thinkgeo.mapsuite.webedition.highlightfeatureoverlay
ThinkGeo.MapSuite.WebEdition.HighlightFeatureOverlay
<!– Class –> Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
The &lt;strong&gt;HighlightFeatureOverlay&lt;/strong&gt; class has a &lt;strong&gt;HighlightStyle&lt;/strong&gt; property which determines the style of features when you move your mouse over them. By setting this property, you can add an attractive highlight effect.The &lt;strong&gt;HighlightFeatureOverlay&lt;/strong&gt; class also has a &lt;strong&gt;Click&lt;/strong&gt; event and a &lt;strong&gt;ContextMenu&lt;/strong&gt; property that can be attached to its features. When you click or right-click on the features, the event will be fired or the context menu will pop up, respectively.The &lt;strong&gt;OnClientClick&lt;/strong&gt; property holds the Javascript that will be executed before the &lt;strong&gt;Click&lt;/strong&gt; event. If you return &lt;strong&gt;false&lt;/strong&gt; in the Javascript, the &lt;strong&gt;Click&lt;/strong&gt; event will not be fired.You can only accesss the &lt;strong&gt;HighlightFeatureOverlay&lt;/strong&gt; instance by using &lt;strong&gt;Map.HighlightOverlay&lt;/strong&gt;. You cannot create an instance by yourself.&lt;strong&gt;Note:&lt;/strong&gt; Because the &lt;strong&gt;HighlightFeatureOverlay&lt;/strong&gt; serializes and paints all of its features to the client side, there might be a performance impact if you add too many features to its &lt;strong&gt;Features&lt;/strong&gt; collection.
Public MethodGetType Object
Public MethodToJson Overlay Returns a JSON string which contains the information for creating an overlay at the client side.
Public MethodToString Object
Protected MethodOnClick HighlightFeatureOverlayClickEventArgs Raises the click event on the HighlightFeatureOverlay.
Protected MethodOnTick EventArgs Overlay Raises the Tick event of the MarkerOverlay.
Protected MethodRegisterJavaScriptLibraryCore Page Overlay Registers a Javascript library URL string to the client HTML page.
Public PropertyAttribution String Overlay
Public PropertyAutoRefreshInterval TimeSpan Overlay Gets or sets the time interval in which the MarkerOverlay refreshes itself.
Public PropertyColumns Collection<FeatureSourceColumn> FeatureOverlay Gets a collection of FeatureSourceColumns, which specifies the column names of the feature data.
Public PropertyContextMenu ContextMenu Gets or sets the shortcut menu associated with the HighlightFeatureOverlay.
Public PropertyEditTools EditTools FeatureOverlay Gets the EditTools that allow you to easily edit features in the FeatureOverlay.
Public PropertyFeatureSource InMemoryFeatureSource FeatureOverlay Gets the FeatureSource of the FeatureOverlay.
Public PropertyFeatures GeoCollection<Feature> FeatureOverlay Gets a collection of features that will be serialized to the client for drawing and editing.
Public PropertyHighlightStyle FeatureOverlayStyle Gets or sets a FeatureOverlayStyle that will be applied to the features when the mouse pointer is over them.
Public PropertyId String Overlay Gets the identifier for the overlay to be found.
Public PropertyIsBaseOverlay Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyIsVisibleInOverlaySwitcher Boolean Overlay Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Public PropertyName String Overlay Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Public PropertyOnClientClick String Gets or sets the client-side script that executes when the HighlightFeatureOverlay is clicked.
Public PropertyOpacity Single Overlay Gets or sets the opacity level of the overlay.
Public PropertyQueryTools QueryTools FeatureOverlay Gets the QueryTools that allow you to easily query features from the FeatureOverlay.
Public PropertyStyle FeatureOverlayStyle FeatureOverlay Gets or sets a FeatureOverlayStyle object, which determines how the features are drawn at the client side.
Protected PropertyHasClickEvent Boolean Gets a flag that check whether it raise an event on the client side.
Protected PropertyHasTickEvent Boolean Overlay Indicates whether the overlay supports tick event.
Protected PropertyOverlayType String Overlay(overriden)
Public EventClick HighlightFeatureOverlayClickEventArgs Occurs when the HighlightFeatureOverlay is clicked.
Public EventTick EventArgs Overlay Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
Return Type Description
Boolean<!– System.Boolean –>
Name Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A JSON string which is used to create an overlay at the client side.
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
Void<!– System.Void –>
OnClick(HighlightFeatureOverlayClickEventArgs)
e HighlightFeatureOverlayClickEventArgs<!– ThinkGeo.MapSuite.WebEdition.HighlightFeatureOverlayClickEventArgs –> A HighlightFeatureOverlayClickEventArgs that contains the event data.
<!– ThinkGeo.MapSuite.WebEdition.HighlightFeatureOverlay –> Go Back
OnTick(EventArgs)
e EventArgs<!– System.EventArgs –> An System.EventArgs object that contains the event data.
The &lt;strong&gt;RegisterJavaScriptLibraryCore&lt;/strong&gt; method allows derived classes to override and register their own Javascript library URL to the HTML page.
page Page<!– System.Web.UI.Page –> The page object that is used for registering the javascript library.
Attribution
Return Type
AutoRefreshInterval
Return Type
TimeSpan<!– System.TimeSpan –>
Columns
Return Type
Collection<FeatureSourceColumn><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.FeatureSourceColumn} –>
<!– ThinkGeo.MapSuite.WebEdition.FeatureOverlay –> Go Back
ContextMenu
Return Type
ContextMenu<!– ThinkGeo.MapSuite.WebEdition.ContextMenu –>
EditTools
Return Type
EditTools<!– ThinkGeo.MapSuite.Core.EditTools –>
FeatureSource
Return Type
InMemoryFeatureSource<!– ThinkGeo.MapSuite.Core.InMemoryFeatureSource –>
Features
Return Type
GeoCollection<Feature><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Feature} –>
HighlightStyle
Return Type
FeatureOverlayStyle<!– ThinkGeo.MapSuite.WebEdition.FeatureOverlayStyle –>
Id
Return Type
IsBaseOverlay
Return Type
IsVisible
Return Type
Return Type
Return Type
OnClientClick
Return Type
Opacity
The &lt;strong&gt;Opacity&lt;/strong&gt; property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type
Single<!– System.Single –>
QueryTools
Return Type
QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –>
Style
Return Type
HasClickEvent
Return Type
HasTickEvent
Return Type
OverlayType
Return Type
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
Click
Event Arguments
Event Arguments
Tick
Event Arguments
Event Arguments
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
thinkgeo.mapsuite.webedition.highlightfeatureoverlay.1440040135.txt.gz · Last modified: 2015/09/18 03:07 (external edit)
