thinkgeo.mapsuite.portablecore.filebitmaptilecache
ThinkGeo.MapSuite.Core.FileBitmapTileCache
FileBitmapTileCache()
  • This is the default constructor.
  • If you use this constructor, you have to set the properties manually.
FileBitmapTileCache(String)
  • This is the overloads constructor.
  • If you use this constructor, the other properties are set with default values.
  • cacheDirectory
    • Description:This parameter specifies the cache directory of the tile cache.
FileBitmapTileCache(String,String)
  • cacheDirectory
  • cacheId
    • Description:This parameter specifies the cache id of the tile cache.
FileBitmapTileCache(String,String,TileImageFormat,TileMatrix)
  • This is the constructor with all the parameters needed passed in.
  • cacheDirectory
  • cacheId
  • imageFormat
    • Description:This parameter specifies the image format of the tile cahce.
  • tileMatrix
    • Description:This parameter specifies the tile matrix of the tile cache.
ClearCache(TimeSpan,Double)
  • tileExpiration
    • Type:TimeSpan
  • maxSizeInMegabytes
GetTileImageFileName(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTileImageFileNames(RectangleShape)
  • Type:Collection<String>
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
GetHigherScaleTile(RectangleShape,Double)
  • tileScale
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(GeoImage,RectangleShape)
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
GetTileCore(Int64,Int64)
  • This method returns the BitmapTile corresponding to passed in row and column.
  • Description:Returns the BitmapTile corresponding to the passed in row and column.
  • row
    • Type:Int64
    • Description:The target row for the tile to fetch.
  • column
    • Type:Int64
    • Description:The target column for the tile to fetch.
SaveTileCore(Tile)
  • This method will save the target tile passed in, you could override this API to create your own logic.
  • tile
    • Type:Tile
    • Description:The target tile to be saved.
DeleteTileCore(Tile)
  • This method will delete the target tile passed in.
  • This method will not take effect when the ReadOnly is set to true.
  • tile
    • Type:Tile
    • Description:The target tile to be deleted.
CheckExpiration(String)
  • tileImageFileName
GetBinariesFromBitmap(GeoImage)
  • Type:Byte[]
ClearCacheCore()
  • This method will clear all the tiles in the tileCache.
GetHigherScaleTileCore(RectangleShape,Double)
  • This method overrides the logic in its base class BitmapTileCache. This method will return the HigherScale BitmapTile which is always used for preview effects when ZoomIn or ZoomOut.
  • Description:Returns the higher scale(higher zoomLevel) bitmap tile.
  • tileBoundingBox
    • Description:The parameter specifies the current tile bounding box.
  • tileScale
    • Description:This parameter specifies the current tile scale.
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
GetEncoder(GeoImageFormat)
  • Type:ImageCodecInfo
GetTemporaryFolder()
CacheDirectory
  • Gets or sets the cache direcory.
ExpirationTime
  • Type:TimeSpan
TileMatrix
TileAccessMode
NoDataTileImage
LoadingTileImage
ImageFormat
JpegQuality
  • Type:Int16
CacheId
CapabilityInMegaBytes
GottenCacheImage
Event Arguments:GottenCacheImageBitmapTileCacheEventArgs
GettingCacheImage
thinkgeo.mapsuite.portablecore.filebitmaptilecache.txt · Last modified: 2017/03/16 21:59 (external edit)
