<!– Class –> This class defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class defines how features will be marked based on its scale. Inside of the ZoomLevelSet there are a number of marker zoomlevels. We will determine which MarkerZoomLevel to use based on which one has the Scale property closest to the current scale. The matching one will define the styles that will be used to mark the features on the map.
*System.Object **ThinkGeo.MapSuite.SilverlightEdition.MarkerZoomLevel
![]() | This is the constructor of MarkerZoomLevel class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | IEnumerable<Feature> | This method returns a collection of markers that is applied with the styles when the current zoomlevel falls into the ranges that defined. | |
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | ApplyUntilZoomLevel | Gets or sets the zoomlevel to which the styles will be applied. | |
![]() | MarkerStyle | Gets or sets a custom style that can be any type of MarkerStyle. | |
![]() | PointMarkerStyle | Gets or sets default style that is applied to the markers if the CustomMarkerStyle is not defined. |
This is the constructor of <strong>MarkerZoomLevel</strong> class.
Name | Type | Description |
Return Type | Description |
Int32<!– System.Int32 –> |
Collection<Marker><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.SilverlightEdition.Marker} –> | A Collection of markers that created from the feature collection. |
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.SilverlightCore.Feature} –> | A collection of features that is applied with the styles when the current zoomlevel falls into the ranges that defined. |
<!– ThinkGeo.MapSuite.SilverlightEdition.MarkerZoomLevel –> Go Back
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
ApplyUntilZoomLevel<!– ThinkGeo.MapSuite.SilverlightCore.ApplyUntilZoomLevel –> |
The CustomMarkerStyle has a higher priority than the DefaultMarkerStyle. When you define both styles, the CustomMarkerStyle will be applied. The CustomMarkerStyle can be any kind of MarkStyle while DefaultMarkerStyle can not.
Return Type |
MarkerStyle<!– ThinkGeo.MapSuite.SilverlightEdition.MarkerStyle –> |
Gets or sets the style that is applied to the markers if the CustomMarkerStyle is not defined.
Return Type |
PointMarkerStyle<!– ThinkGeo.MapSuite.SilverlightEdition.PointMarkerStyle –> |
