thinkgeo.mapsuite.portablecore.adornmentlayer
ThinkGeo.MapSuite.Core.AdornmentLayer
AdornmentLayer()
  • This method is the default constructor for the AdornmentLayer.
  • None
GetDrawingLocation(GeoCanvas,Single,Single)
  • This method returns the drawing location of the AdornmentLayer.
  • Description:It returns the upper left screen point of where the AdornmentLayer will be drawn.
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas used in drawing.
  • adornmentWidth
    • Type:Single
    • Description:This parameter is the width of the adornment.
  • adornmentHeight
    • Type:Single
    • Description:This parameter is the height of the adornment
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • This method draws the AdornmentLayer.
  • This virtual method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided. You can use the full power of the GeoCanvas to do the drawing.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object (or a GeoImage) to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
OpenCore()
CloseCore()
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
Width
  • Type:Single
Height
  • Type:Single
BackgroundMask
Location
  • This property gets and sets the drawing location of the AdornmentLayer.
XOffsetInPixel
  • This property gets and sets the X pixel offset for the AdornmentLayer.
  • This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
  • Type:Single
YOffsetInPixel
  • This property gets and sets the Y pixel offset for the AdornmentLayer.
  • This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
  • Type:Single
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
ActualWidth
  • Type:Single
IsOpenCore
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.adornmentlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
