<!– Class –> This is the base class of AdornmentLayers. The AdornmentLayer is used to place adornments on the map. Two types of AdornmentLayers are provided: ScaleLineAdornmentLayer and ScaleBarAdornmentLayer.
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.AdornmentLayer ThinkGeo.MapSuite.PortableCore.GraticuleAdornmentLayer ThinkGeo.MapSuite.PortableCore.KmlAdornmentLayer ThinkGeo.MapSuite.PortableCore.LegendAdornmentLayer ThinkGeo.MapSuite.PortableCore.LogoAdornmentLayer ThinkGeo.MapSuite.PortableCore.MagneticDeclinationAdornmentLayer ThinkGeo.MapSuite.PortableCore.ScaleBarAdornmentLayer ThinkGeo.MapSuite.PortableCore.ScaleLineAdornmentLayer
AdornmentLayer | This method is the default constructor for the AdornmentLayer. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetDrawingLocation | GeoCanvas, Single, Single | This method returns the drawing location of the AdornmentLayer. | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | Layer | ||
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the AdornmentLayer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OpenCore | Layer | This method opens the Layer so that it is initialized and ready to use. |
BackgroundMask | AreaStyle | ||
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
Height | Single | ||
Location | AdornmentLocation | This property gets and sets the drawing location of the AdornmentLayer. | |
Width | Single | ||
XOffsetInPixel | Single | This property gets and sets the X pixel offset for the AdornmentLayer. | |
YOffsetInPixel | Single | This property gets and sets the Y pixel offset for the AdornmentLayer. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
| RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
| ScreenPointF<!– ThinkGeo.MapSuite.PortableCore.ScreenPointF –> | It returns the upper left screen point of where the AdornmentLayer will be drawn. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas used in drawing. |
| adornmentWidth | Single<!– System.Single –> | This parameter is the width of the adornment. |
| adornmentHeight | Single<!– System.Single –> | This parameter is the height of the adornment |
<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayer –> Go Back
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
This virtual method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.
You can use the full power of the GeoCanvas to do the drawing.
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object (or a GeoImage) to draw on. |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
| args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
| e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
| e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
| args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
| e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
| eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
| eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
| AreaStyle<!– ThinkGeo.MapSuite.PortableCore.AreaStyle –> |
| DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
The default value is false.
| AdornmentLocation<!– ThinkGeo.MapSuite.PortableCore.AdornmentLocation –> |
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
