thinkgeo.mapsuite.portablecore.bitmaptile
ThinkGeo.MapSuite.Core.BitmapTile
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
BitmapTile()
  • This is the default constructor without passing any parameters. All its properties should be set via the properties.
BitmapTile(RectangleShape,Double)
  • This is the constructor for Tile by passing the boundingBox and scale.
  • scale
BitmapTile(GeoImage,RectangleShape,Double)
  • This is the constructor for Tile by passing image bitmap and the boundingBox and scale.
  • scale
GetBitmapStream()
  • Type:Stream
Dispose()
  • This method is targeting releasing or resetting unmanaged resources.
CloneDeep()
  • Type:Tile
GetBitmapStreamCore()
  • Type:Stream
  • This method is the destructorof this class. Destructor cannot be called and only will be invoked automatically.
CloneDeepCore()
  • Type:Tile
Bitmap
  • This property is the NativeImage showing the tile image.
Scale
BoundingBox
thinkgeo.mapsuite.portablecore.bitmaptile.txt · Last modified: 2017/03/16 21:59 (external edit)
