit will be the one specified in the distanceUnit parameter. The distance must be greater than 0.
CloneDeep()
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This method returns a complete copy of the shape without any references in common.
Contains(Feature)
Boolean<!– System.Boolean –> This method returns if the targetFeature lies within the interior of the current shape.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The targetFeature that contains a shape you wish to compare the current one to.
Contains(BaseShape)
Boolean<!– System.Boolean –> This method returns if the targetShape lies within the interior of the current shape.
targetShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> The shape you wish to compare the current one to.
CreateShapeFromWellKnownData(String)
<!– static –> This method creates a BaseShape from a string of well-known text.
This method creates a BaseShape from a string of well-known text. Well-known text allows you to describe geometries as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometries.
POINT(5 17)
LINESTRING(4 5,10 50,25 80)
POLYGON1)
MULTIPOINT(3.7 9.7,4.9 11.6)
MULTILINESTRING2)
MULTIPOLYGON3),4))
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> The return type is a higher level shape constructed from the well-known text you passed into the method. Though the object is a higher level shape, such as a PolygonShape or MultiPointShape, you will need to cast it to that shape in order to use its unique properties.
wellKnownText String<!– System.String –> A string representing the geometry in well-known text format.
CreateShapeFromWellKnownData(Byte[])
<!– static –> This method creates a BaseShape from a string of well-known binary.
This method creates a BaseShape from a string of well-known binary. Well-known binary allows you to describe geometries as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well-known text as well.
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> The return type is a higher level shape constructed from the well-known binary you passed into the method. Though the object is a higher level shape, such as a PolygonShape or MultiPointShape, you will need to cast it to that shape in order to use its unique properties.
wellKnownBinary Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.ellipseshape –> An array of bytes representing the geometry in well-known binary format.
Crosses(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape share some but not all interior points.
Crosses(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature share some but not all interior points.
GetArea(GeographyUnit, AreaUnit)
You would use this method to find the area inside the shape.
Double<!– System.Double –> The return unit is based on a AreaUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
returningUnit AreaUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaUnit –> This is the AreaUnit you would like to use as the return value. For example, if you select square miles as your returningUnit, then the distance will be returned in square miles.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> Go Back
GetBoundingBox()
The GetBoundingBox method calculates the smallest RectangleShape that can encompass the entire geometry by examining each point in the geometry.
Depending on the number of PointShapes and complexity of the geometry, this operation can take longer for larger objects.
If the shape is a PointShape, then the bounding box's upper left and lower right points will be equal. This will create a RectangleShape with no area.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> The RectangleShape returned is the smallest RectangleShape that can encompass the entire geometry.
GetCenterPoint()
This method returns the center point of the current shape's bounding box. It is important to note that this is the center point of the bounding box. There are numerous ways to calculate the “center” of a geometry, such as its weighted center, etc. You can find other centers by examining the various methods of the shape itself.
PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> A PointShape representing the center point of the current shape's bounding box.
GetClosestPointTo(BaseShape, GeographyUnit)
PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> A PointShape representing the closest point of the current shape to the targetShape.
targetShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> The shape you are trying to find the closest point to.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> The geographic unit of the shape you are trying to find the closet point to.
GetClosestPointTo(Feature, GeographyUnit)
This method returns the point of the current shape that is closest to the target feature. It is often the case that the point returned is not a point of the object itself. An example would be a line with two points that are far apart from each other. If you set the targetFeature to be a point midway between the points but a short distance away from the line, the method would return a point that is on the line but not either of the two points that make up the line.
PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> A PointShape representing the closest point of the current shape to the targetFeature.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feature you are trying to find the closest point to.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> The geographic unit of the feature you are trying to find the closet point to.
GetConvexHull()
This method is useful when you want to create a perimeter around the shape. For example, if you had a MultiPolygon that represented buildings on a campus, you could easily get the convex hull of the buildings and determine the perimeter of all of the buildings together. This also works with MultiPoint shapes, where each point may represent a certain type of person you are doing statistics on. With convex hull, you can get an idea of the regions those points are located in.
RingShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RingShape –> This method returns the convex hull of the shape, defined as the smallest convex ring that contains all of the points in the shape.
GetCrossing(BaseShape)
MultipointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipointShape –> This method returns the crossing points between the current shape and the passed-in target shape.
targetShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> The target shape you wish to get crossing points with.
