thinkgeo.mapsuite.portablecore.tilecache
ThinkGeo.MapSuite.Core.TileCache
TileCache(String,TileImageFormat,TileMatrix)
  • This is the constructor of the class.
  • cacheId
    • Description:This is the cache identifier which marks its difference with other TileCache.
  • imageFormat
    • Description:This is the imageFormate showing what kind of image we are trying to save.
  • tileMatrix
    • Description:This is the tile matrix system which is used for caculating tiles.
SaveTile(Tile)
  • This method will save the target tile passed in.
  • This method will not take effect when the ReadOnly is set to true.
  • tile
    • Type:Tile
    • Description:The target tile to be saved.
SaveTiles(GeoImage,RectangleShape)
  • This method will save the bitmap with its extent attached into tiles.
  • bitmap
    • Type:GeoImage
    • Description:The target bitmap to be saved into tiles.
  • bitmapExtent
DeleteTiles(RectangleShape)
  • This method will delete the tiles within the passed in worldExtent.
  • worldExtent
    • Description:The target extent to delete all tiles within it.
DeleteTile(Tile)
  • This method will delete the target tile passed in.
  • tile
    • Type:Tile
    • Description:The target tile to be deleted.
ClearCache()
  • This method will clear all the tiles in the tileCache.
ClearCacheCore()
  • This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method.
SaveTileCore(Tile)
  • This abstract method will save the target tile passed in, for each sub TileCache class must implement this method.
  • tile
    • Type:Tile
DeleteTileCore(Tile)
  • This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method.
  • tile
    • Type:Tile
TileMatrix
  • Gets or sets the TileMatrix which is used in caculation for tiles.
TileAccessMode
  • Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete
  • If you want it to take effect, you need set the ReadOnly property false.
NoDataTileImage
  • This property returns back a preset image showing the tile data is missing.
LoadingTileImage
  • This property returns back a preset image showing the Tile is loading.
ImageFormat
  • Gets or sets the tile image format.
JpegQuality
  • Gets or sets the Jpeg quality , this property only take effects when setting the ImageFormat to Jpeg.
  • Type:Int16
CacheId
  • Gets or sets the id of the TileCache.
thinkgeo.mapsuite.portablecore.tilecache.txt · Last modified: 2017/03/16 21:59 (external edit)
