thinkgeo.mapsuite.portablecore.scalelineadornmentlayer
ThinkGeo.MapSuite.Core.ScaleLineAdornmentLayer
The ScaleLineAdornmentLayer is a concrete class inherited from AdornmentLayer. The ScaleLineAdornmentLayer class allows you show a ScaleLine graphic on the map.
      • ThinkGeo.MapSuite.Core.AdornmentLayer
        • ThinkGeo.MapSuite.Core.ScaleLineAdornmentLayer
ScaleLineAdornmentLayer()
  • Creates a new instance of the ScaleLineAdornmentLayer class. The default location of this ScaleLineAdornmentLayer is the lower left corner of the CurrentExtent of the map.
ScaleLineAdornmentLayer(ScreenPointF)
  • Creates a new instance of the ScaleLineAdornmentLayer class by passing in the specified ScreenPoint, which will be the start position of this ScaleLineAdornmentLayer when it is shown on the map.
  • startPoint
    • Description:The start position of the ScaleLineAdornmentLayer that will be shown on the Map.
ScaleLineAdornmentLayer(AdornmentLocation)
  • Creates a new instance of the ScaleLineAdornmentLayer class by passing in the specified enumeration of the AdornmentLocation that will be used to set the start position of this ScaleLineAdornmentLayer when it is shown on the map.
  • location
    • Description:This parameter specifies the location of the start point of the ScaleLineAdornmentLayer.
GetDrawingLocation(GeoCanvas,Single,Single)
  • adornmentWidth
    • Type:Single
  • adornmentHeight
    • Type:Single
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • This method draws the Layer.
  • This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
OpenCore()
CloseCore()
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
ProjectionToDecimalDegrees
  • Gets or sets a Proj4 projection parameter string which shows what coordinate system the map is using.
ProjectionParametersString
DisplayUnitString
  • This propery is a dictionary that exposes what text will be drawn to represent the ScaleLine Unit.
  • We will display different letters for different units of measure; for example: “m” for meters, “ft” for feet, etc.
UnitSystem
  • Gets or sets the UnitSystem to be used for the ScaleLine.
  • By setting this property, you can set the top and button unit for the ScaleLine.
TextStyle
Width
  • Type:Single
Height
  • Type:Single
BackgroundMask
Location
XOffsetInPixel
  • Type:Single
YOffsetInPixel
  • Type:Single
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
ActualWidth
  • Type:Single
IsOpenCore
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.scalelineadornmentlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
