thinkgeo.mapsuite.portablecore.huefamilyareastyle
ThinkGeo.MapSuite.Core.HueFamilyAreaStyle
    • ThinkGeo.MapSuite.Core.Style
      • ThinkGeo.MapSuite.Core.AreaStyle
        • ThinkGeo.MapSuite.Core.HueFamilyAreaStyle
HueFamilyAreaStyle()
  • This is the constructor for the class. If you use this constructor, then you need to set the required properties manually.
  • None
HueFamilyAreaStyle(GeoPen,GeoColor,Int32)
  • This is the constructor the for the class.
  • None.
  • outlinePen
    • Type:GeoPen
    • Description:This parameter represents the outline pen that will be used on the style.
  • baseColor
    • Type:GeoColor
    • Description:This parameter represents the base color that will be used in the class.
  • numberOfColors
    • Description:This prameter represents how many colors will be used in the style, based on the base color.
HueFamilyAreaStyle(GeoPen,GeoColor,Int32,PenBrushDrawingOrder)
  • None.
  • outlinePen
    • Type:GeoPen
  • baseColor
    • Type:GeoColor
  • numberOfColors
  • penBrushDrawingOrder
    • Description:This parameter describes the PenBrushDrawingOrder that will be used when drawing the area type feature.
ClearCache()
  • This method clears the cached style in the cache.
  • Description:None.
CloneDeep()
  • Type:Style
  • features
    • Type:IEnumerable<Feature>
  • shapes
    • Type:IEnumerable<BaseShape>
GetRequiredColumnNames()
  • Type:Collection<String>
DrawSample(GeoCanvas)
  • This method draws the features on the canvas you provided.
  • This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently. When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • features
  • canvas
    • Type:GeoCanvas
  • labelsInThisLayer
  • labelsInAllLayers
CloneDeepCore()
  • Type:Style
GetRequiredColumnNamesCore()
NumberOfColors
  • This gets or sets the number of colors in the style.
  • None.
Cache
  • This gets the cached style in the class.
  • This gets the cached style in the class. The key of the style in the cache is feature.Id & feature.GetHashCode().
BaseColor
  • This gets or sets the base color of the style.
  • None.
XOffsetInPixel
  • Type:Single
YOffsetInPixel
  • Type:Single
FillSolidBrush
CustomAreaStyles
OutlinePen
Advanced
DrawingLevel
IsActive
RequiredColumnNames
Filters
IsDefault
FiltersCore
thinkgeo.mapsuite.portablecore.huefamilyareastyle.txt · Last modified: 2017/03/16 21:59 (external edit)