GetDifference(AreaBaseShape)
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that is the set of all points which lie in the current shape but not in the targetShape.
targetShape AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> The shape you are trying to find the difference with.
GetDifference(Feature)
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that is the set of all points which lie in the current shape but not in the target feature.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feture you are trying to find the difference with.
GetDistanceTo(Feature, GeographyUnit, DistanceUnit)
In this method we compute the closest distance between a shape and a feature. The returned unit will be in the unit of distance specified.
Double<!– System.Double –> The return type is the distance between this shape and the targetFeature in the GeographyUnit of the shape.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feature you are trying to find the distance to.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter is the unit of the shape which is contained in the targetFeature you are getting the distance to.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This parameter is the unit of the distance you want the return value to be in.
GetDistanceTo(BaseShape, GeographyUnit, DistanceUnit)
In this method we compute the closest distance between the two shapes. The returned unit will be in the unit of distance specified.
Double<!– System.Double –> The return type is the distance between this shape and the targetShape in the GeographyUnit of the shape.
targetShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> The shape you are trying to find the distance to.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter is the unit of the shape you are getting the distance to.
GetFeature()
Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feature with the same Id and BaseShape as the current BaseShape, and with empty columnValues in it.
GetFeature(IDictionary<String, String>)
Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feature with the same Id and BaseShape as the current BaseShape and with empty columnValues in it, substituted with the passed-in columnValues.
columnValues IDictionary<String,String><!– System.Collections.Generic.IDictionary{System.String,System.String} –> The columnValues will be passed into returning feature.
GetHeightByUnit(GeographyUnit, DistanceUnit)
Double<!– System.Double –> This method returns the height of the EllipseShape in the unit specified in the returningUnit parameter.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter is the unit of the current shape.
returningUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the unit you would like to use for the return value. For example, if you select miles as your returningUnit, then the distance will be returned in miles.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.EllipseShape –> Go Back
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that contains the set of all points which lie in both the current shape and the target shape.
targetShape AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> The shape you are trying to find the intersection with.
GetIntersection(Feature)
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that contains the set of all points which lie in both the current shape and the target feature.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feature you are trying to find the intersection with.
GetPerimeter(GeographyUnit, DistanceUnit)
You would use this method to find the distance around the area shape.
Double<!– System.Double –> The return unit is based on a LengthUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
returningUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the DistanceUnit you would like to use as the return value. For example, if you select miles as your returningUnit, then the distance will be returned in miles.
GetShortestLineTo(Feature, GeographyUnit)
This method returns a MultiLineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This is effect is similar to what you might see on an international flight when the displayed flight path is curved.
Overriding:
Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> A MultiLineShape representing the shortest distance between the shape you're calling the method on and the targetFeature.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> The geographic unit of the feature you are trying to find the distance to.
GetShortestLineTo(BaseShape, GeographyUnit)
This method returns a LineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This effect is similar to what you might see on an international flight when the displayed flight path is curved.
MultilineShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultilineShape –> A LineShape representing the shortest distance between the shape you're calling the method on and the targetShape.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> The geographic unit of the Shape you are trying to find the distance to.
GetSymmetricalDifference(AreaBaseShape)
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that is the set of all points which lie in the current shape or the targetShape but not both.
targetShape AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> The shape you are trying to find the symmetrical difference with.
GetSymmetricalDifference(Feature)
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that is the set of all points which lie in the current shape or the targetFeature but not both.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feature you are trying to find the symmetrical difference with.
GetTangents(EllipseShape)
This operation is useful for finding the corridor between two ellipses. It would be handy in a buffering type of scenario.
Collection<PointShape><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.PointShape} –> This method returns the tangent points of the current ellipse in relation to the target ellipse you specify.
targetEllipse EllipseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.EllipseShape –> This parameter represents the other ellipse you wish to find the tangent points to.
Type<!– System.Type –>
This method returns a byte array that represents the shape in well-known binary. Well-known binary allows you to describe geometries as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well known text as well.
Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.ellipseshape –> This method returns a byte array that represents the shape in well-known binary.
byteOrder WkbByteOrder<!– ThinkGeo.MapSuite.WindowsPhoneCore.WkbByteOrder –> This parameter is the byte order used to encode the well-known binary.
GetWellKnownBinary()
GetWellKnownText()
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe geometries as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometries.
