<!– Class –> Defines the properties and methods that are shared by all controls on the map.
This is the base class that all of the map controls are derived from.
*System.Object ThinkGeo.MapSuite.WebEdition.MapTool *ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool *ThinkGeo.MapSuite.WebEdition.KeyboardMapTool *ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool *ThinkGeo.MapSuite.WebEdition.LogoMapTool *ThinkGeo.MapSuite.WebEdition.MeasureMapTool *ThinkGeo.MapSuite.WebEdition.MiniMapMapTool *ThinkGeo.MapSuite.WebEdition.MouseCoordinateMapTool *ThinkGeo.MapSuite.WebEdition.MouseMapTool *ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool *ThinkGeo.MapSuite.WebEdition.PanZoomBarMapTool *ThinkGeo.MapSuite.WebEdition.PanZoomMapTool *ThinkGeo.MapSuite.WebEdition.ScaleLineMapTool *ThinkGeo.MapSuite.WebEdition.TouchMapTool
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Returns a JSON string that represents the map control object. | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Boolean | Gets or sets a value that turns the feature on and off. |
Initialize an instance of the MapTool class.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#MapTool.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#MapTool.28.29</a>
Name | Type | Description |
Initialize an instance of the MapTool class with a boolean value that indicates whether it is enabled.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#MapTool.28Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#MapTool.28Boolean.29</a>
enabled | Boolean<!– System.Boolean –> | A boolean value that indicates whether this MapTool is enabled. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#GetType.28.29</a>
Type<!– System.Type –> |
This method returns a JSON string that instructs the client Javascript to create a specific client object.
String<!– System.String –> | A JSON string that represents the map control. |
<!– ThinkGeo.MapSuite.WebEdition.MapTool –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#Enabled” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTool#Enabled</a>
Return Type |
