This class is the base class for all types of RoutingAlgorithm.
This is the default constructor for the RoutingAlgorithm and should be called by inherited classes.
GetRoute(RoutingSource,String,String)
This method returns a RoutingResult based on the extent you provided.
GetRouteCore(RoutingSource,String,String)
OnFindingRoute(FindingRouteRoutingAlgorithmEventArgs)
This method allows you to raise the FindingRoute event from a derived class.
Event Arguments:FindingRouteRoutingAlgorithmEventArgs