POINT(5 17)
POLYGON5)
MULTILINESTRING6)
MULTIPOLYGON7),8))
String<!– System.String –> This method returns a string that represents the shape in well-known text.
GetWellKnownType()
WellKnownType<!– ThinkGeo.MapSuite.WindowsPhoneCore.WellKnownType –> This method returns the well-known type for the shape.
GetWidthByUnit(GeographyUnit, DistanceUnit)
Double<!– System.Double –> This method returns the width of the EllipseShape in the unit specified in the returningUnit parameter.
Intersects(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape have at least one point in common.
Intersects(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature have at least one point in common.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The targetFeature you wish to compare the current one to.
IsDisjointed(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape have no points in common. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
IsDisjointed(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature have no points in common. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feature you wish to compare the current one to.
IsTopologicallyEqual(Feature)
Topologically equal means that the shapes are essentially the same. For example, let's say you have a line with two points, point A and point B. You also have another line that is made up of point A, point B and point C. Point A of line one shares the same vertex as point A of line two, and point B of line one shares the same vertex as point C of line two. They are both straight lines, so point B of line two would lie on the first line. Essentially the two lines are the same, with line 2 having just one extra point. Topologically they are the same line, so this method would return true.
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature are topologically equal.
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape are topologically equal.
IsWithin(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape lies within the interior of the targetFeature.
IsWithin(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape lies within the interior of the targetShape.
LoadFromWellKnownData(String)
Void<!– System.Void –>
wellKnownText String<!– System.String –> This parameter is the well-known text you will use to hydrate your object.
LoadFromWellKnownData(Byte[])
wellKnownBinary Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.ellipseshape –> This parameter is the well-known binary used to populate the shape.
Overlaps(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape share some but not all points in common.
Overlaps(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature share some but not all points in common.
Register(PointShape, PointShape, DistanceUnit, GeographyUnit)
Registering allows you to take a geometric shape generated in a planar system and attach it to the ground in a Geographic Unit.
A common scenario is integrating geometric shapes from external programs (such as CAD software or a modeling system) and placing them onto a map. You may have the schematics of a building in a CAD system and the relationship between all the points of the building are in feet. You want to then take the CAD image and attach it to where it really exists on a map. You would use the register method to do this.
Registering is also useful for scientific modeling, where software models things such as a plume of hazardous materials or the fallout from a volcano. The modeling software typically generates these models in a fictitious planar system. You would then use the register to take the abstract model and attach it to a map with real coordinates.
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
fromPoint PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the anchor PointShape in the coordinate of origin.
toPoint PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the anchor PointShape in the coordinate of destination.
fromUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This parameter is the DistanceUnit of the coordinate of origin.
toUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter is the GeographyUnit of the coordinate of destination.
Register(Feature, Feature, DistanceUnit, GeographyUnit)
fromPoint Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the anchor PointFeature in the coordinate of origin.
toPoint Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the anchor PointFeature in the coordinate of destination.
Rotate(BaseShape, PointShape, Single)
<!– static –> This method returns a shape rotated by a number of degrees based on a pivot point.
This method returns a shape rotated by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape you can achieve in-place rotation. By moving the pivot point outside of the center of the shape you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This method returns a shape rotated by a number of degrees based on a pivot point.
sourceBaseShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This parameter is the basis for the rotation.
pivotPoint PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> The pivotPoint represents the center of rotation.
degreeAngle Single<!– System.Single –> The number of degrees of rotation required, from 0 to 360.
Rotate(Feature, PointShape, Single)
<!– static –> This method returns a feature rotated by a number of degrees based on a pivot point.
This method returns a feature rotated by a number of degrees based on a pivot point. By placing the pivot point in the center of the feature you can achieve in-place rotation. By moving the pivot point outside of the center of the feature you can translate the feature in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the basis for the rotation.
Rotate(PointShape, Single)
ScaleDown(Feature, Double)
<!– static –> This method returns a new area feature that has been scaled down by the percentage given in the percentage parameter.
This method is useful when you would like to decrease the size of the feature. Note that a larger percentage will scale the shape down faster, since you apply the operation multiple times. There is a ScaleUp method that will enlarge the shape as well.
Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This method is useful when you would like to decrease the size of the feature. Note that a larger percentage will scale the shape down faster, since you apply the operation multiple times. There is a ScaleUp method that will enlarge the shape as well.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the shape to use as the base for the scaling.
percentage Double<!– System.Double –> This is the percentage by which to decrease the shape's size.
