<!– Class –> A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.OverlaySetting`2[[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay **ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting
![]() | WorldMapKitWmsWebOverlay | Initializes a new instance of the WorldMapKitWmsWebOverlaySetting class. |
![]() | Object | ||
![]() | Object |
![]() | WorldMapKitWmsWebOverlay | MvcElementSettingBase<WorldMapKitWmsWebOverlay,WorldMapKitWmsWebOverlaySetting> |
Name | Type | Description |
worldMapKitWmsWebOverlay | WorldMapKitWmsWebOverlay<!– ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay –> |
Return Type | Description |
WorldMapKitWmsWebOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting –> |
timeSpan | TimeSpan<!– System.TimeSpan –> |
<!– ThinkGeo.MapSuite.MvcEdition.OverlaySetting{ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay,ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting} –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
id | String<!– System.String –> |
isBaseOverlay | Boolean<!– System.Boolean –> |
isVisible | Boolean<!– System.Boolean –> |
isVisibleInOverlaySwitcher | Boolean<!– System.Boolean –> |
name | String<!– System.String –> |
clientTickFunctionName | String<!– System.String –> |
opacity | Single<!– System.Single –> |
projection | WorldMapKitProjection<!– ThinkGeo.MapSuite.Core.WorldMapKitProjection –> |
<!– ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting –> Go Back
Set tileHeight for Element property and retun the WorldMapKitWmsWebOverlaySetting
WorldMapKitWmsWebOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting –> | The setting of WorldMapKitWmsWebOverlaySetting itself |
tileHeight | Int32<!– System.Int32 –> | A tileHeight for Element property |
Set tileType for Element property and retun the WorldMapKitWmsWebOverlaySetting
tileType | TileType<!– ThinkGeo.MapSuite.MvcEdition.TileType –> | A tileType for Element property |
Set tileWidth for Element property and retun the WorldMapKitWmsWebOverlaySetting
tileWidth | Int32<!– System.Int32 –> | A tileWidth for Element property |
Set transitionEffect for Element property and retun the WorldMapKitWmsWebOverlaySetting
transitionEffect | TransitionEffect<!– ThinkGeo.MapSuite.MvcEdition.TransitionEffect –> | A transitionEffect for Element property |
transitionEffectDelayInMilliseconds | Int32<!– System.Int32 –> |
Set webImageFormat for Element property and retun the WorldMapKitWmsWebOverlaySetting
webImageFormat | WebImageFormat<!– ThinkGeo.MapSuite.MvcEdition.WebImageFormat –> | A webImageFormat for Element property |
Set wrapDateline for Element property and retun the WorldMapKitWmsWebOverlaySetting
wrapDateline | WrapDatelineMode<!– ThinkGeo.MapSuite.MvcEdition.WrapDatelineMode –> | A wrapDateline for Element property |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay,ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting} –> Go Back
