thinkgeo.mapsuite.portablecore.bitmaptilecache
ThinkGeo.MapSuite.PortableCore.BitmapTileCache
<!– Class –> This is the base class for BitmapTileCache system which inherits from TileCache class.
TileCahce system is very efficient in improving the performance of application, especially when large data or remote server images are included.
Protected MethodBitmapTileCache String, TileImageFormat, TileMatrix This is the constructor of the class.
Public MethodClearCache TileCache This method will clear all the tiles in the tileCache.
Public MethodDeleteTile Tile TileCache This method will delete the target tile passed in.
Public MethodDeleteTiles RectangleShape TileCache This method will delete the tiles within the passed in worldExtent.
Public MethodGetHigherScaleTile RectangleShape, Double This method will return the HigherScale BitmapTile which is always used for preview effects when ZoomIn or ZoomOut.
Public MethodGetTile RectangleShape This method returns the BitmapTile corresponding to the tile bounding box passed in.
Public MethodGetTile Int64, Int64 This method returns the BitmapTile corresponding to passed in row and column.
Public MethodGetTiles RectangleShape This method returns all the BitmapTiles within the passed in world extent, some of which may not has bitmap.
Public MethodGetType Object
Public MethodSaveTile Tile TileCache This method will save the target tile passed in.
Public MethodSaveTiles GeoImage, RectangleShape TileCache This method will save the bitmap with its extent attached into tiles.
Public MethodToString Object
Protected MethodClearCacheCore TileCache This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method.
Protected MethodDeleteTileCore Tile TileCache This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method.
Protected MethodGetHigherScaleTileCore RectangleShape, Double This method is virtual and can be overriden by its sub classes. This method will return the HigherScale BitmapTile which is always used for preview effects when ZoomIn or ZoomOut.
Protected MethodGetTileCore Int64, Int64 This abstract method returns the BitmapTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column.
Protected MethodMergeBitmaps IEnumerable<BitmapTile>, Double This method will merege the passed in bitmap tiles into a larege bitmap tile.
Protected MethodOnGettingCacheImage GettingCacheImageBitmapTileCacheEventArgs
Protected MethodOnGottenCacheImage GottenCacheImageBitmapTileCacheEventArgs
Protected MethodSaveTileCore Tile TileCache This abstract method will save the target tile passed in, for each sub TileCache class must implement this method.
Public PropertyCacheId String TileCache Gets or sets the id of the TileCache.
Public PropertyImageFormat TileImageFormat TileCache Gets or sets the tile image format.
Public PropertyJpegQuality Int16 TileCache Gets or sets the Jpeg quality , this property only take effects when setting the ImageFormat to Jpeg.
Public PropertyLoadingTileImage GeoImage TileCache This property returns back a preset image showing the Tile is loading.
Public PropertyNoDataTileImage GeoImage TileCache This property returns back a preset image showing the tile data is missing.
Public PropertyTileAccessMode TileAccessMode TileCache Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete
Public PropertyTileMatrix TileMatrix TileCache Gets or sets the TileMatrix which is used in caculation for tiles.
BitmapTileCache(String, TileImageFormat, TileMatrix)
Name Type Description
cacheId String<!– System.String –> This is the cache identifier which marks its difference with other TileCache.
imageFormat TileImageFormat<!– ThinkGeo.MapSuite.PortableCore.TileImageFormat –> This is the imageFormate showing what kind of image we are trying to save.
tileMatrix TileMatrix<!– ThinkGeo.MapSuite.PortableCore.TileMatrix –> This is the tile matrix system which is used for caculating tiles.
Go Back
ClearCache()
This method will not take effect when the ReadOnly is set to true.
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.PortableCore.TileCache –> Go Back
DeleteTile(Tile)
tile Tile<!– ThinkGeo.MapSuite.PortableCore.Tile –> The target tile to be deleted.
DeleteTiles(RectangleShape)
worldExtent RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> The target extent to delete all tiles within it.
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetHigherScaleTile(RectangleShape, Double)
BitmapTile<!– ThinkGeo.MapSuite.PortableCore.BitmapTile –> Returns the higher scale(higher zoomLevel) bitmap tile.
tileBoundingBox RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> The parameter specifies the current tile bounding box.
tileScale Double<!– System.Double –> This parameter specifies the current tile scale.
<!– ThinkGeo.MapSuite.PortableCore.BitmapTileCache –> Go Back
GetTile(RectangleShape)
BitmapTile<!– ThinkGeo.MapSuite.PortableCore.BitmapTile –> Returns the BitmapTile corresponding to the passed in boundingBox.
tileBoundingBox RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> The target boundingBox for the tile to fetch.
GetTile(Int64, Int64)
BitmapTile<!– ThinkGeo.MapSuite.PortableCore.BitmapTile –> Returns the BitmapTile corresponding to the passed in row and column.
row Int64<!– System.Int64 –> The target row for the tile to fetch.
column Int64<!– System.Int64 –> The target column for the tile to fetch.
GetTiles(RectangleShape)
Collection<BitmapTile><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.BitmapTile} –> Returns a collection of BitmapTiles within the passed in worldExtent.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> The target worldExtent will be used to fetch all the BitmapTiles from.
Type<!– System.Type –>
SaveTile(Tile)
tile Tile<!– ThinkGeo.MapSuite.PortableCore.Tile –> The target tile to be saved.
SaveTiles(GeoImage, RectangleShape)
bitmap GeoImage<!– ThinkGeo.MapSuite.PortableCore.GeoImage –> The target bitmap to be saved into tiles.
bitmapExtent RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> The target extent for the bitmap.
ClearCacheCore()
DeleteTileCore(Tile)
GetHigherScaleTileCore(RectangleShape, Double)
GetTileCore(Int64, Int64)
MergeBitmaps(IEnumerable<BitmapTile>, Double)
BitmapTile<!– ThinkGeo.MapSuite.PortableCore.BitmapTile –> Returns a merged bitmap tile.
tilesToMerge IEnumerable<BitmapTile><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.BitmapTile} –> The collection of tiles to be mereged.
scale Double<!– System.Double –> The target scale for result mereged bitmap tile.
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
e GettingCacheImageBitmapTileCacheEventArgs<!– ThinkGeo.MapSuite.PortableCore.GettingCacheImageBitmapTileCacheEventArgs –>
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
e GottenCacheImageBitmapTileCacheEventArgs<!– ThinkGeo.MapSuite.PortableCore.GottenCacheImageBitmapTileCacheEventArgs –>
SaveTileCore(Tile)
CacheId
Return Type
ImageFormat
Return Type
JpegQuality
Return Type
Int16<!– System.Int16 –>
LoadingTileImage
Return Type
NoDataTileImage
Return Type
TileAccessMode
If you want it to take effect, you need set the ReadOnly property false.
Return Type
TileAccessMode<!– ThinkGeo.MapSuite.PortableCore.TileAccessMode –>
TileMatrix
Return Type
GettingCacheImage
Event Arguments
Event Arguments
GottenCacheImage
Event Arguments
Event Arguments
thinkgeo.mapsuite.portablecore.bitmaptilecache.1440040132.txt.gz · Last modified: 2015/09/21 08:04 (external edit)