ScaleDown(AreaBaseShape, Double)
<!– static –> This method returns a new area shape that has been scaled down by the percentage given in the percentage parameter.
This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster, since you apply the operation multiple times. There is a ScaleUp method that will enlarge the shape as well.
AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster, since you apply the operation multiple times. There is a ScaleUp method that will enlarge the shape as well.
targetShape AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> This parameter is the shape to use as the base for the scaling.
ScaleDown(Double)
Void<!– System.Void –> This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster, since you apply the operation multiple times. There is a ScaleUp method that will enlarge the shape as well.
ScaleTo(BaseShape, Double)
<!– static –>
baseShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –>
scale Double<!– System.Double –>
ScaleTo(Double)
ScaleUp(AreaBaseShape, Double)
<!– static –> This method returns a new area shape that has been scaled up by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster, since you apply the operation multiple times. There is a ScaleDown method that will shrink the shape as well.
percentage Double<!– System.Double –> This is the percentage by which to increase the shape's size.
ScaleUp(Double)
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster, since you apply the operation multiple times. There is a ScaleDown method that will shrink the shape. as well.
ScaleUp(Feature, Double)
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the feature to use as the base for the scaling.
SetHeightByUnit(Double, GeographyUnit, DistanceUnit)
newHeight Double<!– System.Double –> This parameter is the newHeight of the ellipse shape.
unitOfHeight DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the unit you would like to use for the setting value. For example, if you select miles as your unitOfHeight, then the distance will be set in miles.
SetWidthByUnit(Double, GeographyUnit, DistanceUnit)
newWidth Double<!– System.Double –> This parameter is the newWidth of the ellipse shape.
unitOfWidth DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the unit you would like to use as the setting value. For example, if you select miles as your unitOfWidth, then the distance will be set in miles.
Simplify(GeographyUnit, Double, DistanceUnit, SimplificationType)
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> This method returns a simplification multipolgyon by the specified parameters.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter specifies the geographic unit of this current shape you are performing the operation
tolerance Double<!– System.Double –> This parameter specifes the tolerance to be used when simplification.
toleranceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This parameter specifes the distance unit of the tolerance.
simplificationType SimplificationType<!– ThinkGeo.MapSuite.WindowsPhoneCore.SimplificationType –> This prameter specifies the type of simplification operation.
Simplify(Double, SimplificationType)
Simplify(AreaBaseShape, GeographyUnit, Double, DistanceUnit, SimplificationType)
<!– static –> This method performed a simplification operation based on the parameters passed in. Simplify permanently alters the input geometry so that the geometry becomes topologically consistent.
targetShape AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> This parameter specifies the area shape to be simplfied.
targetShapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter specifies the geographic unit of the shape you are performing the operation
Simplify(AreaBaseShape, Double, SimplificationType)
Split(Feature, Feature)
<!– static –> This method returns a collection of Features split by the specified parameters.
Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This method returns a collection of Features split by the specified parameters.
areaToSplit Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter represents the feature to be split.
areaToSplitBy Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter represents the feature that will be used to perform the split.
Split(AreaBaseShape, AreaBaseShape)
<!– static –> This method returns a collection of MultiPolygonShapes split by the specified parameters.
Collection<MultipolygonShape><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape} –> This method returns a collection of MultiPolygonShape split by the specified parameters.
areaToSplit AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> This parameter represents the shape to be split.
areaToSplitBy AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> This parameter represents the shape that will be used to perform the split.
ToPolygon()
This method is mainly used to convert this non GIS standard shape to a GIS standard shape.
PolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PolygonShape –> This method returns the current shape as a PolygonShape.
ToPolygon(Int32)
This method is mainly used to convert a GIS non-standard shape to a GIS standard shape.
vertexCountInQuarter Int32<!– System.Int32 –> This parameter specifies how many points will make up each quarter of the ellipse.
Touches(Feature)
Boolean<!– System.Boolean –> This method returns of the current shape and the targetFeature have at least one boundary point in common, but no interior points.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The targetFeature which contains a shape that you wish to compare the current one to.
Touches(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points.
