thinkgeo.mapsuite.portablecore.geobrush
ThinkGeo.MapSuite.Core.GeoBrush
GeoBrush()
  • This is the constructor for the GeoBrush
  • None
CloneDeep()
  • Create a copy of GeoBrush using the deep clone process.
  • The difference between deep clone and shallow clone is as follows: In shallow cloning, only the object is copied; the objects within it are not. By contrast, deep cloning copies the cloned object as well as all the objects within.
  • Type:GeoBrush
  • Description:A cloned GeoBrush.
CloneDeepCore()
  • Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization.
  • Type:GeoBrush
Id
  • The id of the GeoBrush. This is always used as a key when in the cached brushes.
  • Type:Int64
thinkgeo.mapsuite.portablecore.geobrush.txt · Last modified: 2017/03/16 21:59 (external edit)
