<!– Class –> Serves as the base class for the overlays that contain features and paint the features at client side.
The <strong>FeatureOverlay</strong> class is the base class for the overlays that need to draw features at client side. An instance of <strong>FeatureOverlay</strong> corresponds to an OpenLayer's vector layer at the client side.All features in the <strong>Features</strong> collection will be serialized to the client and drawn as the <strong>Style</strong> property specifies.<strong>Note:</strong> The <strong>Features</strong> property exposes the internal features of the <strong>FeatureSource</strong> property.The <strong>FeatureSource</strong> property provides you with a batch of properties and functions that affect its internal features.The <strong>Columns</strong> collection defines the column names for the feature data. It will be used to fetch a certain column from the data.The <strong>QueryTools</strong> and <strong>EditTools</strong> provide you an easy way to query or edit features.
*System.Object ThinkGeo.MapSuite.WebEdition.Overlay *ThinkGeo.MapSuite.WebEdition.FeatureOverlay ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay ThinkGeo.MapSuite.WebEdition.HighlightFeatureOverlay
![]() | This is constructor of FeatureOverlay class. | ||
![]() | String | This is constructor of FeatureOverlay class. | |
![]() | String, Boolean | This is constructor of FeatureOverlay class. |
![]() | Object | ||
![]() | Object | ||
![]() | EventArgs | Overlay | Raises the Tick event of the MarkerOverlay. |
![]() | Page | Overlay | Registers a Javascript library URL string to the client HTML page. |
![]() | String | Overlay | |
![]() | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
![]() | Collection<FeatureSourceColumn> | Gets a collection of FeatureSourceColumns, which specifies the column names of the feature data. | |
![]() | EditTools | Gets the EditTools that allow you to easily edit features in the FeatureOverlay. | |
![]() | InMemoryFeatureSource | Gets the FeatureSource of the FeatureOverlay. | |
![]() | GeoCollection<Feature> | Gets a collection of features that will be serialized to the client for drawing and editing. | |
![]() | String | Overlay | Gets the identifier for the overlay to be found. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
![]() | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
![]() | Single | Overlay | Gets or sets the opacity level of the overlay. |
![]() | QueryTools | Gets the QueryTools that allow you to easily query features from the FeatureOverlay. | |
![]() | FeatureOverlayStyle | Gets or sets a FeatureOverlayStyle object, which determines how the features are drawn at the client side. |
![]() | Boolean | Overlay | Indicates whether the overlay supports tick event. |
![]() | String | Overlay(overriden) | Gets a string that indicates which type the overlay is. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#FeatureOverlay.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#FeatureOverlay.28.29</a>
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#FeatureOverlay.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#FeatureOverlay.28String.29</a>
id | String<!– System.String –> | A string value indicates the Id property of this object. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#FeatureOverlay.28String.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#FeatureOverlay.28String.2C_Boolean.29</a>
isBaseOverlay | Boolean<!– System.Boolean –> | A boolean value indicates whether this overlay is base overlay or not. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#GetType.28.29</a>
Type<!– System.Type –> |
Returns a JSON string which contains the information for creating an overlay at the client side.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#ToJson.28.29</a>
String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#OnTick.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#OnTick.28EventArgs.29</a>
e | EventArgs<!– System.EventArgs –> | An System.EventArgs object that contains the event data. |
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
page | Page<!– System.Web.UI.Page –> | The page object that is used for registering the javascript library. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Attribution” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Attribution</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#AutoRefreshInterval</a>
Return Type |
TimeSpan<!– System.TimeSpan –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Columns” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Columns</a>
Return Type |
Collection<FeatureSourceColumn><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.FeatureSourceColumn} –> |
<!– ThinkGeo.MapSuite.WebEdition.FeatureOverlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#EditTools” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#EditTools</a>
Return Type |
EditTools<!– ThinkGeo.MapSuite.Core.EditTools –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#FeatureSource” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#FeatureSource</a>
Return Type |
InMemoryFeatureSource<!– ThinkGeo.MapSuite.Core.InMemoryFeatureSource –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Features” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Features</a>
Return Type |
GeoCollection<Feature><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Feature} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Id</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#IsBaseOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#IsBaseOverlay</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#IsVisible</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#IsVisibleInOverlaySwitcher” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#IsVisibleInOverlaySwitcher</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Name</a>
Return Type |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type |
Single<!– System.Single –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#QueryTools” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#QueryTools</a>
Return Type |
QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Style” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#Style</a>
Return Type |
FeatureOverlayStyle<!– ThinkGeo.MapSuite.WebEdition.FeatureOverlayStyle –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#HasTickEvent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#HasTickEvent</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#OverlayType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureOverlay#OverlayType</a>
Return Type |
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
Event Arguments |
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