TranslateByDegree(Double, Double, GeographyUnit, DistanceUnit)
This method moves a base shape from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this shape a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
If you pass a distance of 0, then the operation is ignored.
distance Double<!– System.Double –> The distance is the number of units to move the shape using the angle specified. The distance unit will be the DistanceUnit specified in the distanceUnit parameter. The distance must be greater than or equal to 0.
angleInDegrees Double<!– System.Double –> A number between 0 and 360 degrees that represents the direction you wish to move the shape, with 0 being up.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the DistanceUnit you would like to use as the measure of the translate. For example if you select miles as your distanceUnit then the distance will be calculated in miles.
TranslateByDegree(Double, Double)
TranslateByDegree(BaseShape, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns a shape repositioned from one location to another based on a distance and a direction in degrees.
This method returns a shape repositioned from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this shape a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This method returns a shape repositioned from one location to another based on a distance and a direction in degrees.
targetShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This parameter is the basis of the move.
distance Double<!– System.Double –> The distance is the number of units to move the shape using the angle specified. The distance unit will be the one specified in the distanceUnit parameter. The distance must be greater than or equal to 0.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the distance unit you would like to use as the measure for the move. For example, if you select miles as your distance unit, then the distance will be calculated in miles.
TranslateByDegree(Feature, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees.
This method returns a feature repositioned from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this feature a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the basis of the move.
angleInDegrees Double<!– System.Double –> A number between 0 and 360 degrees that represents the direction you wish to move the feature, with 0 being up.
TranslateByOffset(Feature, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns a feature repositioned from one location to another based on an X and Y offset distance.
This method returns a feature repositioned from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This method returns a feature repositioned from one location to another based on an X and Y offset distance.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the basis of the moved feature.
xOffsetDistance Double<!– System.Double –> This is the number of horizontal units of movement in the distance unit specified in the distanceUnit parameter.
yOffsetDistance Double<!– System.Double –> This is the number of horizontal units of movement in the distance unit specified in the distanceUnit parameter.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the distance unit you would like to use as the measure for the move. For example, if you select miles as your distance unit, then the xOffsetDistance and yOffsetDistance will be calculated in miles.
TranslateByOffset(Double, Double)
TranslateByOffset(Double, Double, GeographyUnit, DistanceUnit)
This method moves a base shape from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This is the geographic unit of the base shape you are performing the operation on.
TranslateByOffset(BaseShape, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns a shape repositioned from one location to another based on an X and Y offset distance.
This method returns a shape repositioned from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This method returns a shape repositioned from one location to another based on an X and Y offset distance.
targetShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> This parameter is the basis of the moved shape.
yOffsetDistance Double<!– System.Double –> This is the number of vertical units of movement in the distance unit specified in the distanceUnit parameter.
Union(IEnumerable<AreaBaseShape>)
<!– static –> This method returns the union of the specified area shapes.
This is useful for adding area shapes together to form a larger area shape.
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that contains the set of all points that lie within the shapes you specified.
areaShapes IEnumerable<AreaBaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape} –> The shapes you are trying to find the union with.
Union(AreaBaseShape)
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that contains the set of all points which lie in the current shape or the target shape.
targetShape AreaBaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape –> The shape you are trying to find the union with.
Union(Feature)
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that contains the set of all points which lie in the current shape or the target feature.
targetFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> The feature you are trying to find the union with.
Union(IEnumerable<Feature>)
<!– static –> This method returns the union of the current shape and the target features, defined as the set of all points in the current shape or the target features.
Overriding:
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that contains the set of all points which lie in the current shape or the target features. Overriding: Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
targetFeatures IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> The target features you are trying to find the union with.
Validate(ShapeValidationMode)
ShapeValidationResult<!– ThinkGeo.MapSuite.WindowsPhoneCore.ShapeValidationResult –> This method returns a ShapeValidationResult based on a series of tests.
validationMode ShapeValidationMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.ShapeValidationMode –> This parameter determines whether the test is simple or advanced. In some cases, the advanced tests can take some time. The simple test is designed to always be fast.
BufferCore(Double, Int32, BufferCapType, GeographyUnit, DistanceUnit)
Overriding:
quadrantSegments Int32<!– System.Int32 –> The number of quadrantSegments used in the buffer logic.
bufferCapType BufferCapType<!– ThinkGeo.MapSuite.WindowsPhoneCore.BufferCapType –> The bufferCapType used in the buffer logic.
