thinkgeo.mapsuite.portablecore.graticuleadornmentlayer
ThinkGeo.MapSuite.Core.GraticuleAdornmentLayer
GraticuleAdornmentLayer shows Meridians and Parallels displaying through the map. Meridians are lines of longitude and they have a North South orientation. Parallels are lines of latitude and they have an East West orientation. Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users.
      • ThinkGeo.MapSuite.Core.AdornmentLayer
        • ThinkGeo.MapSuite.Core.GraticuleAdornmentLayer
GraticuleAdornmentLayer()
  • This is the default constructor of the class.
  • If use this constructor, the projection is null.
GraticuleAdornmentLayer(Projection)
  • projection
    • Description:This parameter represents the external projection which the map is actually displayed in, the internal projection is the Geodetic projection (Decimal Degrees).
GetDrawingLocation(GeoCanvas,Single,Single)
  • adornmentWidth
    • Type:Single
  • adornmentHeight
    • Type:Single
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • This method draws the AdornmentLayer.
  • This virtual method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided. You can use the full power of the GeoCanvas to do the drawing.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object (or a GeoImage) to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
OpenCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
CloseCore()
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
GraticuleLineStyle
  • Gets or Sets the LineStyle of the Meridians and Parallels.
GraticuleTextFont
  • Gets or Sets the GeoFont of the Meridians and Parallels.
GraticuleTextBrush
  • Gets or Sets the GeoBrush of the Meridians and Parallels.
Projection
  • Gets or Sets the Projection of the Meridians and Parallels.
WrappingMode
WrappingExtent
GraticuleTextHaloPen
Width
  • Type:Single
Height
  • Type:Single
BackgroundMask
Location
XOffsetInPixel
  • Type:Single
YOffsetInPixel
  • Type:Single
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
ActualWidth
  • Type:Single
IsOpenCore
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.graticuleadornmentlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
