thinkgeo.mapsuite.portablecore.inmemorybitmaptilecache
ThinkGeo.MapSuite.Core.InMemoryBitmapTileCache
This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
    • ThinkGeo.MapSuite.Core.TileCache
      • ThinkGeo.MapSuite.Core.BitmapTileCache
        • ThinkGeo.MapSuite.Core.InMemoryBitmapTileCache
InMemoryBitmapTileCache()
  • This is the default constructor.
  • If you use this constructor, you have to set the properties manually.
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
GetHigherScaleTile(RectangleShape,Double)
  • tileScale
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(GeoImage,RectangleShape)
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
GetTileCore(Int64,Int64)
  • This method returns the BitmapTile corresponding to passed in row and column.
  • Description:Returns the BitmapTile corresponding to the passed in row and column.
  • row
    • Type:Int64
    • Description:The target row for the tile to fetch.
  • column
    • Type:Int64
    • Description:The target column for the tile to fetch.
SaveTileCore(Tile)
  • This method will save the target tile passed in.
  • This method will not take effect when the ReadOnly is set to true.
  • tile
    • Type:Tile
    • Description:The target tile to be saved.
DeleteTileCore(Tile)
  • This method will delete the target tile passed in.
  • tile
    • Type:Tile
    • Description:The target tile to be deleted.
ClearCacheCore()
  • This method will clear all the tiles in the tileCache.
GetHigherScaleTileCore(RectangleShape,Double)
  • This method overrides the logic in its base class BitmapTileCache. This method will return the HigherScale BitmapTile which is always used for preview effects when ZoomIn or ZoomOut.
  • Description:Returns the higher scale(higher zoomLevel) bitmap tile.
  • tileBoundingBox
    • Description:The parameter specifies the current tile bounding box.
  • tileScale
    • Description:This parameter specifies the current tile scale.
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
MaximumTilesCount
  • This property gets or sets the maximum tiles count, if it exceed,it will delete the old first cached tiles.
CachedTilesByScale
  • This property gets the Cached tiles,each item is a Dictionary with scale as its key.
TileAccessMode
NoDataTileImage
LoadingTileImage
ImageFormat
JpegQuality
  • Type:Int16
CacheId
GottenCacheImage
Event Arguments:GottenCacheImageBitmapTileCacheEventArgs
GettingCacheImage
thinkgeo.mapsuite.portablecore.inmemorybitmaptilecache.txt · Last modified: 2017/03/16 21:59 (external edit)