CloneDeepCore()
When you override this method, you need to ensure that there are no references in common between the original and copy.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape(overriden) –> Go Back
ContainsCore(BaseShape)
Overriding:
Boolean<!– System.Boolean –> This method returns whether the targetShape lies within the interior of the current shape.
CrossesCore(BaseShape)
Overriding:
GetAreaCore(GeographyUnit, AreaUnit)
Overloads
In this overload, the return unit is based on the AreaUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
You would use this method to find the area inside of a shape.
Overriding:
Double<!– System.Double –> The return unit is based on the AreaUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
returningUnit AreaUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaUnit –> This is the AreaUnit you would like to use for the return value. For example, if you select square miles as your returningUnit, then the distance will be returned in square miles.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaBaseShape(overriden) –> Go Back
GetBoundingBoxCore()
Depending on the number of PointShapes and complexity of the geometry, this operation can take a significant amount of time (the larger the objects, the more time the operation will take).
Overriding:
GetCenterPointCore()
Overriding:
GetClosestPointToCore(BaseShape, GeographyUnit)
This method returns point of the current shape that is closest to the target shape. It is often the case that the point returned is not a point of the object itself. An example would be a line with two points that are far apart from each other. If you set the targetShape to be a point midway between the points but a short distance away, the method would return a point that is on the line, but not one of the two points that make up the line.
Overriding:
PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> A PointShape representing the point of the current shape that is closest to the targetShape.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This is the GeographicUnit of the shape you are performing the operation on.
GetConvexHullCore()
Overriding:
GetCrossingCore(BaseShape)
This method returns the crossing points of the current shape and the passed-in target shape.
MultipointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipointShape –> This method returns the crossing points of the current shape and the passed-in target shape.
targetShape BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> The target shape you wish to get crossing with.
GetDifferenceCore(AreaBaseShape)
This method returns the difference between two shapes, defined as the set of all points which lie in the current shape but not in the targetShape.
Overriding:
GetDistanceToCore(BaseShape, GeographyUnit, DistanceUnit)
Overloads
The distance returned will be in the unit specified in the distanceUnit parameter.
In this method, we compute the closest distance between two shapes. The returned unit will be in the unit of distance specified in the distanceUnit parameter.
Overriding:
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the DistanceUnit you would like to use as the return value. For example, if you select miles as your distanceUnit, then the distance will be returned in miles.
This method returns the intersection of the current shape and the target shape, defined as the set of all points which lie in both the current shape and the target shape.
Overriding:
GetPerimeterCore(GeographyUnit, DistanceUnit)
This method returns the perimeter of the shape, which is defined as the sum of the lengths of all its sides.
Overloads
In this overload, the return unit is based on the LengthUnit you specify in the returningLengthUnit parameter, regardless of the shape's GeographyUnit.
Overriding:
Double<!– System.Double –> The return unit is based on the LengthUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
returningUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the DistanceUnit you would like to use for the return value. For example, if you select miles as your returningUnit, then the distance will be returned in miles.
GetShortestLineToCore(BaseShape, GeographyUnit)
This method returns the shortest LineShape between this shape and the targetShape parameter.
This method returns a LineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This is effect is similar to what you might see on an international flight when the displayed flight path is curved.
Overriding:
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> The geographic unit of the shape you are trying to find the distance to.
GetSymmetricalDifferenceCore(AreaBaseShape)
This method returns the symmetrical difference between two shapes, defined as the set of all points which lie in the current shape or the targetShape but not both.
Overriding:
GetWellKnownBinaryCore(WkbByteOrder, Int32)
This method returns a byte array that represents the shape in well known binary. Well-known binary allows you to describe geometries as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We also have methods that work with well-known text.
Overriding:
byteOrder WkbByteOrder<!– ThinkGeo.MapSuite.WindowsPhoneCore.WkbByteOrder –> This parameter specifies whether the byte order is big- or little-endian.
Overriding:
GetWellKnownTextCore(Int32)
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe geometries as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We also have methods that work with well-known binary. Below are some samples of what well-known text might look like for various kinds of geometries.
POINT(5 17)
POLYGON9)
MULTILINESTRING10)
MULTIPOLYGON11),12))
Overriding:
String<!– System.String –> This method returns a stringthat represents the shape in well-known text.
Name Type Description
GetWellKnownTextCore()
POINT(5 17)
POLYGON13)
MULTILINESTRING14)
MULTIPOLYGON15),16))
Overriding:
GetWellKnownTypeCore()
IntersectsCore(BaseShape)
This method returns whether the current shape and the targetShape have at least one point in common.
