thinkgeo.mapsuite.portablecore.iconvaluestyle
ThinkGeo.MapSuite.Core.IconValueStyle
This class allows you to choose different icons based on values in the data of a feature.
    • ThinkGeo.MapSuite.Core.Style
      • ThinkGeo.MapSuite.Core.PositionStyle
        • ThinkGeo.MapSuite.Core.IconValueStyle
IconValueStyle()
If you use this constructor, then you need to set the required properties manually.
IconValueStyle(String)
  • columnName
    • Description:This parameter is the column name you want to match on.
IconValueStyle(String,IEnumerable<IconValueItem>)
  • columnName
  • iconValueItems
    • Type:IEnumerable<IconValueItem>
    • Description:This parameter is the icon value items you want to match on.
CloneDeep()
  • Type:Style
  • features
    • Type:IEnumerable<Feature>
  • shapes
    • Type:IEnumerable<BaseShape>
GetRequiredColumnNames()
  • Type:Collection<String>
DrawSample(GeoCanvas)
SaveStyle(String)
  • filePathName
SaveStyle(Stream)
  • stream
    • Type:Stream
  • Description:None
  • features
  • canvas
    • Type:GeoCanvas
  • labelsInThisLayer
  • labelsInAllLayers
GetRequiredColumnNamesCore()
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:This method returns a collection of the column names that it needs.
GetLabelingCandidateCore(Feature,GeoCanvas)
This method determines whether the specified feature is a good candidate to be labeled, based on the labeling properties set.
This overridden method is called from the concrete public method Draw. In this method, we take the feature you passed in and determine if it is a candidate for labeling. If it is, then we will add it to the return collection. The algorithm to determine whether the label will draw is complex and determined by a number of properties and factors.
  • feature
    • Type:Feature
    • Description:This parameter is the feature that will be considered as a labeling candidate.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas that will be used to draw the feature. This method will not draw on this canvas, but rather will use it to determine font size, etc.
FilterFeatures(IEnumerable<Feature>,GeoCanvas)
  • Type:Collection<Feature>
  • features
FilterFeaturesCore(IEnumerable<Feature>,GeoCanvas)
  • features
AbbreviateText(Feature,GeoCanvas)
  • feature
AbbreviateTextCore(Feature,GeoCanvas)
  • feature
GetLabelingCandidates(Feature,GeoCanvas)
  • feature
CheckDuplicate(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckDuplicateCore(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckOverlapping(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckOverlappingCore(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
lD8=(PolygonShape,String,GeoCanvas)
  • text
Format(String,BaseShape)
  • text
  • labeledShape
FormatCore(String,BaseShape)
  • text
  • labeledShape
OnFormatting(FormattingPositionStyleEventArgs)
OnFormatted(FormattedPositionStyleEventArgs)
CloneDeepCore()
  • Type:Style
ColumnName
This property gets and sets the column name that will be used for the drawing and matching.
This column name will be used to draw the text on the icon (if necessary) and to also match the value in the IconStyleItem.
IconValueItems
This property gets the collection of IconValueItems for matching.
You should create your IconValueItems and place them in this collection for consideration.
PolygonLabelingLocationMode
MaxNudgingInPixel
NudgingIntervalInPixel
  • Type:Single
BestPlacementSymbolWidth
  • Type:Single
BestPlacementSymbolHeight
  • Type:Single
AbbreviationDictionary
LeaderLineStyle
LeaderLineRule
LeaderLineMinimumLengthInPixels
  • Type:Single
GridSize
DuplicateRule
OverlappingRule
AllowLineCarriage
SuppressPartialLabels
ForceLineCarriage
FittingPolygon
LabelAllPolygonParts
LabelAllLineParts
FittingPolygonFactor
TextLineSegmentRatio
BestPlacement
PointPlacement
MaskType
IsActive
RequiredColumnNames
Filters
xT8=
LabelPositions
XOffsetInPixel
  • Type:Single
YOffsetInPixel
  • Type:Single
CustomTextStyles
RotationAngle
FittingLineInScreen
FittingPolygonInScreen
TextFormat
NumericFormat
DateFormat
TextSolidBrush
Font
HaloPen
TextColumnName
Mask
MaskMargin
Advanced
AllowSpline
ForceHorizontalLabelForLine
SplineType
DrawingLevel
uBs=
FiltersCore
Formatting N/A
Event Arguments:FormattingPositionStyleEventArgs
Formatted N/A
Event Arguments:FormattedPositionStyleEventArgs
thinkgeo.mapsuite.portablecore.iconvaluestyle.1442823052.txt.gz · Last modified: 2015/09/21 08:10 by admin
