thinkgeo.mapsuite.webedition.markerzoomlevel
ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel
Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
    • ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel
MarkerZoomLevel()
Initialize a new instance of the MarkerZoomLevel class.
This is the default constructor. If you use this constructor, you should set the require properties on the class manually.
GetMarkers(IEnumerable<Feature>)
Returns a collection of markers to which the styles will be applied when the current zoomlevel falls into the ranges defined.
  • Type:Collection<Marker>
  • features
    • Type:IEnumerable<Feature>
    • Description:A collection of markers to which the styles will be applied when the current zoomlevel falls into the ranges defined.
GetRequiredColumnNames()
This method returns the column data for each feature that is required for the styles to properly draw.
In this method, we return the column names that are required for the styles to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include the column name. This will ensure that the column data is returned to you in the feature when it is ready to draw. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Type:Collection<String>
  • Description:This method returns a collection containing the required column names.
GetContextMenusCore()
Gets a collection of context menus that are associated with the MarkerZoomLevel.
ZhQ=()
ApplyUntilZoomLevel
Gets or sets the zoomlevel to which the styles will be applied.
DefaultMarkerStyle
Gets or sets the style that is applied to the markers if the CustomMarkerStyle is not defined.
CustomMarkerStyle
Gets or sets a style that can be any type of MarkerStyle.
The CustomMarkerStyle has a higher priority than the DefaultMarkerStyle. When you define both styles, the CustomMarkerStyle will be applied. The CustomMarkerStyle can be any kind of MarkerStyle while the DefaultMarkerStyle cannot.
GxU=
thinkgeo.mapsuite.webedition.markerzoomlevel.1442545720.txt.gz · Last modified: 2015/09/18 03:08 by admin