Overriding:
Boolean<!– System.Boolean –> This method returns whether the current shape and the targetShape have at least one point in common.
IsDisjointedCore(BaseShape)
Overriding:
Overriding:
IsWithinCore(BaseShape)
Overriding:
This method hydrates the current shape with its data from well-known binary.
OverlapsCore(BaseShape)
Overriding:
RegisterCore(PointShape, PointShape, DistanceUnit, GeographyUnit)
Overriding:
RotateCore(PointShape, Single)
This method rotates the shape by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape, you can acheive in-place rotation. By moving the pivot point outside of the center of the shape, you can translate the shape in a circular motion. Moving the pivot point further away from the center will make the circular area larger.
Overriding:
degreeAngle Single<!– System.Single –> The number of degrees of rotation required from 0 to 360.
ScaleDownCore(Double)
This method decreases the size of the area shape by the percentage given in the percentage parameter.
Overriding:
Void<!– System.Void –> This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster, as you are applying the operation multiple times. There is also a ScaleUp method that will enlarge the shape.
ScaleToCore(Double)
ScaleUpCore(Double)
This method increases the size of the area shape by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster, as you are applying the operation multiple times. There is also a ScaleDown method that will shrink the shape.
Overriding:
SimplifyCore(Double, SimplificationType)
TouchesCore(BaseShape)
Overriding:
TranslateByDegreeCore(Double, Double, GeographyUnit, DistanceUnit)
This method moves the base shape from one location to another based on a direction in degrees and distance.
Overloads
In this overload, the distance unit is based on a DistanceUnit you specify in the distanceUnit parameter, regardless of the shape's GeographicUnit.
This method moves the base shape from one location to another based on angleInDegrees and distance parameter. It is important to note that with this overload the distance units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit in miles, you're going to move this shape a number of miles based on the distance and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
Overriding:
angleInDegrees Double<!– System.Double –> A number between 0 and 360 degrees that represents the direction you wish to move the shape with zero being up.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the DistanceUnit you would like to use as the measurement for the move. For example, if you select miles as your distanceUnit, then the distance will be calculated in miles.
TranslateByOffsetCore(Double, Double, GeographyUnit, DistanceUnit)
Overloads
In this overload, the X and Y offset are based on the DistanceUnit you specify, regardless of the shape's GeographicUnit.
This method moves the base shape from one location to another based on an X and Y offset distance. It is important to note that with this overload the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of one and a Y offset of one, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles to on the X axis and 3 miles on the Y axis.
Overriding:
Return Type Description
xOffsetDistance Double<!– System.Double –> This is the number of horizontal units of movement in the DistanceUnit specified by the distanceUnit parameter.
yOffsetDistance Double<!– System.Double –> This is the number of horizontal units of movement in the DistanceUnit specified by the distanceUnit parameter.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the DistanceUnit you would like to use as the measurement for the move. For example, if you select miles as your distanceUnit, then the xOffsetDistance and yOffsetDistance will be calculated in miles.
UnionCore(AreaBaseShape)
This method returns the union of the current shape and the target shapes, defined as the set of all points in the current shape or the target shape.
Overriding:
MultipolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.MultipolygonShape –> The return type is a MultiPolygonShape that contains the set of all points which lie in the current shape or the target shape. Overriding: Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
Overriding:
CanRotate
Return Type
Center
This property allows you to get or set the center PointShape of the EllipseShape.
Return Type
Height
This property returns the height of the EllipseShape in the unit of the shape.
Return Type
Id
The id of the shape.
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> Go Back
Tag
The tag of the shape.
Return Type
Width
This property returns the width of the EllipseShape in the unit of the shape.
Return Type
1) , 5) , 9) , 13) 2 2,6 2,6 6,2 6,2 2),(3 3,4 3,4 4,3 4,3 3
2) , 6) , 10) , 14) 4 5,11 51,21 26),(-4 -7,-9 -7,-14 -3
3) , 7) , 11) , 15) (2 2,6 2,6 6,2 6,2 2),(3 3,4 3,4 4,3 4,3 3
4) , 8) , 12) , 16) 4 4,7 3,7 5,4 4
thinkgeo.mapsuite.windowsphonecore.ellipseshape.txt · Last modified: 2017/03/16 21:59 (external edit)
