thinkgeo.mapsuite.portablecore.adornmentlocation
ThinkGeo.MapSuite.Core.AdornmentLocation
  • None
Items
UseOffsets
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the upper left point.
UpperLeft
UpperCenter
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the upper center point.
UpperRight
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the upper right point.
CenterLeft
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the center left point.
Center
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the center point.
CenterRight
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the center right point.
LowerLeft
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the lower left point.
LowerCenter
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the lower center point.
LowerRight
  • Summary:This method makes the GetDrawingLocation function calculate the drawing location by XOffset and YOffset from the lower right point.
thinkgeo.mapsuite.portablecore.adornmentlocation.txt · Last modified: 2017/03/16 21:59 (external edit)
