thinkgeo.mapsuite.portablecore.wfsfeaturelayer
ThinkGeo.MapSuite.Core.WfsFeatureLayer
This class represents the wfs(web feature service) FeauteLayer.
      • ThinkGeo.MapSuite.Core.FeatureLayer
        • ThinkGeo.MapSuite.Core.WfsFeatureLayer
WfsFeatureLayer()
WfsFeatureLayer Constructor.
WfsFeatureLayer(String,String)
WfsFeatureSource Constructor
The parameters can not be null.
  • serviceLocationUrl
    • Description:The url of wfs service.
  • typeName
    • Description:The typename in the specify wfs service.
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
GetCapabilities(String)
Get capabilities from the specific wfs service url.
Every OGC Web Service (OWS), including a Web Feature Service, must have the ability to describe its capabilities by returning service metadata in response to a GetCapabilities request. Specifically, every web feature service must support the KVP encoded form of the GetCapabilities request over HTTP GET so that a client can always know how to obtain a capabilities document. The capabilities response document contains the following sections: 1. Service Identification section The service identification section provides information about the WFS service itself. 2. Service Provider section The service provider section provides metadata about the organization operating the WFS server. 3. Operation Metadata section The operations metadata section provides metadata about the operations defined in this specification and implemented by a particular WFS server. This metadata includes the DCP, parameters and constraints for each operation. 4. FeatureType list section This section defines the list of feature types (and operations on each feature type) that are available from a web feature service. Additional information, such as the default SRS, any other supported SRSs, or no SRS whatsoever (for non-spatial feature types), for WFS requests is provided for each feature type. 5. ServesGMLObjectType list section This section defines the list of GML Object types, not derived from gml:AbstractFeatureType, that are available from a web feature service that supports the GetGMLObject operation. These types may be defined in a base GML schema, or in an application schema using its own namespace. 6. SupportsGMLObjectType list section The Supports GML Object Type section defines the list of GML Object types that a WFS server would be capable of serving if it was deployed to serve data. described by an application schema that either used those GML Object types directly (for non-abstract types), or defined derived types based on those types. 7. Filter capabilities section The schema of the Filter Capabilities Section is defined in the Filter Encoding Implementation Specification [3]. This is an optional section. If it exists, then the WFS should support the operations advertised therein. If the Filter Capabilities Section is not defined, then the client should assume that the server only supports the minimum default set of filter operators.
  • Description:The xml text represents capabilities of this wfs server.
GetCapabilities(Uri)
  • serverUri
    • Type:Uri
GetCapabilities(Uri,WebProxy)
  • serverUri
    • Type:Uri
  • webProxy
    • Type:WebProxy
    • Description:The proxy of the wfs service.
GetLayers(String)
Get layer names from specific wfs service url.
Typically, it will call WfsFeatureSource.GetLayers(serviceLocationUrl) internally.
  • Type:Collection<String>
  • Description:The collection represent layer names.
GetLayers(Uri,WebProxy)
Typically, it will call WfsFeatureSource.GetLayers(serverUri) internally.
  • serverUri
    • Type:Uri
  • webProxy
    • Type:WebProxy
GetLayers(Uri)
  • serverUri
    • Type:Uri
1BU=(IEnumerable<String>)
  • returningColumnNames
    • Type:IEnumerable<String>
1xU=(GeoCanvas,Dictionary<String,Collection<Feature»,Collection<SimpleCandidate>,ZoomLevel,RectangleShape)
  • featuresForFilters
  • currentZoomLevel
SetupTools()
SetupToolsCore()
OpenCore()
CloseCore()
GetBoundingBoxCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
LastXmlResponse
The xml text represnets last respone, it will pass out by RequestedData event as parameter.
ServiceLocationUrl
TypeName
TimeoutInSeconds
This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
HasBoundingBox
This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
The default value is false.
WebProxy
This property gets or sets the proxy used for requesting a Web Response.
  • Type:WebProxy
WrappingExtent
WrappingMode
EditTools
FeatureIdsToExclude
QueryTools
MaxRecordsToDraw
FeatureSource
DrawingQuality
ZoomLevelSet
DrawingMarginPercentage
DrawingMarginInPixel
  • Type:Single
GeometryValidationMode
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
yhU=
  • Type:Int64
zRU=
  • Type:Int64
0BU=
  • Type:TimeSpan
0xU=
  • Type:TimeSpan
IsOpenCore
SendingWebRequest N/A
Event Arguments:SendingWebRequestEventArgs
SentWebRequest N/A
Event Arguments:SentWebRequestEventArgs
DrawingFeatures N/A
DrawingWrappingFeatures N/A
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.portablecore.wfsfeaturelayer.txt · Last modified: 2017/03/16 21:59 (external edit)
